Acer Aspire 3680 Laptop Logo
Posted on Jan 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hibernation Turned on computer and screen says hibernation. Tried everything cannot bypass.
Anonymous
Level 2:
Sergeant:
  • Expert 239 Answers
  • Posted on Jan 11, 2008
Anonymous
Expert
Level 2:
Sergeant:
Answers
239
Questions
0
Helped
117371
Points
620
Hello I was wondering did you try to go in to your bios and turn your hibernation option off, That should take care of your computer in that state, Now if you don't know how to get into your bios its fairly easy, When you first turn on your computer you see your computers Logo. Dell,Hp,Ibm,ect. Now when you see that, press the F2 key or it may even be the delete key repeatedly until you enter the bios, Now look at the instructions on how to navigate around your system, Now if you go to your power options and turn off your hibernation option and any others that you don't need, after that push F10 to save your settings and exit, That should get you up and running. Let me know if that don't work and we will figure out another way.
What is the difference between putting your computer to sleep or in hibernation
putting a computer to sleep is not the same as hibernation because sleep mode still is technically powered on it's just in a relaxed state or low-powered state whereas hibernation takes everything that's in Ram writes it to hard drive and then completely Powers down hope that helps
tip
How to enable hibernation in Windows XP
Hibernation is a low-power mode that laptops use when they are idle in order to save power. A hibernating computer can come back up to ready a lot quicker than a computer that is completely shut down, but it only uses marginally more power while it is hibernating.
To enable hibernation, open the Power Options applet in the Control Panel. Click on the Hibernate tab (the farthest one on the right) and check the box next to "Enable hibernation." Beneath this box you will see the amount of disk space required to use hibernation. (This amount is typically about the same as the amount of RAM you have installed, because when the computer hibernates, everything in RAM is written to the hard drive.) If you do not have enough free hard drive space, you won't be able to use hibernation; delete some old programs or files that you no longer need in order to free up some more room.
Once you have enabled hibernation and clicked Apply, you can tell Windows when to use hibernation. Go to the Advanced tab (still in Power Options). Under the "Power buttons" heading, there are settings for different actions, such as closing your laptop's lid or pressing the power button. If you want your computer to hibernate when any of these actions are performed, just choose Hibernate from the drop down list. You can also make your computer hibernate manually by choosing Hibernate from the shut down options (Start menu > Shut Down).
Your changes will take effect as soon as you click Apply or OK.
on May 28, 2010 • Computers & Internet
Hibernation partition
Make sure you have the HDD in the same state as it was on Hibernating. If it was removed after Hibernation, it will not be 'seen' by the PC. Everything that was connected during Hibernation MUST be connected again when starting the machine so the O/S can follow the route.
1helpful
3answers
Question
Hibernation is a power management feature. When you hibernate a laptop, you're essentially turning it off. So, unlike Stand By (Sleep) mode, a hibernated laptop isn't using any battery power at all - that laptop is off!
The secret behind hibernation is that before you turn off the laptop, everything you're doing with the computer is saved. (The contents of memory are saved to the hard disk.) When the computer is turned on again, it recovers from hibernating by reloading all the saved information and restoring your laptop to exactly the same condition it was in before it was hibernated.
Briefly, hibernation works like this:
1. You activate the hibernation feature.
Hibernation is activated differently depending on how it's set up.
2. The laptop hums as everything in memory is saved to disk.
3. The laptop turns itself off.
It's really and truly off: The battery isn't being used, and it's safe to store the laptop or put it away until you need to use it again.
To recover from Hibernation mode, just turn the laptop on. In some cases, the laptop may recover from hibernation when you press a key or touch the mouse pad. hibernated state for as long as you want.
Hibernation mode requires hard drive space. So you should be aware that when hard drive space runs low, it's possible that Hibernation mode won't work.
In Windows XP, you have to activate Hibernation mode before you can use it. Follow these steps to activate Hibernation:
1. Click the Start button.
2. From the Start menu, choose Control Panel.
3. Open the Power Options icon in the Control Panel.
4. In the Power Options Properties dialog box, look for and click on the Hibernation tab.
If you don't see a Hibernation tab, there's your answer: The laptop isn't capable of hibernating. Oh, well.
You might want to check the laptop's Setup program to see whether you can activate Hibernation there.
5. Select the Enable Hibernation option by clicking the check box to place a check mark in the box.
6. Review other options, if they're available.
7. Click OK to confirm the changes and close the Power Options Properties dialog box.
Optionally, close the Control Panel window, as well.
Some laptops may require you to restart Windows for this change to take effect.
2helpful
Screen goes blank after hibernation - Dell Inspirion 530 Vista
Turn off vista hybrid sleep and hibernation mode. It causes more problems then it helps.
Monitor keeps hibernating, can't make it stop, pixel issue.
Hey,
I think this is more of a problem on your computer instead of the monitor, ofcourse you could try another monitor and see if the same happens. I suspect your computer goes into standby or hibernation on its own, and it does work fine if you reset the computer right?
if you go into power management again, disable or turn off hibernation completely, its on one of the pages.
Make sure its not set to standby, and also disable your screen saver.
Right click on desktop - properties - then screensaver. turn it to none.
Also you could look into the computer bios and make sure its not set to standby or hibernation from there. thats unlikely but you could check.
how to get into bios.. depends on the computer, right when you turn it on, on one of the corners of the screen you will get a message, press button to enter setup or bios. press that to enter bios when its presented.
look around the bios and poweroptions.
Let me know if you need anything else.
Thanks,
Ekse
2answers
Hibernating
go to power options got to hibernation tab then untick enable hibernation . then reboot
3helpful
4answers
Hibernation problem?
Press and hold the blue Fn key while pressig the F4
wait a moment and see if it wakes up
Hibernation feature
Please press key button CTRL + ALT + DELETE to terminate hibernate mode.
Best regards,
Philip
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
