Question about Hitachi 55VS69 55" Projection HDTV
I have a blue ring or halo around center of screen
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
55VS69 is a LCD rear projection set---if you have blue or some other color discoloration in some part of the picture most likely you have a damaged optical light engine.
This model used two different ones--It is an expensive part as one wholesales for about 550 and the other about 600 not counting major labor to replace.
If you have an extended warranty--get it in and fixed.
The reason this happens in some sets is the Lamp used for the light source creates a lot of heat and can damage the lens/baffles inside the sealed light engine.
Blue is the most common as that part of the engine is usually closest to the lamp.
The set shines the light from the lamp into the engine and signal etc is injected and at the top of the engine is a 3 inch lens that projects the picture into a mirror which puts it on the screen.
Some of Hitachi's earlier sets are now involved in class action lawsuits as they had a red oval in the middle of the screen--red was first in those models--some Sony and other sets have had the same problems.
Let me know if you have questions as I am here to help. I know I am not giving you good news but based on your description I think it is your problem.
If this has helped you at all, rate this solution as I do this here for FREE.
Thanks for using Fixya!
SD TECH
Posted on Nov 20, 2009
Testimonial: "thanx (i guess) for the info...."
Samsung hcn5529W hmdi input dispaly issue
then try using RY able instead of HDMI input to test if its a cable problem
Mar 29, 2008 | Samsung HCN5529W 55" Rear Projection...
Convegence
Yes - about every 4-5 years.
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 18, 2010 | Televison & Video
When the screen goes dark there is a blue halo with rays radiating out from it.
this is likely caused by a misaligned deflection coil on the blue CRT or in the blue deflection amplifier circuit or a defective deflection coil assembly, you may be viewing a inductor ring, posibly due to arking internal to the coil these are the most likely faults
Jan 22, 2010 | Televison & Video
I am getting a blue halo around text and objects on screen, wheb text is at the bottom the blue halo is curved over the original text.
A common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Or - your TV may have a convergence problem....
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 20, 2009 | Philips 51PW9363 51" Rear Projection...
My Hitachi LCD rear projection TV has blue color in left corner
It is most likely the tube going out. Find some one to replace the tube if the TV is fairly new other wise it is going to be a trend. One tube now and another.. and so on. Ride it out as long as you can then go for an upgrade
Sep 08, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
White halo on picture
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Jan 25, 2009 | Televison & Video
White objects (especially text) on a black background produce a white halo effect around the white lettering. When playing a PS3 game I noticed that the blue color appeared black, as though I had no blue...
Aug 27, 2008 | Philips 9P6040C 60" Rear Projection...
Yellow tinted halo
you need to have the lcd pannels cleaned
Feb 26, 2007 | Hitachi 60V710 60" Rear Projection HDTV
Blue Halo, Tried to adjust on Projection TV
The convergence issue you have will not adjust out....repair
of the convergence circuit will be necessary....then adjust...T.
Dec 01, 2006 | GE 46GW947 46" Rear Projection Television
Televison & Video Logo
1,067 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
