Question about Hitachi 53SDX01B 53" Rear Projection Television
The screen has a blue shadow across the whole screen and there is a curve across the top and bottom of the screen as well. Is this something that can be fixed??? Please help.
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
Go into the customer menu with the Hitachi remote and select convergence--if red or blue are skewed and will not move in some direction or the picture looks 3D one of the two convergence chips this set uses is bad.
If it is 53SDX01B THEY WILL BE (as you look from the back of the set) towards the far right side on either one large or two smaller heat sinks with fins.
They will be black in color--about 1 1/2 wide by 1 1/2 tall and will have either the STK-392-110 OR THE STK-392-150 PRINTED ON THEM IN WHITE LETTERS.
Both chips were used----the 150 chip is a longer lasting version of the 110 chip.
To the left of them you will see about 12 resistors--take a good look and if any are discolored even slightly in the middle you can be sure of what has happened.
Most of the time only both the chips need to be replaced--the resistors around them are easy to test like testing a fuse.
Shops are going to get 300 or more for this kind of repair--considering you can buy the chips for under 15 dollars for a pair on Ebay (where I buy mine) if you or someone you know can solder and do it--you can save the set and a lot of money.
The reason the chips fail is simple--the back of them is metal and a white grease is applied to them to quickly transfer heat to the metal they are bolted to, after some years from the heat the grease dries out and one of the chips overheats and fails.
If you have questions or need advice, let me know--I am here to help people.
Thank you for using Fixya!
If this information has helped you, rate this solution as I do this here for FREE.
SD TECH
Posted on Nov 20, 2009
    Brigadier General:
  • 4,090 Answers
All faults can be fixed But it depends how much money you want to part with. This problem is on the convergence boiard and is not a quick fix. Manufacturers recommendations is that all three boards should be replaced at the same time. The problem may be on the sustain board but the cause of the problem can be on one of the other two. Unlike PC's playing board swap jockey is not tolrtayed in HI end Tv;s They are much more complex and require knowledge of Voltage output special tools to measure component output between each board and the ability to produce a cross hatch display to correctly aklign the "guns" when the convergence boards are fitted.
NOT A DIY job. My advice is call in a service person and save yourself from doing the replacement more than once in the month. Many on here fall afoul of the system by believing all they need to do is dwap the boards. Not so! They end up dpernding 3-4 times the cost of having it done correctly the first time by a professional.
If it has warranty ot extended warranty.. claim now
Estimated cost parts and labour $5-600
Please rate my help++++Thanks for using FIXYA
  • 273 Answers
You have a convergence circuit failing
yes it can be repaired and as a rule cost 280 to 320 and that also will vary depending on where you live
SONY PROJECTION TV MODEL # KP-51WS510.
If the entire screen is curved, and it is not taking the whole screen, then you have a vertical deflection problem.
If the colors are double and do not match, with lines of different colors around pictures , then you have a convergence problem, often caused by a faulty convergence board.
The curving effect can be a side effect of bad convergence, or you may have both problems at once.
Unless you are a TV repairer yourself, better calling technical support. Usually you can ring the number listed on the owner manual.
Jul 21, 2009 | RCA P52920BL 52" Rear Projection...
Red and blue streaks across the screen top and bottom
The Convergence Amp IC's are bad. You should call a good TV Tech for this repair.
Jul 11, 2009 | Mitsubishi WS-65809 65" Rear Projection...
3 year old rca rear projection just started going blurry. green blue and red line across the top of screen. objects have shadow.
Focus and screen control box / remove front bottom panel there you will find it / it has 3 controls on top 3 on bottom top are focus for RGB tubes bottom controls adjust screen drives for RGB.
Jan 25, 2009 | RCA D52W23 52" HDTV CRT TV
Green cruve line
Good Day;
Suspect Convergence IC's STK4274, part Number 2003191. Replace all three IK04(red), IK05(green), IK06(blue).
Good Luck, big IRISH.
Aug 30, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Pcture problem
Replace both STK392-110 convergence IC's with Toshiba or
Sanyo brand...............no cheap junk !!.............T.
Aug 04, 2008 | Toshiba 43H71 43" Rear Projection...
RCA 56 inch hdwidescreen
Did you use the Automatica Convergence to try and straighten it out? If that does not help, you can manually adjust the convergence.
Jul 12, 2008 | RCA HD56W58 56" TV
Blue shadow
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 25, 2007 | Toshiba 53AX61 53" Rear Projection...
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Hitachi 53SDX01B 53" Rear Projection Television Logo
378 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
