Question about Nokia 1600 Cellular Phone
Does not detects SIM card
When I switch on my Cell phone it shows 'Insert SIM'. I've tried with some other sim cards also, and its showing the same message. Sometimes it works after a restart, but within few minutes, it shows the same message again. Please help me to solve this problem. I'll be very thankful if anybody provides me a good solution.
Thanking you.
First you see the set will waterlock are not and after you clean the simcard pin and after insert a sim and ON the set if it is the same problem you remove the sim card IC and after jumper it
Posted on Jan 21, 2008
Dear first you have to chk ur imei no. if it is seeing like????????????4 it then u can,t do anything this ph will restat within 10 sec. yush
Posted on Jan 19, 2008
Change yiur sim ic
Posted on Jan 15, 2008
You have to remove your simlock !!!
Posted on Jan 12, 2008
Thanks fr the message
Insert correct sim card
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Jul 29, 2012 | Sony Ericsson Walkman W810i Cellular Phone
Insert sim card diplays on the phone when i have already inserted sim the same sim card is working on other phones i tried with othr good sim cards the same problem exist
Clean the area of the SIM card detection pins and make sure that the card was inserted into the phone in the correct direction. If there is no detection with any card then the phone motherboard is defective but if the phone works with some card of a particular service provider then the phone is locked to that network-- in which case it will show and ask for unlocking code.
Sep 06, 2011 | Cell Phones
My phone shows "please insert
You could try to remove your sim card.
Install battery and turn on phone without sim card.
Use phone without sim card and do some operations.
This will check if you phone is working correctly.
Turn phone off and install sim card.
Made sure sim card is install correctly.
If this does not work, it could be the sim card is bad.
Jan 15, 2011 | Cell Phones
I am using this airtel sim from past 6 month,from 3 days its showing sim registration failed........but when i m switching it off it starts working again but its showing the same problem...
The SIM card may not be making proper electrical contact. Remove the SIM card, clean the contacts on the SIM card and on the cell phone with alcohol then replace the SIM card in the cell phone.
Dec 04, 2010 | Cell Phones
When i switch on the mobile it shows insert sim card
if you sim card is already in there try putting it back in there may be you inserted in the wrong way.
May 14, 2010 | Cell Phones
What should i do when 1100 cell shows insert sim
the pins that touch the sim card could be lose or the sim card might be bad, try pulling the pins on the phone up carefully just a little so its a little more thighter to inser the sim card, then try again, also try another sim card if it doesn't help.
Jun 11, 2009 | Nokia 1100
Insert sim card showing
Try your sim card to another phone, or try another sim to that phone just to eliminte the problem. Sim card are easily ruin by static discharge
Jan 03, 2009 | Motorola Mobility RAZR V3
Insert SIM Card message in nokia 6080 though SIM is inserted
May be its detecting your sim card properly. Check your sim card in another handset. Verify if its the propbelm with sim card not your handset.
Nov 26, 2008 | Nokia 6080 Cellular Phone
Nokia 1600 Cellular Phone Logo
117 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
