Question about Bernina Bernette 75
My Bernina 730 record can only run the zig-zag stitch. The tech said the motor was "weak". Will replacing the brushes in the motor fix the stitch problem?
Sewing machines needs full service now and then (every 10 years will often do). The motor on the 730 series is actually as powerful as they get on domestic machines, and handles just about everything that fits under the pressure foot. Only if the machine has been used a lot over the years are the brushes worn down, but it might need new grease not matter how little it has been used.
However, the stitch applications can sort of gum or clog up if the machine has not been used for ages. Take a look in the manual and oil ever point suggested every time you take out the machine. Try them now and then on slow speed, that might get every function to run smoothly again.
This is as good a machine as any out there, favorably compared to any new machine under 500£. It sews perfect stitches on just about any material, and is well worth a full professional service (At a shop they will always recommend a new machine they want to sell you). All kinds of pressure feet and accessories are available in regular sewing shops and online.
Check with different shops for price on full service. This is a great machine what ever they tell you.
Posted on Jan 09, 2010
    Problem Solver:
  • 4 Answers
Find an old back yard tech who can fix it for you cheaper than your normal techs who only want the money. DO NOT GET RID OF YOUR 730. I maybe could recommend someone if i knew what area u r in Cheers
Posted on Nov 20, 2009
I have a bernina 730 and it does a fabulous straight stitch but it won't do zig zag or any ornamental stitches
Assuming this is the older mechanical Bernina 730 Record (not the new computerized model)...Sounds like your machine is seized due to dried oil.
Wheel on right side that controls the needle up and down is very tight...
Jan 09, 2017 | Bernina Sewing Machines
I cant get my stitch Width Zig zag knob to turn om my bernina record 930. Any one have this problem?
Most likely because your machine has not been serviced (oiled & cleaned) in a long time and the old oil has turned to glue and seized. This is probably the most common problem with mechanical sewing machines. A mechanical sewing machine should be regularly maintained..ie every 40 hours of sewing use or at least every six months when not in use. You may want to take it to a Bernina service technician. Ask for a bottle of Bernina oil for CB hook machines and ask if they will show you how to oil it.
My machine Bernina 830 does not run
Bernina 830 won zig zag won buttonhole no decorative stitch
Bernina 930 Record oiling diagram
Questions Answers for Bernina seized Sewing Machines
Aug 14, 2016 | Bernina Sewing Machines
Can you use twin needles on bernina 1080
I have a Bernina 930 Record that will take twin (even triple) needles, so I don't know why your 1080 wouldn't. Just be sure your machine does not have the straight stitch plate on it, that your presser foot can accommodate zig-zag stitch, and that you carefully adjust any zig-zag stitch width so the needles do not hit the presser foot or stitch plate. I'd suggest installing the double needle and then carefully hand rotate the handwheel to see if the needles will hit anything. If you can make a full rotation of the handwheel without anything hitting, then slowly try it with the motor engaged.
Feb 23, 2015 | Bernina Sewing Machines
Bernina 730
try changing the needle--one for the fabric being sewed
also the zig zag could have a worn or damaged gear or cam
or there could be a timing problem.
Apr 11, 2014 | Sewing Machines
Bernina Record 730 hand wheel stuck
OK OBRIGADO VOU LIMPAR A MAQUINA PODE SER POEIRA PORQUE FICOU ALGUNS MESES SEM FUNCIONAR.
aGRADECIA SE ELA FUNCIONASSE TENHO MUITOS TRABALHOS POR FAZER SOMENTE O ERROR C14A3 ESTA A BARRAR-ME E NAO ACEITA MAIS NADA A FUNCIONAR
Feb 06, 2014 | Bernina Sewing Machines
Have a Bernnina record 530. The zigzag will not work, just straight stitch on any width setting. all the other fancy stitches(1-12) work fine.
the cam or gear of the zig zag could be worn or damaged,, having the machine checked,, would tell you for sure what wrong with the zig zag..
Sep 28, 2013 | Bernina Sewing Machines
Bernette 75 won't Zig-Zag
Is there a stitch width setting and has to be set to a number greater than zero?
May 14, 2010 | Bernina Bernette 75
Zig Zag Stitch not working
THis problem occurred as I was sewing on Neoprene. I was using Gutterman all-purpose thread and a size 80 needle. Tried switching to a size 70, then to size 90. Still unable to zig zag. After inserting a test sample of cotton, the zig zag worked perfectly, so I knew it was not a mecahnical problem. I switched needles again. This time to size 90 for stretch fabric. Voila! Problem solved.
May 23, 2009 | Bernina Virtuosa 150
Sewing Machines Logo
669 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
