Question about Logitech Squeezebox Duet
Music doesn't stream from the PC to the receiver
I have a sqeezebox not a Duet. The receiver connects to the WIFI network and gets an IP address. The PC can ping the receiver. The music doesn't stream from the PC to the receiver.
    Guru:
  • 1,738 Answers
Check your firewall settings. You might have to tell your firewall to allow the sqeezebox to work.
Posted on Nov 20, 2009
My connection keep failing my password is correct.they are asking for my ip address where do i find that,
dont give anyone your ip adress,contact your internet provider to fix problem,if you are using someone elses wifi you will have that problem,use your own
Apr 26, 2015 | Amazon Fire TV Stick
How to get my ip address in my to use my wifi?
Hi once you connect wifi in your phone immediately an ip address will assigned for you by your ISP provider ....If you want to know your network ip address then visit sites like Ip-Details.com in your phone .Here they will display informations like ip location ,ISP address ,country and so on .
Jan 12, 2014 | Sony Ericsson Walkman E16i W8 Orange...
Wifi isn't working
First Step:
Let me know the status for the following:
Is it detecting any Wifi Network?
Have you check if the Wifi is disabled?
Have you check if the drivers are rightly installed?
If the above things are working correctly. Then you can connect to your wifi network only by entering the Password.
Second Step:
Also you should release the IP address if entered manually. To check IP of your machine- go to local area network, then click on Properties, check for TCP/IP settings. If the IP is set for Automatic then ping the IP of your Wifi Network in command prompt.
Let me know the details to assist you further.
Jan 02, 2014 | Microsoft Windows 7 Ultimate for PC
Yamaha receiver will not connect to Airplay
I have the same problem, it seems the airplay connection is easily lost, it never plays for longer than an hour without itunes losing the receiver, then i have to reset the receiver so that it appears in itunes again, very annoying. I spoke to Yamaha and they are not aware of any issues but clearly there is one. A quick workaround is to bring the receiver up in a browser by typing in its IP address, go to IP Address tab and simply apply without changing anything, this causes the receiver to initialize its network function as you will see the amp resetting and it will then appear in iTunes. This doesn't work through the units setup without changing settings and then changing them back again. Hopefully this is just a glitch that will Yamaha will fix in the next firmware update, I am running 1.14 update.
Sep 28, 2012 | Yamaha RX-V473 5.1 Channel Network AV...
How can I connect WiFi router to office network?
On your computer wireless card configuration, try changing the fixed IP address to the following -.
In the TCP/IP Protocol set Obtain an IP address automatically and set Obtain DNS server address automatically.
Jun 25, 2012 | D-Link DIR655 WiFi Router 4port switch...
My problem is my wifi?when my wifi connected other network but internet is not working?
Open a command prompt shell. type the following:
ipconfig release
press enter
ipconfig renew
now see what happens. Make sure that your ip address is not the same as your modems ip address. Always have your systems assign ip addresses automatically unless you are running a business that requires specific ip addresses for all the computers.
Jun 01, 2011 | Acer Aspire One PC Notebook
My wifi is connected but cant browes the internet
Wifi is a just mode of connectivity, does your wifi access point or router has connection to internet ?
if yes there is configuration issue most like gateway ip address
if no its obvious u should get a internet connection
wifi is nothing but a Wireless local area network
Feb 18, 2010 | Acer Aspire One Netbook 8.9" Notebook
The Wifi works (with my laptop) but my desktop
your laptop is able to go online using WI-FI.
desktop is connected to theb router but not able to go online. Do you see the port light on the router ?
check the Ip address on the computer. Check if there is any static IP address on the computer.
Click here for more information about the router and network
Jan 20, 2010 | Linksys WRT160N Wireless Router
My Samsung Blue Ray Disc player with a Samsung WIS09ABGN LAN adapter won't connect with my Apple Express WiFi and MacBook Pro. How do I make it work?
This disc player is get an IP address.
1) If connected to MacBook Pro with an ethernet cable, it will get an IP address something like 169.254.xx.xx but it will communicate with the laptop
2) If connected the Blu-ray disc player using Apple Express, you need to create an Ad-Hoc wireless network to share media and stream it.
**But ensure that the in-built firewall on a MAC is completely turned OFF or else it should be properly configured.
Jan 14, 2010 | Computers & Internet
How to connect to net via wire and wifi
I'm assuming Windows is the OS. After disconnecting from one access method but before connecting with another (modem to wifi or network wire, etc. the IP address on the notebook will likely not be acceptable to the new connection) open a DOS or Command "Box" or "Window" (go to Start --> Run --> type the word "cmd" or "command" without quotes and then click ok. At the prompt, (without the quotes) type: "ipconfig /release" (You can see all the variables for the ipconfig command by typing "ipconfig /?")
Establish a new connection via hardwire network or wifi and allow the PC obtain a new IP address as normal. If unable to access internet sites, you can try to forcing a new IP address by opening the DOS box again and type "ipconfig /renew" This should cause the machine to get a new IP address. The "ipconfig" commands will probably not force a modem connection to get a new IP address (I haven't run modems for a long time - so I'm not familiar with their procedure of obtaining an IP address)
Oct 09, 2009 | Computers & Internet
Logitech Squeezebox Duet Logo
171 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
