Kenmore Front Loading Washer - Water in drum
We have a Kenmore Elite Washer that appears to be working properly.  It spins and drains during the wash and when we take the clothes out the drum is dry. However, lately, we have been finding about a cup of water in the drum the next day when we go to put in a load of wash.
Can't find the answer anywhere.  Can you help?
Thanks.
  • 1 more comment
  • Trollina Jan 11, 2008
    The model number is 110.4586.
    Does this help?
    Try this
    110 45872 403
    Thanks - will give it a try and let you know!!
  • 53 Answers
Sounds like your fill valve (hot and cold water hoses connect to it) is not shutting off compeltely. You probably have a slow leak/drip from it. To check it, after you remove your clothes at the end of the cycle, pull open and remove the soap dispenser and watch for a drip or trickle of water. If there is a leak. You will need to replace the valve assembly.
Good Luck!
Posted on Dec 12, 2012
    President:
  • 1,314 Answers
Please hold my rating till were done i need your model number to give you the proper procedure for checking your drain pump as i believe something in it is restricting your drain flow and three different companies build kenmore
Posted on Jan 11, 2008
  • 1 more comment
  • robert samples Jan 11, 2008
    there are about 10 digits in kenmores model numbers open the washer door and get it from there 110.4586 is right just not all of it
    First if you have a wet vac pull the drain hose out of the drain spout and use the vac to pull the water out of the washer through the drain hose.If not you will need a pair of radiator hose clamps from the auto parts store. Pull the screws from the lower panel at the front of the washer and remove it.in side you will see a rubber hose coming down from the tub to the drain pump. Put the radiator hose clamp there if you didn't have a shop vac.On the front of the pump is a round part with a handle turn that and remove the pump filter .Clean any foreign objects out of the pump and look inside the pump to make sure no impeller blades are broken if any are you will have to replace the pump. put the filter back in and tighten it. If you had to use the hose clamp remove it now.reassemble and don't forget to give the tech his four boxes if this fixes it
    i think that wii solve the promblem tell every one to check their pockets before putting in laundry lol yeah right
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Why does it leak all over floor after last spin cycle?
my washing machine leaks water onto the floor during each spin ...
https://answers.yahoo.com/question/index?qid...
Feb 3, 2010 - During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. ... It happened to us due to over loading. ...something can get betwen the two tubs it this all fails your tub seal is ...
Sep 30, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
Diagnostics ok but only spins slow
Water pump screen is plugged. Will not drain properly even though it goes into high spin.
Mar 14, 2014 | Kenmore HE3T Washer
Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Jan 15, 2010 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elite unite I have it for 6 years and now I have a problem, When is ready to go to the spin cicle it wont spin it just do anything the machine spin but the drum dont.
Hello, Have you checked for debris or an obstruction in the drain pump ? How about the belt, is it intact ? Does the water empty from the unit ? Let me know if you have an answer for these questions, and we can move forward toward having your washe back working proper. Good Luck :)
Oct 29, 2009 | Kenmore Elite 45986 Front Load Washer
Water drains during spin cycle, but tub does not spin and appears to have dropped down. Machine does aggitate.
If you can move the tub by hand laterally - the rear main bearing has likely failed - or the drum rollers are worn.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Elite 45986 Front Load Washer
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Kenmore Elite HE4t washer won't spin
The motor controller board is likely bad.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Open Questions:
Washing Machines Logo
1,246 people viewed this question
Top Washing Machines Experts
