Question about Dacor Dishwashers
Dacor 30' epicure dishwasher door won't open. i have hit thecure button for 3 seconds and nothi
  • Ginko
    Ginko May 11, 2010
    Hi.
    Hold down the clear button for longer, about ten seconds.
    Try tripping the circuit breaker, or disconnecting power cord for about five minutes.
    If the appliance is still not opening, then the tub is probably filled with water, or the door lock solenoid is broken.
    At that point you many need to call the service number listed on the owners manual to get a repairman.
    The tub is emptied accessing the drain hose underneath the dishwasher and disconnecting it from pump.
  • Dacor Master
  • 19,396 Answers
Hi.
Posted on Dec 02, 2009
Schematic wiring for epicure double oven eo230sch
Hi I found the schematic and a whole lot more here: http://www.msaworld.com/wp-content/uploads/sites/3/2014/07/Dacor-Technical-Manual-All-Products.pdf
Sep 19, 2014 | Dacor EO230SCH Discovery Epicure 30"...
My dacor microwave convection oven won't turn or heat but but the exhaust, time etc. works.
I found the answer on other posts on this website and it saved me $500! I had the same problem with my Dacor Model ECD2278 double oven. After I ran the self cleaning the top oven would not come on and the lower oven ran almost double the temp that was set. To fix: disconnect power to the oven at the circuit breaker. Open the oven door. You'll see the grille/grate/steel cover in front of the door latch mechanism, and it should have about 4 screws holding it in place. Remove the screws then remove the grille cover. On my model the tiny red reset button was on the right side on top of a black plastic round piece which is about 1" in diameter. Press the little button down til it clicks.
Oct 25, 2012 | Dacor ECS127 Epicure Stainless Steel...
The display reads OFF on both ovens, I have never seen this before and the ovens won' work
This means you have turned the oven OFF The solution is to hold down both of the Cancel buttons for about 10 seconds and the oven should turn back ON.
Nov 21, 2010 | Dacor ECD230 Epicure Electric Double Oven
How to replace glass on oven door - Dacor Epicure
You need to take the door off. There little hooks on hinges, that you move to up position and then lift up the door and it comes out. After that unscrew allt he screws, that you see.
Hope it helps.
Dacor range repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor double oven, lower oven works fine, upper oven doesn't turn on at all
I had the same problem after auto-cleaning my oven just before Thanksgiving. The cause was overheating...and the tripping of a heat sensor switch.
The switch (reset button) is located about 3 inches behind the door locking mechanism.
Removing the front panel (4 screws) that the door lock sticks through exposes the switch. Just push the little red button & your are back in business!!
Nov 14, 2009 | Dacor ECD230 Epicure Electric Double Oven
Oven won't heat
Check your main panel. If you ran it for a long time with the door open, the elements never reached their shutoff temperature. Quite possibly, you burned them out.
Feb 19, 2009 | Ovens
Constant buzzing noise
it sounds like your fan may be hitting on something
Jan 04, 2009 | Dacor Epicure EF42BNDB Side by Side...
Oven door won't open
Hi... Having problems with my Dacor ERD36 as well, I came across this posting that might help with your particular situation of not being able to open the oven door.
Here is the link to the forum:
http://www.applianceguru.com/forum1/2189.html
In case you can't get to the forum link, here is the response:
Have a 2nd person at the circuit breaker turn off power. You press and hold the cooktime keypad. The other person turns the breaker back on. The display will show the 4-character ID code of the ERC (e.g., 1180). You have 30 seconds between each test.
Press and hold these keys on sequence:
convection bake
standard bake
pure convection
broil
timer 2 (momentary push only)
stop time
clock
Finally, we arrive at the test we want:
Open the door, push and hold cook time for 10 seconds. Self clean latch motor will activate. Door latch will complete a cycle. The test will end the ERC will display the time of day.
Complete this test within 30 seconds or you'll get an F0 code (stuck keypad).
I hope this helps.
patti
Dec 06, 2006 | Dacor Epicure ERD36 Dual Fuel (Electric...
Dishwashers Logo
166 people viewed this question
Top Dacor Dishwashers Experts
Are you a Dacor Dishwasher Expert? Answer questions, earn points and help others
