Question about SVA-USA VR 17S 17" Flat Panel LCD Monitor
When i turn on my computer all it tells me is sva no signal input please check video signal
  • 5,660 Answers
No Signal.
No signal coming from the computer.
The monitor is working, but there isn't any video signal coming from the computer.
1.Could be a bad video cable. The one from the monitor to the computer.
Do you have another computer available to test this monitor on? Use the video cable attached to it now.
Works?
You have a computer problem.
Doesn't work?
Use the video cable on the computer you're doing a test with.
Works?
You have a bad video cable.
Computer problem.
Does your computer have a graphics card, or is it Integrated Graphics that the monitor is plugged into?
(Integrated Graphics is also referred to as 'Onboard' graphics. ON the motherBoard)
With Integrated Graphics your monitor will be plugged into the I/O area on the back of the computer.
I/O = Input/Output
This area, is where the rectangular metal shield on the back of the computer is located. A mouse and keyboard are usually connected in this area.
Example of an I/O Shield,
http://ep.yimg.com/ca/I/directron_2079_111707086
A graphics card is a separate hardware component that is plugged into an expansion slot, and you will see it towards the bottom of the computer case. There are slots in the metal frame of the computer case, and you will see the outside edge of the graphics card located in one of these slots.
Example of a basic graphics card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5271084&Sku=G458-9603
It could be a problem with the Integrated Graphics, (GPU soldered to motherboard), or an issue with the graphics card, if used.
The main problem I see when repairing are one of three issues, or a combination of two or more issues.
1.The inside of the computer is dirty, and the power supply.
2.The power supply is bad.
3.Electrolytic Capacitors have failed, or are failing on the motherboard.
1a.If the inside of the computer is dirty, so is the inside of the power supply. The power supply's fan draws air through the computer.
Dust/Dirt/Hair, and other foreign objects, are drawn in with the air from the cooling fan/s, and the power supply fan.
No matter how good a person is as a housekeeper, this foreign material is drawn in. It requires a regular cleaning of the inside of the computer, as well as the power supply.
The computer is turned off, and unplugged from power. Computer case open. A can of compressed air is then used to clean the computer. (Plastic straw attached. Do Not make the small processor fan spin too fast. It is only designed to spin so fast. Spinning it faster than it is designed for, can lead to premature failure of the fan's bearings)
2a.Power supply failure. This is a multifaceted problem.
When foreign material clogs the cooling components inside the computer, (Fan/s, and processor heatsink), plus the power supply, (Fan, and heatsinks inside), the power supply has to put out more power.
Heat = Wasted Energy.
The more heat due to cooling capacity drop, the more power is required. The power supply can only keep up so long, and components inside eventually fail.
Generally it's Electrolytic Capacitors as they are the weakest link. Electrolytic paste inside the capacitor develops a gas, and breaks the seal stature of the capacitor. This leads to Electrolytic paste oozing out, and capacitor failure to follow.
A power supply with failing, or failed capacitors has a weak voltage rail, or more than one voltage rail.
There are three voltages produced by a personal computer power supply.
A.3.3 Volts
B.5 Volts
C.12 Volts
With a bad power rail the power supply has enough power to light lights, and spin fans, (Usually), but not enough power to turn the processor on.
1.ALL the lights require less than 1 Watt.
2.EACH fan requires 2 to 3 Watts.
3.A typical processor requires 55 to 125 Watts. Depends on what processor it is.
(You may even hear the harddrive spinning. Enough power to make the harddrive motor turn, but with no processor, there is nothing to make the Operating System on the harddrive work. Operating System example: Windows XP)
3a.Bad Electrolytic Capacitors on the motherboard.
As mentioned, Electrolytic Capacitors have Electrolytic paste inside. The paste develops a gas, (Hydrogen Gas), and pushes against a rubber seal on the bottom of the capacitor. It can also push against the top of the capacitor, and break the capacitor metal case open.
(Usually there is an X or lK on top of the capacitor. This shape is stamped into the thin metal on top. It spreads open when there is too much pressure, alleviating the pressure that has built up. Paste oozes out of here also)
Electrolytic Capacitors that surround the Processor are Voltage Regulators. The Processor must have a clean, steady, supply of voltage. The Processor has a very small tolerance range.
Too little it doesn't turn on. Too much, and it won't stay on.
This details out the visual signs of Electrolytic Capacitor failure,
http://www.capacitorlab.com/visible-failures/index.htm
Electrolytic Capacitors do not always show visible signs of failure. The paste can dry up inside, and no external failure is present.
If you see capacitor failure on the motherboard, then you automatically know what is wrong.
If you do not see failure of capacitors, then you may want to try using a known, good, power supply for a test.
Would appreciate 'hearing' what the outcome is.
Posted on Nov 20, 2009
    Problem Solver:
  • 15 Answers
Sometimes the monitor could of blown or your graphics card has gone bad. first check and see if your graphics card still works. go to another monitor and hook it up if it works then your monitor has blown if it doesn't work then you have a graphics card problem.
My sreen is not turning on only the green power one is on please help
1st Check the cable that hooks to the monitor side. Then check it at the computer side. By check I mean to disconnect it an rehook it up again so you no it is seated correctly. On some monitors its hard wired so you cant check the monitor side.
2nd if you have access to a second monitor (after checking the cables on your monitor first). Disconnect your current monitor and hook up the test monitor. If you continue to get no signal or picture then you have a defective video (graphics) card and you will need to replace it.
I hope this helps you out, if it does please give me a YES that I did assist you. Thank you.
Apr 10, 2011 | SVA-USA Computers & Internet
Hi, I turned my computer on and the screen was black and said, VGA INPUT - No input signal. Then says monitor going to sleep. I have turned it off and check all cables then turned back on, but it says the...
If the computer is turning on but the monitor is not getting a signal it sounds like your video card is bad. Fairly easy and inexpensive fix. If you could supply the make and model of your computer I could let you know the card you need and supply installation instructions.
Jan 01, 2011 | Computers & Internet
Monitor says check video signal,what is this?
Normaly this is due to no signal from your graphics card either on your motherboard or the added graphics card.
check that the card is installed correctly in its slot if its an additional card, if its a card that requires the extra power connector on the motherboard make sure its connected or it will not work properly.
Nov 06, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
''Out of range'' message on an older SVA monitor
This usually means the display resolution settings on your PC are set too high for the monitor to display the signal. Try lowering the resolution on your PC.
Mar 16, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
What does this mean?
It means that the monitor is not receiving a signal from the video card of the computer.
Possible failures are as follows:
1. The monitor input cable is no longer connecteds to the video casd.
2. The computer is not powering on
3. The video card has failed
4. The input Select option of the LCD is set wrong
Jan 27, 2009 | Gateway 300 C PC Desktop
Pc ready
There is a PC/DTV RGB input area with two audio jack inputs.  The input is a standard 15 pin PC jack. Hook it up to your PC video card input.  You can get the audio cable from Best Buy or a electronics store...split RCA on one end and the headphone jacks on the other to your PC. Then select the TV/Video source button on your remote until you see PC/DTV YPbPr screen appear.  It will search for the signal, find your PC and display the screen. You may have to go to MENUE on your remote to adjust the HDTV (1080i) frequency.... an option that only appears if there is something hooked up to the PC/DTV RGB signal input.
Nov 26, 2008 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
Sound problem SVA HD4208T VI PDP
Hi there, I think you are ecnountering a connection issue. If you are using the yellow red and white connection then make sure all these wires are connected to the corresponded input line. Your television has two composite input line. Make sure the red and the white wire is connected in the same input line as the video. For example, Connect the yellow red and white wire in Input1 ( all are in the same input line) http://www.sva-usa.com/4208.html If you have any addittional question, please feel free to contact me. Thanks, Mike
Nov 04, 2008 | SVA-USA HD4208 42 in. HD-Ready Plasma...
NO VIDEO SIGNAL
There is no input yet meaning, it is not yet properly connected to your computer. Check the cable connection. Please make sure that the computer or laptop is already turned on.
Oct 14, 2008 | NEC LT 260K Multimedia Projector
Sva vr 20 NO SIGNAL
Is it displaying NO SIGNAL on the screen? If it is and you use another source for video, such as RCA, Component or other inputs, then your TUNER is bad.
Jul 28, 2008 | SVA-USA VR-20 20 in. HD-Ready LCD...
SVA-USA VR 17S 17" Flat Panel LCD Monitor Logo
223 people viewed this question
Top SVA-USA Computers & Internet Experts
David Payne
David Payne
Are you a SVA-USA Computer and Internet Expert? Answer questions, earn points and help others
