Question about Netopia (3342) Modem
Problem with my Arris Comcast cable modem.
Problem with my Arris Comcast modem. It is a TM602G, at random times the box will restart itself. Sometimes it restarts itself 3 times at once. I would like some help, I called comcast but they said it is fine.
I just had a tech out yesterday regarding this problem on a TM402 - restarts under high network saturation (big uploads or downloads). According to the tech, this is a know issue. Comcast upgraded their network to support multiple carriers (called channel bonding) dynamically. Due to this upgrade, when your modem is demanding high bandwidth for large downloads, essentially, it requests an additional carrier (or channel)...when that request is initiated, the modem's hardware (and firmware) can't connect to more than one channel at a time, therefore, it "gets confused" and restarts itself to attempt to fix the problem. I upgraded to the TM602, and the problem is still there. This is because the channel bonding feature requires a Docsis 3.0 capable modem. The Arris TM702 is the first in the Arris line to offer docsis 3.0. I called Comcast and they are upgrading me to the Arris TM702 (which is a 50M down/10M up service, btw) for an additional $30/month - well worth it for the stability which I require.
As far as Comcast saying that it's fine, call them back with the information I provided, and ask to get you to a tech who can better service your needs...unfortunately, the "tier 1" techs don't have a clue.
Posted on Dec 07, 2009
The restarting of your modem is that the modem is bad or the power supply is bad call comcast have them send you a new one . Broadband will not reset the unit
Dana
Posted on Nov 21, 2009
I need the value for the network address property.
http://www.speedguide.net/routers/arris-touchstone-tm602g-voip-gateway-557
Oct 17, 2013 | Arris Touchstone Telephony Cable Modem...
I have an arris tm602g. What is the IP address to access modem 192.????
Try 192.168.0.1 or 192.168.100.1. Make sure that your pc is connected directly to the Arris TM602G modem and not on a router.
Aug 28, 2011 | Arris Computers & Internet
Comcast installed Arris TM602G/CT Modem yesterday. Attempted to link modem to MAC AIRPORT wireless router. Have net access with my PC cabled to modem. If I hook the modem to the AIRPORT, the PC indicates...
first its a mac so no wonder its broken second its not your modem it would be your router settings. you may want to restore your device back to its defualts then try again.
Apr 13, 2011 | Computers & Internet
Do I need a router in addition to the Arris tm602g ct provided by Comcast?
Yes, you will need a router the Touchstone® TM602G is only a modem. I recommend a Cisco-Linksys (#1 recommended router brand) like the E1000 Wireless- N Router (Walmart $59.00) with up to 300 Mbps data transfer rates; WPA/WPA2 (personal and enterprise) and SPI firewall protection; four 10/100 Mbps Ethernet ports. It will meet all your needs.
Thanks for choosing FixYa, If you find this helpful please vote and leave a comment.
Oct 14, 2010 | Computers & Internet
I have an Arris modem from Comcast that gives me phone and internet service. Prior to going to Comcast for telephony I used a regular, off the shelf, modem and I could connect to my Direct TV sat box via...
comcast use 10.0.0.1 for ip address, I think
check direct tv box for internet settings for it's ip address should 10.0.0.2 maybe call directv maybe they could further.
May 14, 2017 | Arris Touchstone 450a (CM450) Modem
How do I access my Arris TM602G modem. I want to
Have a look on the Arris website. Go Here:
http://www.arrisi.com/solution/docsis-cable-modem.html
Oct 31, 2009 | Computers & Internet
I am looking for usb driver for arris rndis modem model number is tm602g
http://www.drivers-fix.net/arris.php. Comcast sometimes has drivers for this device. Use the ethernet connection if you can cause Arris EMTA's usb outputs **** unless your trying to do both which is what I think your doing. If your computer only has a USB connection look for adaptors
Oct 11, 2009 | Arris Touchstone 450a (CM450) Modem
Can't install linksys wrt54g2 router with arris tm602g modem
I've tried network magic and everything thing else and I still can't get it to work.
Sep 28, 2009 | Linksys Wireless-G WRT54GS Router...
I have an arris tm602gct and cannot connect thru my netgear
Can you connect if you are directly wired into the router?
You may want to try using a ball point pen and pressing the reset button on the back of the arris. Let it reboot and try again.
Some netgear routers come with the wireless disabled out of the box, so you need to be hard wired when you run the CD or if you try to connect through your browser 192.168.1.1
Feb 15, 2009 | Arris Touchstone 450a (CM450) Modem
Arris cable modem
try shutting of your computer then shutting off the modem, the modems have batteries you might have to remove them theres usally a panel on the bottom, in the back you should have a wire for comcast cable and an ethernet chord telephone too if you have everything. also your modem could be broken, i had the same problem
Jun 06, 2008 | Arris Touchstone 450a (CM450) Modem
Netopia (3342) Modem Logo
2,347 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
