Question about APS20B Prestige Keyless Remote Alarm
I just got a prestige pager alarm for my car. how do i set the time on the pager remote?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 19 Answers
Hold down the F button 3 seconds then hit it again to advance to the clock mode, use the lock and unlock buttons to toggle the feature up and down. regards, martin @ lessco electronics
Posted on Jul 29, 2010
I bought my car used with an aftermarket prestige alarm w/ remote start. Battery and alternator went bad. They have been replaced. The car will not turn on and alarm remote is not working.
Locate a black push button switch under the dash or near the drivers side kick panel (older model), or the alarm has a push button LED light(newer model) or the Valet switch is in the antenna(newest model). Turn the ignition on, press and release the switch one time. This should disarm the alarm.
For programming: turn ignition on, press and release the valet switch three times: you will hear one chirp from the alarm, press the lock button on the remote. Press and release the valet one time, you will hear two chirps from the alarm, press the unlock button on the remote. Repeat as necessary. Turn igniton off to exit programming. Test remote for proper functioning.
Jul 16, 2011 | Prestige Appliances Vehicle Parts &...
I have a new prestige car remote installed recently and i have a problem how to shut off the alarm coz the installer did not or forgot to give me the manual. When i start the car remotely i press the...
You did not mention the year/make/model of your vehicle but, the issue appears to be the factory alarm. The installer failed to make the connection. If you intend to make the connection yourself I would need information pertaining to the vehicle. The (-) pulse before start wire for Prestige remote starters is black with a blue stripe. It is in a 4 pin connector at the module. This wire can be used to disarm the factory alarm before the remote start sequence.
Jan 23, 2011 | Prestige Remote Start
I need to know how to set up a key fob for Audiovox PRO-OE2C4S
TURN KEY ON
THEN PRESS VALET SWITCH 3 TIMES
THEN PRESS LOCK BUTTON.
TURN KEY OFF
Jan 04, 2010 | Audiovox Prestige Code Alarm Remote Alarm...
I need to see if a add on remote start will work with my prestige
The APS9076 is a OEM add-on remote start module only and not an alarm. Are you trying to add or find a remote to an existing Prestige alarm or installing one?
Aug 02, 2009 | Audiovox AS9076 Car Upgrade Remote Start...
How do I disarm a audiovox prestige car alarm?
Locate the valet/override switch (button), (if you can't locate it, try tracing the wires under the dash from the main unit, usually a black and gray or black and red set of wires). Turn key to "RUN" position then press the button, the alarm's LED should light up solid at this time indicating valet mode as been set.
Jun 14, 2009 | APS20B Prestige Keyless Remote Alarm
Free programming instructions for Prestige remote
YOU can call prestige tech support at 1800 225 5074.. or just put the key in the ignition turn the key all the way to the right without starting the car then flip the vallet switch usually located at the bottom of the dash drivers side, flip the switch on and off three times, you will hear a chirp then you should press the first button on the remote for 2 seconds then flip the swith on and off one more time , then press the second button the remote for 2 seconds then flip the switch again on and off one more time then press the 3rd button on the remote for 2 seconds... After which... remove the key from the ignition and your done... Try the remote to see if it works the way it should if not do it all over again..
MSB....
Oct 13, 2008 | Gmc Dodge Ford Reverse Back-up Sensor...
APS20B Prestige Keyless Remote Alarm Logo
415 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
