Question about Cell Phones
Does anyone know where I can purchase a replacement lens for my motorola i9? I need the touchscreen to work . The outer glass is cracked not the lcd itself. Please help!
Cracked screen
    wholesale lcd 1024x600 ips 7 - AliExpress.com
    www.aliexpress.com > Wholesale Product
    7" 7Inch 1024*600 1024X600 IPS TFT LCD Dispaly Screen For ... 100% Original LCDScreen Replacement Repairt Part For Freelander PX1 1024X600 IPS Screen ... Original New 7" IPS Tablet Touch Screen Touch Panel Digitizer Glass For ... images for Cracked screen 7 inch panel 1024x600 ips
    More images for Cracked screen 7 inch panel 1024x600 ips
    Cheap screen 1024x600 replacement tablet 7 deals
    guide.alibaba.com > Computer Hardware & Software > Tablet PC
    7 inch 1024*600 IPS screen Capacitive touch panel nfc android tablet .... Front TouchScreen/Panel Glass Screen Replacement Repair Parts for RCA Tablet 7 ...
    Touch Screen 1024x600 - Alibaba
Jan 01, 2016 | Tablets & eReaders
Touchscreen stopped working
HERE'S A LINK TO REPLACEMENT SCREEN... http://www.cellulardr.com/motorola-cliq-xt-mb501-faceplate-with-touch-screen-digitizer-and-lower-navigation-keypad-assembly-with-flex-cable-tmobile-quench-front-housing-frame-with-touchscreen-lens-glass.html?cat=248
THIS IS THE SITE: THERE ARE TWO DIFFERENT SSCREENS, ONE WITH THE WHOLE FRONT PANEL FOR $100.00 AND ANOTHER WITH JUST THE SCREEN PART FOR $89.00 YOU CAN CALL: Call 818-553-2700 OR HERE'S THE LINK: http://www.cellulardr.com/motorola-mb501-cliq-xt-main-lcd-display-screen-with-flex-cable-tmobile-quench-main-lcd-display-module-with-flex-cable.html
Dec 17, 2010 | Motorola Mobility CLIQ Cell Phone
Lens got dropped and the out glass cracked. Lens
Hi, there.
I assume you mean the 77mm FILTER that was screwed on the lens.
Apr 25, 2010 | Nikon 70-200mm f/2.8D VR G-AFS ED-IF Lens
My son crack the LCD glass on his 204T SyncMaster
The glass of the panel is glued or welded to the LCD wafer below, it cannot be replaced separately. Since the panel is the most expensive part of an LCD monitor, its probably the cheapest option to just get a new monitor - spare part ordering and extensive manual work required for the change simply outweighs the remaining value of the monitor.
Feb 09, 2010 | Samsung SyncMaster 204t 20.1" Flat Panel...
Cracked touch screen i9 phone
The I9 has a defect. The outer screen, which is glued, does not allow for expansion. My screen cracked after only a week of light use. My phone was NEVER DROPPED, and developed a small crack near the edge. Within two hours, the crack expanded to the other side of the screen. The phone i have was manufactured in the same month I got it. Motorola has some issues with their warranty system, and it only works sporatically. This phone will most likely be recalled.
Apr 17, 2009 | Cell Phones
Outer glass lense replacement
I needed the same lens. Found it at:
http://www.flexqueen.com/mov3v3cv3mv3.html
Not sure about how to fix it but I think I will find some info at:
http://www.themotoguide.com/razrdisassembly.php
Mar 14, 2009 | Motorola Mobility RAZR V3
Motorola RAZR V3 faceplate lens cracked
This is very simple to fix. I have replaced 2 of them already. You can buy the new glass for I believe $6.99 or around that delivered from someone selling them on eBay. Then just pull out the old glass etc. Then the new piece has a little trim of double sided tape on it to fit into the exact same spot.
Jul 30, 2008 | Motorola Mobility RAZR V3
Motorola V9
bring it to the professionals to work with it.. you may damage your fone if you alone...
Apr 20, 2008 | Motorola Mobility MOTORAZR2 V9 Cellular...
Cell Phones Logo
76 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
