Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
I just replace both ink cartridges and now the printer will not come on it shows that the ink cartridges are empty.
  • 235 Answers
Is the ink cartridges new? if it is new try re installing the devices software, if you done that and message still the same then there is a problem with your printer head maybe it is dirty or you may need a new printer head
cartridge replaced
regards
michael
Posted on Nov 20, 2009
My printer is not HP it is Brother MFC-260C
The printer uses several ways to show ink levels. When you replace the cartridge it askes if it has been replaced, Say yes and it sets the ink level monitor to full. As the cartridge empties it them checks through an electronic eye system through the cartridge. When it cannot see any ink it says it is empty.
Replace the cartridges and it should fix the problem.
Feb 22, 2016 | Brother MFC-260C All-In-One InkJet Printer
Ink empty after replacing ink cartridge
Printers often show 'ink empty' when a remanufactured cartridge is used. Usually the printer will still print but some makes have a block that stops this.
My Canon does the same but i ignore the message and it prints OK.
May 22, 2013 | Canon PIXMA Office Equipment & Supplies
MY EPSOM CX 5500 WILL NOT PRINT. i HAVE A RED LIGHT PERM ON BY THE INK ICON. i HAVE TAKEN OUT THE CARTRIDGES SEVERAL TIMES AND RESTARTED BUT NOTHING HAPPENS. tHE CARTRIDGES HAVE INK AS FAR AS i...
Hello, This happens with epson as it has a chip on the cartridge, which sometimes shows the cartridge empty even if there is some ink left on it. You can try this steps:- 1. With the printer turned on press the ink replace button, which will bring the print head to ink replacement position, pull out the cartridges one by one and cover the tip of the cartridge with some tape and shake the cartridges and reinsert it on the printer and press the ink replacement button once again, the printer will check the inks cartridges, if the inks is empty it will show the red light again, pressing the button once will bring the printer to ink replacement position with the cartridge to be replaced on the replacement position. you can also check on the printer software on the pc that which ink cartridge is emptied.
Hope this helps.
May 14, 2011 | Epson CX4400/CX5600
No Cartridges. Open Scanner cover, then reinstall ink cartridge. All Cartridges are full
No Cartridge will show on the display if the machine cannot recognize one of the cartridge or one of the ink is empty.
To make sure about the real issue unplug the mach from the power outlet then plug it back in after 10 seconds.
If the display show: "ink empty C" it means the cyan/blue needs to be replace. "ink empty M" it means the magenta/pink needs to be replace. "ink empty BK" it means that the black needs to replace. If the display shows "ink empty Y" it means that yellow needs to be replace.
Even if it looks like the cartridge is full, it really needs to be replace so that the machine will work again.
Hope this helps. Rate if it works. Thanks
May 05, 2011 | Brother MFC 210C All-In-One InkJet Printer
I just changed my yellow ink and printer is still saying no cartilage need to replace
No Cartridge will show on the display if the machine cannot recognize one of the cartridge or one of the ink is empty. Try to unplug the mach from the power outlet then plug it back in after 10 seconds. If the display show "ink empty C" it means the cyan/blue needs to be replace. "ink empty M" it means the magenta/pink needs to be replace. "ink empty BK" it means that the black needs to replace.
May 03, 2011 | Brother MFC 240C All-In-One InkJet Printer
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
The printer tells me to replace an ink cartridge because the ink has been depleted. The cartridge is nearly new, though. Just yesterday it showed to be half full. I have cleaned the printheads and the...
There is a chip on your cartridge that communicates with the printer to estimate how much ink is left in the cartridge. When the chip thinks the cartridge is empty it will refuse to print any more pages no matter how much ink is left in the cartridge. These cartridges are only estimated to print "up to 840 4" x 6" photos, or 80 13" x 19" photos." If it showed half full yesterday and then you put through a large print job it is very likely the cartridge is empty. In any case once the chip thinks it's empty the cartridge needs to be replaced.
Nov 09, 2009 | HP Photosmart Pro B9180 InkJet Printer
How to replace a new set of ink
If ink cartridge show red light for empty ink cartridge Just press the cartridge will come at standby those cartridge is empty ; just replace it.
If not empty you want to change
Press ink button ..... don't leave until your carriage unit not come at the replacement position
First Black will come and next color will come and after pressing ink cartridge it initialized and it will be ready /
Thanks
Oct 28, 2009 | Epson Stylus C20SX InkJet Printer
Cyan Cartridge not working
Show empty or not recognized (cross sign)? Check connector at chip and at head carriage. Do replacement procedure form status monitor (how to..). Do replacement ink tank one by one with cyan ink first.
Jul 25, 2009 | Epson Stylus RX425 Multifunction...
Problem with replacing color ink cart. #5
Is it the right Cartridge you are trying to install please check and then check if the sensors are working.
Mar 31, 2009 | Lexmark X2600 InkJet Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
167 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
