Question about LG LRFD22850 Bottom Freezer Refrigerator French Door
Grrr noise that stops when doors are opened - LG LRFD22850 Bottom Freezer Refrigerator French Door
  • LG Master
  • 43,501 Answers
The noise you are hearing is probably the fan blades hitting some ice build up. Un plug your refrigerator for over night and it will defrost melting the ice. If it still makes the noise after that then the fan motor is going bad, you will need to replace it soon. The reason that it stops when you open the door is because the power is cut off to the fan when you open the door.
Posted on Nov 20, 2009
Samsung refrigerator loud noise
if the fan is still running when you open the door , the I would be leaving that idea as a last resort
try this
get 2 taper door chocks and put one either side at the back of the fridge
push the cabinet sideways and slip one chock in a bit then do the other side
many noises are from the bottom plate that the compressor is mounted on from tapping on the floor and lifting it a bit stops the noise
the same as when you open the door the pressure on that plate is removed and so it stops hitting the floor
Nov 04, 2015 | Samsung RS261MDWP - 26 cu. ft. Side by...
Why does the refridgerator sounds like a jackhammer?
On some models when you open the door the door switch also turns off the evaporator blower motor. If the fan is hitting something while the door is closed you will hera the noise, and it will stop when you open the door.
Aug 14, 2014 | Samsung Refrigerators
My Leisure HJA6100 icemaking unit is making a terrible noise, which stops when I open the freezer door. It's just a year old, what could be causing this noise?
Your evaporator fan motor would be the cause of your noise. Yes, it can be repaired, just need to replace the fan motor. The noise stops when you open the door because the fan motor turns off when the door is open.
Mar 13, 2013 | Refrigerators
I have a Samsung Waltz double door fridge, i had a noise from the fan for a few days and now the noise has gone so the fan has stopped and the fridge is not cooling as normal, freezer is working ok. This...
I have a Samsung Waltz double door fridge, i had a noise from the fan for a few days and now the noise has gone so the fan has stopped and the fridge is not cooling as normal, freezer is working ok. This fan would switch off when the door was opened
Sep 14, 2010 | Samsung Refrigerators
Buzzing sound
If noise stops when you open the door, you may have a noisy fan (or could have ice build up, causing fan blade to hit ice and cause noise). I gather it is a frost-free model ie has a fan in the freezer compartment. If noise is caused by fan hitting ice build up, you may have a problem with the auto defrost system, as you should not get ice build up in a frost free.
Noise stops when you open door because fan turns off when door is opened.
Aug 09, 2009 | LG Refrigerators
Loud whirring noise that stops when freezer door is open.
It is most likely your circulation fan in the freezer. Normally the fan stops when you open the door. It is a normal operation. Check to make sure that the fan is not blocked by frozen items or that the fan doesn't have an ice build up. On some models the fans stops when you open the door and starts a few minutes later after you close the door.
Mar 15, 2009 | GE Profile PSW26P Stainless Steel Side by...
LG LRFD22850 Bottom Freezer Refrigerator French Door Logo
835 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
