Question about Kenmore Elite 45986 Front Load Washer
Just got a used front end loading kenmore wash mach but very stinky, musty, apparent slime on inside door and seal inside. Heard there is some kind of filter to clean?? Dont't have manual
  • 776 Answers
Try the manual at...
http://dl.owneriq.net/3/30076fd9-5976-4686-b185-6962a1bd649f.pdf
If that is not the right one (check your model number). Check the site...
http://laundry.manualsonline.com/
Enter kenmore and model at left of page...
Good luck - please rate this answer.
Posted on Nov 20, 2009
How do I get rid of musty smell from my Frigidaire front load washer?
First you should reach deep into the front door seal and run your fingers around. There is probably slime in there. You will need to thoroughly clean this with a bleach water mix about 50-50. You might need to pull the seal almost inside out to get in there good. If after scrubbing you still have black in the rubber the mold will come right back in that case you will need to replace the seal. They are not to hard to replace but a little tricky. Here is a link that should help if you need to replace the seal or if the wire ring pops off when cleaning. Now if all cleans up well or you replaced it be sure to wipe out the seal after each use (deep in there) and /or leave the door open.
If the seal is clean and no mold present and it still smells then you likely have a clogged drain pump filter or pump. Here is a link that should help cleaning a drain pump.
Nov 04, 2010 | Frigidaire ATF6000ES Front Load Washer
Drum smells
Open the door and run your hand deep inside the door seal. It probally has a slime around it. You can clean this with a bleach water mix. You might need to pull the seal somewhat inside out to get it real clean. Then run an empty load to flush it all out. Here is a link for replacing the seal or spring clips if you pull one off. http://appliancehelponline.com/washerdoorseal.html
Jul 07, 2010 | Hotpoint Aquarius WD640 Front Load...
Washer smells bad - musty
smell are normally due to 3 culprits
low temp wash , liquid soap , moisture
affresh washer cleaner may be worth a try
video
May 07, 2010 | LG WM0642H Front Load
The gasket at the front door collects water and turns to dark slime in our other wise nice LG front loading washer What is there to be done about this dirty & slimy problem
you may need to replace the door gasket .. it may be sealing properly. that green slime you speak of i s called algea, same fungus found in swimming pools.. you can use algicide to remove it . Pleas were gloves
Oct 11, 2009 | LG WM-2277HW Front Load Washer
Smelly clothes
It is because of the front loading door..
It seals shut - so after you do a load and shut it,, midew forms in certain areas..
Run a white load and use bleach..
After wash - (as all washes) leave the door open..
This might have to be repeted a few times - but it WILL go away..
Remeber to leave the door open after every load..
Have a nice day ;o)
Aug 14, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
How do I get rid of the musty smell?
If you know someone who owns a bar, ask them for about 1/2 pt of line cleaning fluid. Start your machine on a 60o wash (empty) and as soon as the water starts flowing into the powder drawer, slowly pour the line cleaner into the water flow. Let the machine go through it's normal cycle, then run the same cycle programme as soon as you can (immediatly if possible) using clean water. Following this action, get your finger and rub it along the inside of the drum, if it's squeekly clean it's solved, if it feels slightly slimely, run the water only wash again the completly to remove any further residue of the cleaner. The smell should go. Let me know how you get on, Regards Dave.
Jul 17, 2009 | Frigidaire Affinity ATF6000F Front Load...
Smellly Bosch Max 1000 front loader washing machine
(Posted this already, but found an AU site that sells Norwex detergent - a great product!)
We've had our Fridgidaire front load washer for 6 years now, and untilabout 2 months ago, it smelled absolutely horrible. I tried the thingsI was told to do....hot water/bleach cycle, wiping the slime from therubber seal, and leaving the door open....it didn't work.
Iwas told about Norwex laundry detergent - Norwex is a company whichproduces green cleaning products - the detergent is a quicklybiodegradable, highly concentrated powder, and all I need is 1/4 - 1/2a teaspoon per load. After about one week of using the Norwex detergentI noticed that the smell was completely gone and hasn't returned! Also,the gross slime that used to collect in the rubber seal is no longer aproblem. I've been so wonderfully amazed!
I don't know why thisdetergent fixes the smell problem, but I've talked with others who havehad the same great results with it - their smell issue was solved.Perhaps it's because it contains no animal fat products?
Anotherbenefit of the Norwex detergent is how economical it is - it comes in a2kg bag for about $25, and in a front load machine you will get approx.800 loads from it using the above mentioned quantity/load! It's reallyan amazing product! You can buy it online - www.norwexnaturallyclean.com.au (an Australian site) is a great site to buy from. Good luck with the smell!
Feb 02, 2009 | Kenmore 44072 Front Load Washer
Clothes have a musty smell if left in the washer
Make shure to do a cleaning cycle. As well, wipe out the inside, the rubber gasket and the door when done washing for the day. We also have found that
leaving the door "Open" for several hours, when finnished, eliminates any future
smells.
Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
Clothes Smell Musty and Damp
It sounds like a build up of washing residue. Clean inside the door seal and do a very hot wash with a bit of washing powder and no clothes. Repeat this once a week until smell has gone.
Oct 28, 2007 | Hotpoint WMA30 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
67 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
