Question about Hifonics BXi 2006D Mono Block Amplifier Car Audio Amplifier
How to connect HIFONICS BXI 2607 D watt at 1 ohm....
Two dual 2 ohm subs = .5 ohms wired parallel and 2 ohms wired in a series / two dual 4 ohm subs = 1 ohm wired pallallel and 4 ohms wired in a series / one dual 2 ohm sub = 1 ohm wired parallel and 4 ohms wired in a series / one dual 4 ohm sub = 2 ohms wired parallel and 8 ohms wired in a series......this means if you have two dual 2 ohm subs or if you have one dual 4 ohm sub you are not going to be able to get a 1 ohm load.......running parallel on a dual coil speaker is both positives are ran to the positive on the amp and both negatives are ran to the negative on the amp.....running in a series is the positive terminal from one coil ran to the positive on the amp and the negative terminal on the other coil ran to the negative on the amp and having the remaining open positive and negative terminals connected to each other with a jumper wire
Posted on Dec 10, 2009
That's dependent on your subwoofers. You will need 2 dual 4 ohm subs wired in Parallel, a single dual 2 ohm subwoofer wired in parallel, a single dual .5 ohm wired in series. Or something similar.
http://www.bcae1.com/spkrmlti.htm
Posted on Nov 20, 2009
How do I connect my hifonics bxi 2006d to a 1 ohm load
You need to be more specific. What are tyour subs ohm ratings. How many voice coils? How many subs?
Jan 05, 2015 | Hifonics Car Audio & Video
Can a hifonics bxi 1608d support a half ohm
http://www.maxxsonics.net/manuals/hifonics/pdfs/HifonicsBrutus2009AmplifierManual.pdf
THE ABOVE LINK WILL ALLOW YOU TO DOWNLOAD THE .PDF MANUAL FOR THE CURRENT VERSION OF THE AMPLIFIER WHICH IS THE BXI1610D WHICH IS STABLE DOWN TO 1 OHM WHICH PRODUCES 1600 WATTS. YOU CAN ALSO CALL TO VERIFY THE MINIMUM IMPEDANCE OF YOUR AMPLIFIER BY CALLING MAXXONICS AT 847-540-7700......V
Dec 27, 2009 | Hifonics BXi1608D Car Amp
I got to 12 they are about 400 watts each what would be a good amp to put on it to lift the subs
Hello jeremymikjha,
Basically you want to match the subs in impedance and power.
With 4 ohm subs wired in parallel, the final load will be 2 ohms. Depending on how hard you want them to hit, a pair of 400 watt RMS subs will need an amp that delivers 600-1,000 watts into a 2 ohm load.
The enclosure you use will also make a big difference. A sealed enclosure will need more power. A ported enclosure will be louder with less power.
The Hifonics shown here would be a good choice for a sealed enclosure. It's rated for 1,100 watts RMS into a 2 ohm load.
http://www.sonicelectronix.com/item_17598_Hifonics+BXi+1610D.html
The Eclipse XA1200 outputs 600 watts RMS into a 2 ohm load. It would power the subs very well in a ported box.
Somewhat less expensive but good quality would be one of the Alpine MRP series. The MRP-M500 is only $179.99 at SonicElectronix. It delivers 500 watts. It's big brother is the MRP-M1000 with twice the power. Be sure your subs are securely mounted or this amp will literally "lift the subs".
Hope this helps.
Oct 19, 2009 | Rockford Fosgate Punch 301M Car Audio...
Bxi 1606d amp it turns on power up but no sound
Well i sounds like your amp is shot. Or you have the subs wired incorrectly to the amp. Each amp is different in stability with ohm loads and each amp performs differently at each load. Sounds like it was wired at the wrong ohm load in the past or it came defective from factory. Definately send it back if u just got it.
Jun 09, 2009 | Hifonics BXI 1606D Car Audio Amplifier
Hifonics brutus 2000 watt help??!!??
If an RCA took a dive your amp has most likely seen a very nasty input spike and may never be the same as its circuitry has been damaged.....sorry
Mar 09, 2009 | Hifonics Brutus BXi 1206D Car Audio...
2 4ohm dvc subs to a bxi 608 ( 600watt mono)
take the positive on the sub and run a wire to the other positive the run a negative to the other negative then to your pos and neg on the box do the same on the other side then tie your two positives and two neg together and you got 1ohm and that amp willl handle it all day
Jan 29, 2009 | Hifonics Brutus BXi 606 Car Audio...
Hifonics BXI 1606D problems
it may be a wiring problem you need to make sure all the speaker positives and negatives are correct. I sell alot of hifonics amps and have never had 1 do that. it may also be a bad rca cable. if it only does it when you use the filter i would say not to use it also make sure the gain is no more than 3/4 turned up and the bass boost no more than 1/2. if you have a dif amp try a temp setup using it and if it still does it its a wiring issue. also try 1 speaker at a time on the hifonics and keep adding 1 till it comes back it may be a bad voice coil on 1 sub .
Jan 08, 2009 | Hifonics BXI 1606D Car Audio Amplifier
Brutus 1206D
yes it can only at 2 ohms never 1 ohm good luck
May 25, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Setting low pass and bass eq
the only thing that might damage equiptment other than playing it too loud would be running at 1 ohm if not supported by the amplifier.
as far as the eq and crossover settings, that is dependent on personal preference, and the acoustics of the paticular vheicle installed
May 15, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Hifonics bxi 1206d
make sure you have a 40 amp fuse in it
im going to try to describe this to you
to bridge a amp this is for 2 ch AMP
I 2 2 I
I 2 2 I
I I 22
I I 22
I I 22
I I 22
#1 SPEAKER #2 SPEAKER
WIRE WIRE
ONE GOES ON THE POSIVE OF ONE SIDE AND THEN THE NEGATIVE OF THE OTHER
HOPE THIS MAKES SINCE
PLEASE LEAVE MY RATING
Feb 11, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Car Audio & Video Logo
507 people viewed this question
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
