Question about Amana 18.6 cu. ft. Bottom Freezer Refrigerator
Amana,BX22A2W Freezer works, on bottom, Fridge is not cooling, no fan.
  • Amana Master
  • 43,501 Answers
This is a common problem and most of the time it is one of two things. Ice can build up stopping the fan or the fan is bad. Before changing the fan unplug your unit over night and let it defrost to make sure that ice is not the problem. If the fan works after that then also check that the defrost timer is not bad, which could be the reason that you have ice build up. If your fan still does not work and manual defrost then replace the fan.
I hope that this will help you to solve your problem.
Posted on Nov 20, 2009
Amana fridge abb2222few not cooling but freezer is working where is fan motor located for fridge section
its in the freezer near the top if its not cooling I would check ur air damper flow control, is it to far close or opened? check the cold control thermostat, the thermistors. and of course the fan itself, check door seals.
Mar 17, 2015 | Amana ABB2222FE (22.1 cu. ft.) Bottom...
NO COOL AIR IN THE FRIDGE PORTION
ck to make sure the condensor fan and evaporator fans are working.
Jun 02, 2012 | Amana ABB2227DE Bottom Freezer...
I own a amana fridge fridge on top freezer on bottom . all of a sudden my fridge stopped cooling the freezer still works fine I hear fans running but no cool air at all. please help me
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 16, 2010 | Amana Refrigerators
Freezer working but fan not on in fridge - where to locate fan?
May be ice build up - happened with mine. Had to defrost completely (unplug for 24+ hours) then it worked fine on restarting.
Aug 15, 2009 | Amana ABB1927DE Bottom Freezer...
Fan is not working and fridge is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
ARHGADF
Jun 03, 2009 | Amana ARB2557CSR / ARB2557CSL Bottom...
Compressor working but Fridge and Freezer not cooling - Amana
It sounds like the same problem my brother is having with his. I took it apart and found that the fan that moves all the air for cooling is not working. This fan is behind the bottom panel in the freezer side, and sorry you do have to take everything out to get to it.
May 11, 2009 | Amana ARS266ZBS Side by Side Refrigerator
Top refrigerator part not cooling, bottom freezer and fan working
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Nov 26, 2008 | Amana ABB1927DE Bottom Freezer...
My amana bottom freezer won't cool both the fridge and freezer are warm
I just had the same problem with the same fridge. When I removed the inside panel in the freezer, I found that the cooling/circulation fan had fallen due to the mounting screws having rusted off. I removed the fan housing to get the screw ends out from the back side and remounted the fan with new screws. The fridge and freezer both work fine now and I'm assuming it will for many more years until it happens again.
Nov 04, 2008 | Amana ABB1927DE Bottom Freezer...
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Same problem here with an Amana refrigerator with the freezer on the bottom. I removed the back panels and vacuumed dust and cat hair out. The back panel in the freezer was frosted over with ice on the bottom. I removed the shelves and food and used a hairdryer to loosen the panel. The ice maker made it harder to remove the plastic panel so I pulled it back and saw the cooling fins frozen solid. I used the hairdryer to melt the ice and a shop vacuum to collect the water. It works like new again.
Dec 02, 2007 | Refrigerators
Amana 18.6 cu. ft. Bottom Freezer Refrigerator Logo
262 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
