Denon AVR-1802 Receiver Logo
Posted on Jan 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WIRELESS SPEAKERS I'd like to replace the "wired" wall speakers of my DENON AVR 1802 with wireless. Is there a way to retain my current speakers? What are my options? Thank you for your time and advice.
Anonymous
Level 3:
  • Master 431 Answers
  • Posted on May 02, 2009
Anonymous
Master
Level 3:
Answers
431
Questions
0
Helped
147075
Points
1209
There are many kits at Maplins or Radio Shack that will do this for you , you can search for them at http://www.maplins.com or http://www.radioshack.com you may even be able to build one yourself from circuits available off the web .
Yes you will be able to use your own speakers and your options are basicaly down to what you can afford .... Regards Vortash
How can I connect wireless headphones to my denon AVR-1802
Hi Gordon, the wireless headphones, has a transmitter that is connected to the VCR 1 or VCR 2 outputs, or to the output of PreOut Front L R, in this case the sound level a to be modified by the general volume control of the Denon
I hope you can connect and enjoy your headphones
I sent you a link to download the user manual of your Denon, there on page 9 you will see the connections that I tell you
Greetings Franco Dosil
Hola Gordon, los auriculares inalambricos, tiene un transmisor que va conectado en las salidas VCR 1 o VCR 2, o a la salida de PreOut Front L R, en este caso el nivel de sonido a a estar modificado por el control de volumen general del Denon
Espero puedas conectar y disfrutar de tus auriculares
Te env?o un link para que descargues el manual de usuario de tu Denon, ah? en la pagina 9 veras las conexiones que te comento
Saludos Franco Dosil
https://data2.manualslib.com/pdf/4/383/38281-denon/avr1802882.pdf?b0cdee2d6d49fc2300788aa73a04efc3&take=binary
http://www.manualsbase.com/es/manual/downloadmanual/172578
Only red light is blinking on my denon avr 1508
It sounds like you overloaded the Denon avr with too much resistence from the speakers. Please check the total resistence of the speakers before you connect them all. Also check that the speakers or their wires are not shorted!
I moved and set up my AVR-1082. I hooked up the DVD and it showed the video through my Sony TV. I shut it off and hooked my speakers up. I think when I did that I must have hit something on the front of...
Reference to the manuals is highly recommended. All controls and indicators are explained. There may actually be a clue on the front panel. Resetting the microprocessor is a last gasp solution and may only bury you deeper because it will zero out all settings.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Denon-AVR-1802-Receivers-manual/id/363bh839/t/2/
Page 43
I have a Denon AVR 1802 and everything seems to be working properly, but I an mot getting any sound from the unit. When I perform a test tone, I get sound from all the speakers, but I can not get sound...
You could try a total reset of the system. To do so, Press Power while simultaneously pressing Speaker A and Speaker B. When the display flashes at about 1 sec intervals, release all buttons. Then select a desired source as normal and see if it plays as expected.
AVR-1802 5.1 Channels Receiver: My Denon AVR-1802 LED is flashing rapidly. I have...
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
I am trying to use my Denon AVR-1802 to connect my cable box to my TV. The problem is that I don't have any speakers connected to the 1802, I just want to route the cable box's video and audio to the TV...
connect your analog output from the cablebox to the receiver md/tape in. then connect your tv audio input to the md/tape out of the receiver. or you could just pass it straight from the box to the tv, bypassing the receiver altogether.
2answers
Going off by itself
Use a good ohmmeter and check each speakers and wires resistance at the ends you plug into the receiver. The impediance for the receiver is usually printed on a label on the back of the unit. It should be 4 or 8 ohms for each speaker connection. Also, the speakers are marked too. If you read LESS than what the speaker sticker states, 1 or more speakers in that box is shorted (burned out). Replace the speaker in the box that is shorted out by testing each speaker. Usually, the bass (largest) speaker is the 1 that burns out. Also, be sure that the receiver and speakers are the same impediance. The speaker can be higher in ohms than the receiver, BUT NEVER LOWER THAN THE RECEIVER.
Noise coming out of speakers connected to Denon AVR 1908
Check for nearby wireless devices and move them away. -If the audio output from the source device (i.e. DVD, CD player) is digital (i.e. PCM, DTS or Dolby Digital) you're on your own. I'd be willing to bet the output is analog (red and white RCA), because the "beeps" and "exploding sounds" you describe seem like it could be caused by interference. Try replacing the cables. Otherwise the issue is probably with your receiver.
1helpful
Zone 2 speakers will play from tuner but not from cd player
I have the denon as well two zones. 5 speakers inside and 2 speakers outside- can you play both zones at once? meaning can i watch tv in the 5 zone area inside. And play my IPOD in the outside speakers at the same time? PLEASE HELP! thx
2helpful
Digital audio cuts out.
I have same DD 5.1 tiny "bursts" problem with satellite HD channel. It is probably problem with Crystal DSP (German site): http://forum.digitalfernsehen.de/forum/showthread.php?t=89328&page=3
"Denon bietet Lösung für EX-Flag-Problem bei den Modellen AVR-1602 und AVR-1802 an
07.08.2002(cr)
Dass die Denon AV-Receiver AVR-1802 und AVR-1602 die mit einem DD 5.1EX-Flag versehenen Tonspur von "Atlantis" und dem "Herrn der Ringe"nicht abspielen können, ist ein spezifisches Problem von einerbestimmten Revision des in diesen Geräten verbauten Crystal DSPs.Dieser Chip wird u.a auch in einigen Kenwood- und Onkyo-Modelleneingesetzt.Da es von diesem Crystal Chip unterschiedliche verbauteRevisionen gibt, von denen aber nur eine bestimmte betroffen ist,werden die beiden Filme auf dem größten Teil der verkauften AV-Receiverohne Schwierigkeiten laufen.
Denon bietet nun für alle betroffenen Kunden, die ihr Gerät beimdeutschen autorisierten Fachhandel erworben haben, eine kostenloseModifikation an. Das Gerät muss beim entsprechenden Fachhändlerabgegeben werden mit dem Hinweis auf das Herr-der-Ringe- bzw.Atlantis-Problem.
Momentan steht nur eine begrenzte Anzahl an DSPs zur Verfügung - Denonhofft, dass kurzfristig ein größeres Kontingent eintrifft.
Denon bittet daher die Kunden freundlich um Verständnis, dass nichtalle betroffenen Geräte auf einmal und sofort umgerüstet werden können."
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
