Question about Stoves Ovens
Light not comming on bulb shorted when taking out
    President:
  • 1,891 Answers
You wii need to replace the socket and the bulb . / could also damaged the lite sw . mm
Posted on Nov 20, 2009
CAN'T GET MY DACOR OVEN LIGHTS TO WORK AFTER REPLACING BULBS
take the bulb back out and check to see if the prong that hits the bottom of the light bulb is making contact. If that don't work then its most likely going to be a short or a wire problem of some sort...Do all the basics first the work your way down...It should be to hard if your willing to go further if necessary...If not then its time to call the tech...Hope this helps you out..
Dec 17, 2014 | Dacor ECS230 Epicure Electric Double Oven
What type of light bulb do I fit in New World E70DOa oven?
Lights in oven are special, but are readily available at Home Depot or Lowes. You need to remove the old bulb, take it with you, and you will be looking for a utility bulb. The bulb usually has a heavy glass dome over it, held in place by a spring clip
Dec 14, 2014 | New World Ovens
Light bulb in oven exploded and now new bulb will not go on
The exploding lamp may have shorted the receptacle
Aug 08, 2013 | Ovens
The microwave light is out. How do I change it??
I have a kenmore inbuilt and you take the front louver off and the light is under a flap inside. I also have a counter-top model and the only way to get to the lamp is to take the outside case off. On the model I have, there are 8 screws and one of them is tamper resistant, which means that you have to have the correct screwdriver bit to take the case off. Make sure that the unit is UNPLUGGED before you take the case off, and don't touch the electronic stuff. Also don't clean the insides. Get a long life bulb if you can so you don't have to do it again. And make sure the door switch is not bad before you start. Put something in the microwave, turn it on for a few seconds, then open the door a very short distance. The microwave should turn off, and if it doesn't, the door switch is bad.
Jun 30, 2010 | KitchenAid Ovens
Light will not shut off
The only thing thing it can be is the light switch, as this is what gives the power to the light bulb.
It sounds like the switch contacts have shorted, thus giving a constant feed to the bulb, If it were me,I would fit a new switch, but to be sure, pull the leads of the switch, and the light should not work.
MAKE SURE POWER IS OFF FIRST!!!!!.
Feb 08, 2010 | Amana AOCS3040SS Electric Single Oven
GE Profile convection with light bulb burning out
Multiple possibilities.
  • Being used as a night lite. (continuous use)
  • Not using a light bulb designed for use in a oven.
  • Inexpensive bulb. (very low lamp hour rating).
  • Oven door slamming.
  • Over voltage condition.
  • (My favorite) Light bulb swapping Gnomes.
Please take the time to give this solution a fix ya rating.
clarkco
Feb 22, 2009 | GE Profile JTP18 Electric Single Oven
Need to replace light bulb in kitchen aid microwave
KitchenAid wants $58 for the replacement bulb. I bought it for $1.99 from www.lightbulbsdirect.com and it works just fine. The Item number is Q5G412V. It is a halogen 5-watt, 12-volt bipen G-4. Replacing the bulb requires some dismantling of the microwave. At first I was nervous about removing so many parts to get to the bulb but in the end it really wasn't so bad. The only tool I needed was a Phillips screwdriver. I surfed the net a eventually found instructions left by a friendly Blogger that guided me through the whole process. KitchenAid engineers were so STUPID when they designed this microwave. It takes two hours to replace a bulb that should take 5 minutes. Oddly enough, replacing the bulb in the normal oven below the microwave oven is a piece of cake.
Jan 19, 2009 | KitchenAid KEMC308 Electric Double Oven
Nardi FE46 electric oven short
it appears that there's a short in the oven. When you turn it on is when the short happens and in order to properly determine what is wrong then you are probably have to call a service tech./
Dec 23, 2008 | Ovens
Burnt out light bulb in microwave
well it is an absolute nightmare changing the light bulb in the microwave. you have to basically remove the microwave from the rest of the appliance to get to the light after remove panels and other parts. if you intend on doing this take your time. best solution is to have a repair do it that way if it doesn't work he/she is liable not you. best of luck
Jun 20, 2008 | KitchenAid KEMC308 Electric Double Oven
Light bulb
for most smeg, the bulb cover just unscrews as does the bulb and the bulb is a heat-proof small edison screw type
May 07, 2007 | Smeg SE250XUK Stainless Steel Electric...
Open Questions:
Ovens Logo
87 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
