Question about Panasonic DMC-TZ4 Digital Camera
Panasonic DMC-TZ4 When I switch on I get "Turn off camera and turn on again" message but it does not good. When I swtich off I get "workng hard" noises as if there is an effort to retract the lense but it will not retract unless I turn the camera on again. At that point the lense retracts and comes out again at once; more "hard work" noises and a new "turn your camera off" message. The only way to get the lense into the retrated position is to catych it at the right instant and remove the battery. It feels to me lke a software problem. The camera was bought in September 2008.
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 20, 2009
I have lost the manual on the use of my Lumix Panasonic model no DMC-TZ5
http://service.us.panasonic.com/OPERMANPDF/DMCTZ4.PDF
The filename says TZ4, but it's the manual for both the TZ4 and the TZ5.
Jun 06, 2011 | Panasonic DMC-TZ5 Digital Camera
Hello I have a panasonic DMC-TZ4 digital
You can download and print your camera manual, at no cost, here:
http://www.brynmawr.edu/llc/documents/DMCTZ4.pdf
Apr 22, 2011 | Panasonic DMC-TZ4 Digital Camera
My panasonic DMC-TZ4 keep opening&closing the lens non stop and telling me to turn the camera off&on again. I cant do anything else with it. What will it cost to repair this? and where do I send...
check for a reset button on camera ,,it will be small,,push with a small screw driver or ink pen without cap,,may be on botom,,check ur user manual to see,,
Nov 03, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
Panasonic Lumix DMC-TZ4 black - memory card locked
Remove the SD card and slide the lock switch on it to the unlocked position. If it's already there then slide it fully to locked and then fully back again.
If this fails then you need to try another SD card to see whether it's a camera fault. If the camera is at fault then there's nothing more you can do other than to return the camera to Panasonic for repair.
Nov 28, 2009 | Panasonic Lumix DMC-FZ18K Digital Camera
Panasonic DMC-FX35 error message
Sounds as if it has either received a knock, or foreign matter (grit etc) has got into the lens mechanism.
May 30, 2017 | Panasonic Lumix DMC-FX35S Digital Camera
Water damage - screen asking to turn off camera
Hi!
The lens should be taken apart and cleaned. It could be a focus problem. In the worst case it could be a bad lens driver IC. It's a hardware fault not software so you should give it to a repair shop or Panasonic service center.
Sorry for the bad news.
Tom
Oct 09, 2009 | Panasonic DMC-TZ4 Digital Camera
USB upload error from Panasonic DMC-TZ4 to my laptop (Thinkpad T)
Are you trying to copy your photos off the camera, or use it as a webcam?
If you are trying to copy photos, then make sure the camera is in the correct mode, eg: playback mode. if the problem still occurs then try a different USB socket on the computer. If that doesn't work then possibly the USB socket on the camera is damaged (this is a common fault). I would suggest getting a SD card reader that stays connected to your computer full time, take the SD card out of the camera and plug it into the SD reader. That is a more reliable solution.
Sep 27, 2009 | Panasonic DMC-TZ4 Digital Camera
Panasonic DMC-TZ4 Digital Camera Logo
464 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
