Question about Nokia 2600
My alarm function suddenly stopped working, not sure why? What can I do to fix it?
How do I use the buttons in this QHY watch?
Hopefully, this will help...
Lego Watches Manual Instruction:
There are 4 buttons on this lego watch case, Light button, Mode button, Stop button and Reset button, now I will show how to set the time easily!
1, Light Button: Press this button, the watch LCD light will display for 3-5 seconds;
2, How to use the stopwatches chronograph function?
Answer: When the lego watches in normal working condition, Press "Stop button" for 1 time, then the watch goes into the chronograph mode, then you can use "Stop button" and "Reset button" to operate this function.
3, How to set the alarm time?
Answer: When the lego watches in normal working condition, Press "Stop button" for 2 times, then the watch goes into the alarm mode, then you can use "Stop button" and "Reset button" to set the alarm time, also you can turn off or turn on the alarm function and chime on every hour function by the same operate.
4, How to set the right watch time, hour, minute, second, week, date, month, year?
Answer: When the lego watches in normal working condition, Press "Stop button" for 3 times, then the watch goes into the time setting mode, then you can use "Stop button" and "Reset button" to set the second, minute, hour, week, date, month and year.
This is all. So now please have a try to set your lego watches time!
Dec 06, 2014 | Watches
The four button remote with keyless entry and remote start on my 2001 buick lesabre has stoped working. The keyless and trunk and horn functions all still work fine just the remote start has quit working. ...
it maybe that the relay in the alarm module for the starting function has stopped working. your best bet would be an alarm shop where they can test the connection for function. have seen this issue several times. Does the engine turn over at all? if it does then the time for cranking may need to be adjusted.
Jan 11, 2014 | Buick Cars & Trucks
An alarm sound just started going off. I don't know how to make it stop.
my toshiba laptop is working but dont coming display so please help me
Jan 22, 2013 | Toshiba Computers & Internet
Alarm on my 2002 F250 started going off all of a sudden while parked and unlocked. the only way I could make it stop was disconnecting the batteries. what's wrong with my truck?
First, take the battery out of your key fob. All of them. Then hook the battery back up on the truck. If alarm doesn't go off, put battery in one fob. Check it out, all functions. Then check the other one. If alarm goes off when you hook truck battery back up, look for a shorted switch to whatever you alarm monitors and sets an immediate alarm when the switch is closed (or opened). If you still can't locate the reason for the alarm, consider replacing the alarm system, but not before you come back here and tell us what happened.
Sep 17, 2012 | Cars & Trucks
Camera suddenly will not record
This looks like a relay or micro switch has gone, camera needs looking at.
Jun 20, 2010 | Panasonic NV-DS65 Mini DV Digital...
The steam function has stopped working, I regularly descale, but it just stopped working all of a sudden. Any ideas how to fix it?
Try this, using a paper clip make sure that the end of the wand is not clogged. If not then open steam wand and then push the knob in, if that works then the valve stem needs to be replaced, if it doesn't, can you get hot water from the valve, if yes then the thermostat or the element on the steam booster boiler is damaged.
Sep 10, 2009 | Gaggia Titanium Espresso Machine
Alarm sound is not coming in my Nokia 1100
You may have you phone in the silent mode. To fix this you will need to go to profiles.
May 21, 2009 | Nokia 1100
I have an Athletic Works watch and can not turn off the alarm.
the mode button controls the different functions of the watch.  time, alarm time, stopwatch, timeset, alarmset, in a repeating cycle.  Make sure you are on the time function (seconds ticking and changing every second, but not flashing twice per second.  This is the normal mode that shows the time.
 A press of the lap/reset button (labeled) will show the alarm time, Unpress will show the time of day. Press again toshow the alarm time. Press and hold the lap/reset button will show the alarm time again, but it will hold there.  While holding this lap/reset button, press the start/stop button (labeled). This will turn on (or off) the alarm (tiny indicator).  Press this start/stop button repeatedly (while still holding the lap/reset button and you will see the indicator turning on and off with each press.  Stop this button pressing with the indicator OFF, let up on the lap/reset button, and the time will return to the screen.  The alarm will now be OFF.
Jan 24, 2009 | Casio Sea-Pathfinder SPF40-T Wrist Watch
Nokia 2600 Logo
47 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
