Question about Panasonic DMC-TZ4 Digital Camera
Panasonic DMC-TZ4 lense is out when off. When I turn it back on, the lense retracks and closes and then extends again. I try to do anything with it and it says; "Turn camera off then on again." the process starts over again.
I have lost the manual on the use of my Lumix Panasonic model no DMC-TZ5
http://service.us.panasonic.com/OPERMANPDF/DMCTZ4.PDF
The filename says TZ4, but it's the manual for both the TZ4 and the TZ5.
Jun 06, 2011 | Panasonic DMC-TZ5 Digital Camera
Hello I have a panasonic DMC-TZ4 digital
You can download and print your camera manual, at no cost, here:
http://www.brynmawr.edu/llc/documents/DMCTZ4.pdf
Apr 22, 2011 | Panasonic DMC-TZ4 Digital Camera
My panasonic DMC-TZ4 keep opening&closing the lens non stop and telling me to turn the camera off&on again. I cant do anything else with it. What will it cost to repair this? and where do I send...
check for a reset button on camera ,,it will be small,,push with a small screw driver or ink pen without cap,,may be on botom,,check ur user manual to see,,
Nov 03, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
I have a Panasonic DMC-TZ4 camera. I am on vacation and my settings got changed. I do not have the manuel with me. My flash won't work for indoor pictures and I do not know how to change the settings. Help
One of the buttons on the back has a lightning bolt icon. In picture taking mode, press the button and watch the screen....it will cycle through auto flash, red-eye flash, flash off, etc.
Oct 27, 2010 | Panasonic DMC-TZ4 Digital Camera
The camera was dropped and the lens is extended and will not retrack. There is no control with the power switch
Try sending the camera to Panasonic Repair Center for immediate repair. They can help you repair the unit since it was hit badly during the fall.
Thank you.
Aug 01, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic Lumix DMC-TZ4 black - memory card locked
Remove the SD card and slide the lock switch on it to the unlocked position. If it's already there then slide it fully to locked and then fully back again.
If this fails then you need to try another SD card to see whether it's a camera fault. If the camera is at fault then there's nothing more you can do other than to return the camera to Panasonic for repair.
Nov 28, 2009 | Panasonic Lumix DMC-FZ18K Digital Camera
Blurry images
Sounds like a lens problem. If you've ever let the camera "auto turn-off" as a power-saving measure, any button pushed will turn it back on...even if it's in a case or your pocket. This puts strain on the lens as it tries to come out...result....lens problems.
Nov 13, 2009 | Panasonic DMC-TZ4 Digital Camera
Water damage - screen asking to turn off camera
Hi!
The lens should be taken apart and cleaned. It could be a focus problem. In the worst case it could be a bad lens driver IC. It's a hardware fault not software so you should give it to a repair shop or Panasonic service center.
Sorry for the bad news.
Tom
Oct 09, 2009 | Panasonic DMC-TZ4 Digital Camera
I have a Lumix TZ4 that stopped working today. When I turn it on it says to turn the camera off and then on again and it leaves the lenses extended. I cannot do anything with the camera. Please help!
it is entirely possible that you have dirt or a grain of sand in the lens mechanism.
find some one with an air compressor or get a can of pressurized air and blow around the lens.
smack the camera lens down on your hand a few times ( not joking) and tuen it off and on to try and release the dirt holding the lens from setting up correctly keep persisting as in some cases it takes 20 -30 goes to get it free But it does woek belive me it happoened to me and when i was given this info i thought the guy was having a joke one me. But bingo! it finally worked
Jun 22, 2009 | Panasonic Lumix DMC-LS2 Digital Camera
Panasonic DMC-TZ4 Digital Camera Logo
170 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
