I have a network set up in my house using a wireless router (D-Link DIR-655 A4). Our main computer is a XP pc in our rec room. My wife and I access the web from other parts of our house through the D-Link router, and up until recently, were able to also use a Canon printer which was connected via usb to the XP pc. Unfortunately, the Canon printer died, and so we recently connected a Brother mfc-7220 to the XP instead. While we can print using the Brother with all three machines (for the laptops using the shared printer privileges), doing so makes our ms office programs crash. Any thoughts on how to fix the problem? FYI...we use Network Magic to help manage the show.
  • 4,281 Answers
IF ms office program crash then you need ms office disk for repair or reinstall it.
You can also repair it from start menu->control panel0->add remove programs.
Select ms office and click on repair.
Also turn of printer sharing then again share.
You can use share printer with the ip of computer with which it connected.
For that go to start ->run type in run "\\192.168.1.2"
there is 192.168.1.2 is ip of computer check youre computer ip which has printer connected.
Then you can connect printer again from there.
Posted on Nov 20, 2009
655 and charter
To setup your D-Link wireless router follow these steps.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, open the browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings. (SSID, WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access). Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Mar 20, 2013 | D-Link Xtreme N DIR-655 Wireless Router
I have a DIR-655, can't log on with my Itouch, also can't remember password and have not been able to reset
There is a reset button on the back of your router, hold this down for 30 seconds with a pen. You will need to go through the whole setup process after this.
Mar 01, 2011 | D-Link DIR-655 Wireless Router
Just bought a D-Link wireless router (DIR-655). I have a static IP, so config using static IP info. Wireless works and 1 desktop works. However, main desktop can't get internet. I can ping router and...
I have the same D-Link Wireless Router and I can't say that I have run into this before.
Mine seemed to work from day one without any problems. I also purchased the D-Link adapter cards for a laptop and for my desktop that are located in other rooms.
Maybe, try a different version of IE to get it to access. I don't use Firefox, that much, so I didn't notice that firefox worked better or worse on my WiFi network.
Maybe try to shut off the broadband modem and the wifi router and the computer and then reboot all three to make sure that that's not the problem.
Also try to reset the router.
Good luck on figuring this one out.
Oct 29, 2010 | D-Link DIR-655 Wireless Router
How do you connect D-Link DIR-655 router if using an Apple computer? The Apple computer is currently connected to the modem. I have purchased a Dell laptop PC and want the PC to be connected on a...
1. Router's LAN1 connect to Apple through Ethernet cable.
2. Open your Dell Laptop's wireless network connection and search the network and then you can connect your Dell laptop to your router through wireless connectin.
Apr 02, 2010 | D-Link Xtreme N DIR-655 Wireless Router
I have a DIR 655 D Link router and I can't save changes.
Lots of possibilities, especially if the wireless device and your PC are older - the DIR 655 doesn't support wireless protocols 802.11 a and b, for example, only the newer g and n.
Start with getting the router software up to date (see http://us.dlink.com/products/connect/wireless-n-gigabit-router/ )
using an Ethernet link to a PC, and then debug the wireless access. The DNS message could be caused by the Windows wireless adapter config having a manual IP address vs the router being set for DHCP (dynamic) or vice versa.
Sep 10, 2017 | D-Link DIR-655 Wireless Router
Dir-655 works with XP and Mac which can connect
Go to 192.168.0.1 and login. Then go for the 'Setup' tab on the top and look for the 'Wireless Settings' tab on the right.
You can now automaticly setup your WLAN connection and afterwards you can go to the 'Manual Wireless Network Setup'. Over there you can change the 802.11 mode.
  • 802.11b only
  • 802.11g only
  • 802.11n only
  • Mixed 802.11g and 802.11b
  • Mixed 802.11ng and 802.11g
  • Mixed 802.11n, 802.11g and 802.11b
Go for the last one that uses n,g and b and you will be sure your computer can connect :)
Dec 14, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Dlink dir-655
  • call dlink support to configure the router
  • but if you can powercycle first the modem router and pc
Aug 02, 2009 | D-Link Xtreme N DIR-655 Wireless Router
My DIR-655 won't work!
It would be helpful if you could be a bit more specific regarding the way you hooked up the dir 655 to your network and your specifc DSL modem. If the modem you are using is the Actiontec M1000 DSL modem you will not be able to obtain internet access because the DIR 655 is trying to route an already routed IP, the M1000 has a built in router / DHCP that by default is enabled. You can use option 1, access the configuration settings of your M1000 and change the WAN configuration to act as a transparent bridge. After doing so and rebooting the modem you will have to enter your DSL login information like a PPPoE username and password for example into your DIR 655 network settings. With this configuration the modem simply acts as a bridge to relay data directly to the DIR 655 and the 655 itself provides login credentials to obtain internet from your DSL provider as well as hand out IP addresses to the local network. Option 2 is to continue to use the M1000 as a router by default and disable DHCP on your DIR 655 so that it essentially acts as nothing more than a switch or wireless access point while the M1000 hands out local IP addresses. I personally would recommend using the DIR 655 to route IP's as it's got far more configuration utilities than the M1000 does as a router, and really what's the point of getting the 655 if you're only going to use it as a switch or access point when there are other simpler and cheaper devices that could do that for you.
Jul 20, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Computer will not connect to internet through router
check the connections between the router and the modem either cable or dsl or whichever
and change the setting in the router interface so you know what the ssid is being broadcasted and the network key
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 18, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Wireless security not working on my D-Link DIR-655
- Log on to the configuration page of the router
- Go to Manual Wireless Network Setup
- And Change the Channel width to different one
Jan 12, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Computers & Internet Logo
David Payne
David Payne
