Question about Fuji FinePix S5500 Digital Camera
I have a fuji s5500. I am missing one of the pins to attach the cover for the card chamber, it is the top one which I presume has a spring in it. do you carry this as a spare part. I am in Perth.
5 Suggested Answers
SOURCE: Card not initialized
While the camera is on, press menu and go all the way to the right. Choose "Set-up" and it will take you to a window with several tabs. Choose the tab called "1" and then choose to format the card here.
Posted on Jun 11, 2007
MarkDay
  • 111 Answers
SOURCE: i need to purchase spare parts
This type of repair is best performed by a professional service technician. You will need to find someone who is authorized Fuji service in order for them to get the parts, as Fuji will not sell them directly to the general public. Sorry I cant offer anything better, bummer about the camera :(
Posted on May 15, 2008
  • 4 Answers
SOURCE: Fuji finepix lenses
See my other post ref long/wide angle lenses.
Just check out ebay - look for fuji convertor lenses, a pair of basic Raynox long and wide angle lenses are about £100 although you can buy higher spec ones for significantly more. With Jessops going through hard times they tend to put these in their junk/clearance bins - I got my wide angle for £1.39 after waiting for about 3 weeks for it to drop in price. Check out when they are closing or clearing stock. Guess all high st retailers will be in the same boat wherever you are based at the moment so willing to sell-off slow moving stock.
Posted on Oct 06, 2008
  • 102366 Answers
SOURCE: I require the manual for the Fuji Finepix S5500 Digital Camera.
You may download a copy of the manual here.
Posted on Jun 12, 2012
Battery cover clips broken
I had the same problem with mine, sent mine to Fuji for repair.
Unfortunately they no longer have parts for this model, 8-(. I simply had to resort to using tape to keep the cover closed.
Jan 25, 2014 | Fuji FinePix S5500 Digital Camera
DO I NEED A SPRING FOR THE FLOTERS IN A 125 4STROKE CARBIERATOR?? I HAVE PLENTY OF SPARK NEW OIL NEW PETROL STILL WONT START
If youre talking about the spring in the carbs. throttle bodythe answer is yes.
Inside the main chamber is a cylinder with a long pin ,this pin or needle goes to the main jet which governs the gas flow.
if the spring is missing the needle will be in the wrong position .
as far as the floats are concerned they teater on a set pin and are designed to float on top of the fuel in the float chamber.make sure they move freely and that there not rubbing on anything or bent.you might want to try some starting fluid to get things started then make your adjustments,after starting aduust the idle screw first.
a good formula for idle screw is turn the screw all the way in .
Then turn it out 3 and one half turns out,
good luck,Gary
Sep 08, 2013 | Pit Bike 125cc 4 Stroke Dirt Bike
Broken battery cover
  • I had the same problem, sent camera to Fuji to fix. Fuji returned as they no longer make parts for this camera.
Mar 09, 2013 | Fuji FinePix S5500 Digital Camera
Where to by mainboard for fuji s5500
see the picture; God bless you
Aug 02, 2012 | Fuji Cameras
When i turn on my fujifilm s5500 i cannot take any photos or view and photos, if i format the card on the camera it than says card full. Than if i turn the camera off and than on again it comes up with...
I downloaded a PDF manual for your camera to make sure what I was about to say was indeed correct. My first impression/thought about this problem is that your camera Firmware is not capable of that size a memory card. I looked into the card capacity and according to the PDF manual you camera takes an XD - Picture card the capacity on the original Firmware is for 512mb here is a chart.
XD Card Max covers the S5100 and S5500 models
You may be able to go onto the Fujifilm web site and actually update your firmware.
Another thing that came to mind is that these cameras are often "clock" dependent and if the camera batteries have been removed for some time the clock date and time may also be giving an error. However my first impression is that the memory card is to large in capacity.
Jan 11, 2011 | Fuji FinePix S5500 Digital Camera
I have a problem with my Olympus C-750UZ. I stripped it down and replaced the bios capacitor and display screen. The top cover of the SD card assy came off and a small black spring (approx.16mm long x 1mm...
Sir if you know how to fix your device then the only thing to do is to buy that missing spring. i dont know if that spring is available on some electronic shop but if you cant find one then let the technician help you for they have tools and spare parts. hope that helps sir!
CHARCOIS
Sep 16, 2008 | Cameras
Fiji s5500
If you have no data on the memory card, you should hook up the card to the computer. If your computer doesn't have a slot to insert your memory card, hook the camera up to the computer. Then format the memory card (if you don't know how to do that, reply and i'll type it out for you...)
May 12, 2008 | Fuji FinePix S5500 Digital Camera
Fuji FinePix S5500 Digital Camera Logo
18 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
