Question about Samsung CLX 3160fn All-In-One Printer
Back door won't close
We had a paper jam, opened up the backdoor and now it won't close.
  • 1 more comment
  • alegere Jan 11, 2008
    no, it's only able to close about halfway up, and than it stops and you can't force to close any further, there is two pieces of plastic with two rubber washer type things that hold it in place on a metal spool I think thats whats stopping it, but I don't know how to fix that problem
    Its snapped in right, we just had a paper jam, opened the back door, and now we can't close the back door, like I said, I think it has something to do with the black plastic things on the metal spool the is supposed to sync up with the plastic dividers( sorry for the lack of better terminology) There are two gray rubber washers that hold on this plastic black thing to the metal spool that runs across that back inside...I think that is what is hindering the door from closing, and we think that it may need to be adjusted or something, who knows, cause we don't, that all the info I have. Its kind of perplexing.
  • Dean Joly
    Dean Joly May 11, 2010
    Does it close all the way but doesn't latch so it falls back open or is it stuck open?
    Master:
  • 788 Answers
Might not be snapped in properly? Try pushing it in on it's hinge.
Posted on Jan 11, 2008
  • Dean Joly
    Dean Joly Jan 11, 2008
    May just need to be pushed harder, sometimes things get out of place and just need some elbow grease to push them back where they belong. Otherwise, without seeing your printer and not having seen this model first hand before I can't guess as to why your door won't close. Good Luck!
CLP-320N KEEPS TELLING ME TO CLOSE DOOR...ALL THE DOORS ARE CLOSED
Most likely you should check the 'door open switch', probably its broken.
Apr 24, 2014 | Samsung CLP-315W Laser Color Printer
On a clx-6200 message says "paper jam 0-c=open/close door. what door is this?
It is telling you that there is a paper jam. Open the door, pull the jammed paper out, close the door, it should clear the message.
Apr 21, 2012 | Samsung CLX 3160fn All-In-One Printer
My Dell MFP 1815dn has a paper Jam 2. I removed the toner cartridge and pulled the paper out, before I realized that I needed to open the back. I believe I thought I got the paper out, but the printer is...
After a paper jam occurs in the rear cover of a Dell Laser Multi-Function Printer 1815N, the printer will not resume when the jammed paper is removed. This is the normal behavior of the printer as there is no sensor on the rear cover of this printer.
To open the back cover and remove any stuck paper, perform the following steps:
  1. Open and close the front cover.
    The jammed paper may automatically exit the printer. If the paper does not exit, go to the next step.
  2. Gently pull the paper out of the output tray.
  3. If you cannot see the paper in the output tray or the paper does not move when pulled, open the rear cover.
  4. Skip to step 9. If you do not see the paper, go to the next step.If you see the jammed paper, push the two blue pressure levers up and remove the paper.
  5. Release the blue strap, the rear cover stopper, and fully open the rear cover.
  6. Unfold the duplex guide fully.
  7. While pushing the fuser lever to the right, open the fuser door. NOTICE: Make sure to unfold the duplex guide before opening the fuser door, or the fuser door may be damaged.
  8. Pull the jammed paper out.
  9. Return the levers, fuser door, rear cover stopper, and duplex guide to their original position.
  10. Close the rear cover.
  11. Open and close the front cover.
    Printing automatically resumes.
Jun 24, 2011 | Dell 1815dn All-In-One Laser Printer
I have several sheets of paper jammed in my printer and I can,t pull it out
Welcome to FixYa!
Don't try to pull out the jammed paper at the front panel of the printer. You might risk damaging your printer. Remove the jammed paper from the "Back Door" of the printer. The type of backdoor depends on what kind of HP printer you have. Below are 2 common backdoor of HP printers.
1. Press the Power button to turn on the printer.
2. While the printer is still on, disconnect the power cord from the rear of the printer.
3. Turn the printer so that the rear of it faces you.
4. Press in the tab on the left side of the rear door to release it. Then pull the door away from the printer to remove it.
5. Gently pull any jammed paper out of the rollers with your two hands.
6. Return back the back door. Gently push the door forward until it snaps into place.
7. Plug the power cord into the printer.
8. Turn the printer on again using the power button.
Note: Make sure to remove the jammed paper cautiously, any small pieces of paper left inside the printer might cause additional paper jam.
Some HP printers uses a latch to open the backdoor. Refer to the image below:
I hope that this will help you.
Thank you for using FixYa and keep me posted.
Jas247
Mar 09, 2011 | HP Office Equipment & Supplies
How do I fix a paper jam cef for epson aculaser cxn11nf?
Diagram of doors should be above control panel of printer.
Lift ADF/Scanner up. Open door "C" just below it. Lift orange photoconductor lever up to release photoconductor. Lift photo conductor up towards you. Inspect for jammed paper and remove if necessary. Replace photoconductor, close lever and door "C".
Open door "E" on rear of printer and look for jammed paper and remove. Close door "E".
Last place to look is in paper tray. Take stack of paper out and look for paper jam. Removed as needed.
These are the three places i have had jams and you will only find the jam in one of them. Most likely it will be in back in Door E
Aug 12, 2009 | Epson ACULASER CX11NF All-In-One Printer
I have a paper jam in the back of the machine how do you get the paper out?
open the back door,see where paper jam,could be wrapped around fuser.if no jam,fuser or output sensor faulty.
Jul 07, 2009 | Samsung SCX-4828FN All-In-One Laser...
Message on brother MFC7420 "back door open" when it's not
Actually, you need to double check the back cover and front cover, open them all to check all paper jam.
Besure to check the back cover, normally all paper jam is from the back.
be sure to close the front cover at the last cover to close.
Apr 01, 2009 | Brother MFC 7420 All-In-One Laser Printer
My printer always tells me paper jam
the issue can be found when the paper feed rolls in the printer or the internal encoder strip are dirty.
Please try the following:
- open the backdoor of the printer
- also open the front door
- unplug the power chord without shutting down the printer
- now clean the paper feed rolls inside the printer with a soft rubber
- turn the rolls some times (10 tries or so) from down to up
- close the backdoor
- move the cartridge cart some times from one side to the other
- now you see a transparent strip over the metal bar
- this strip you can clean with cleaning alcohol
(be carefully! don't loose the strip or take too much alcohol)
- now let the printer dry over night (let it be open)
- next morning, close the front door
- press # and 6 at the same time and hold them
- keep them pressed and plug in the power chord
- keep them pressed until you see "semi nvm reset"
done
Hope it helps,
Henning
Feb 04, 2009 | HP Officejet J5780 All-In-One InkJet...
Paper jam back door of Lexmark T640
I went at it with surgical tools and was able to grip and remove the paper by the visible edge
Dec 12, 2008 | Lexmark T640 Laser Printer
Paper jam. we removed the major portion of it. bit of paper is inside. we can't find out that. display shows 13.20.00. we removed front and back except toner catridge. what we have to do.
Try this linke below.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=411171&prodTypeId=18972&prodSeriesId=411171&objectID=c00642524
Or i cut and paste text, but you should view pictures. If you cannot get to it from link. Try typing "Paper jams alternating between front and back door" It should be first link from HP about a 3550.
HP Color LaserJet 3500, 3550, and 3700 Series Printers - Paper Jams Alternating Between Front and Back Door Issue Description Customers may see paper jams error messages with no paper seen in the paper path. The message will alternate between check the front door and the back door. Workaround The release lever engagement tabs on the rear door can be bumped into the in-correct position. The purpose for this tab is to re-engage the fuser release levers as the rear door is closed. When one or both of these are left in the in-correct position the printer goes into a cycle of alternating between a "Jam in the Front Door" message and "Jam in the Rear Door" message. There is no paper present in the paper path when this happens. When a customer gets the "Jam in the Front Door" message and opens the front door, no paper is found. After the customer closes the front door, they get the "Jam in the Rear Door" message. When they open the rear door, find not paper (even pull out the fuser), and close the rear door, they get the "Jam in the Front Door" message. This cycle will continue
Placing both engagement tabs in the "Correct" position solves the problem and allows the print job to continue.for as long as the customer is willing to keep checking.
Sep 27, 2007 | HP LaserJet 3550 Printer
Samsung CLX 3160fn All-In-One Printer Logo
52 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
