Question about Xerox Phaser 8400 Laser Printer
What does fault code 37,016.43 cover? - Xerox Phaser 8400 Laser Printer
    Guru:
  • 110 Answers
The expected power from the supply
is not being drawn. This error may
be caused by a power supply that is
faulty or shorted by some other 50
V device.
Try disconnecting one connector from the power supply at a time. This will determine if another device is causing the error like a print head or the drum heater ect. After disconneting any connector turn it on to see if you still get the same fault. If after turning it on and off and nothing happens then finally change the power supply.
Posted on Nov 20, 2009
Xerox error code
There is a bulletin from Xerox that helps to troubleshoot and identify the error. If you provide me your e-mail address I will send it to you. Please e-mail me at sales@iteminc.com.
Sep 16, 2014 | Xerox Phaser 8560DN Laser Printer
Xerox 8560 fault 37,016,43:60822
37,016.43: PEST 50 V power supply test.
Sep 08, 2014 | Xerox Phaser 8560MFP Laser Printer
Vauxhall corsa fault codews
what are you asking.?
the FSM covers each and is 10 pages long.
do you want me to type that?
its set of pages telling the mech, how the monitors run and why they fail and tests to do to isolate the cause.
all cars, all FSM cover this.
if you just want an idea, just google it.
with car MAKERS name in front, due to them being manufactors specifice codes. eg dont read BMW codes.
May 10, 2014 | 2001 Ford Focus
Soft top fault
This needs to go to the dealer to have the systems control module scanned for fault codes during an "active" test cycle.
Jul 26, 2012 | 1996 Saab 900
Check engine light just came on 1993 toy camry
First you need to find out what the fault code is that is making the check engine light come on. To do this, locate the diagnostic connector under the hood. It will be a black rectangular connector approx 50mm X 25mm with Diagnostic written on the cover. Open the cover and on the inside of the cover will be a diagram of the connections and their different labels. Locate pins labelled TE1 and E1. Switch on the ignition switch without starting the engine and with a small jumper wire bridge between pin TE1 and pin E1. Observe the check engine light on the dash and you will notice that it will be flashing. Read the diagnosis code as indicated by the number of flashes that this light makes. Each code will be displayed by first blinking the first digit of the code, then a pause and blink the second digit of the code. For example, Code 52 (knock sensor signal) will flash 5 times, pause and then flash 2 times, then a longer pause before it goes onto the next fault code if there is another one. Once it has gone through all the stored fault codes it will go through the sequence again starting at the first fault code again. Due to the many different fault codes that can be obtained it would be better to post another question for the fault code obtained. Good luck!
Jan 06, 2010 | 1993 Toyota Camry V6
Phaser 8400 error code 37,016,43:7052
From the service manual:
37,016.4x - PEST_FAULT_HM_CLUTCH_DISCONNECT
PEST - Head maintenance clutch disconnect. The head maintenance clutch is not
drawing the expected power from the supply.
1. Run the Head Maintenance Clutch test.
2. Check the Head Maintenance Clutch wiring.
3. Disconnect the Wave Amp signal cable from the left
side of the Electronics Module. If the error code
changes, replace the Wave Amp.
4. Replace the head maintenance clutch.
I have the full service manual available should you need it. Thanks and please take a moment to rate this solution as fixya.
Feb 22, 2009 | Xerox Phaser 8400 Laser Printer
Error b in mp 1600
Do you mean you have a level 'B' fault code? Level 'B' is reset by turning the MAIN power switch off. Not just the reddish switch behind the clearish little cover. Look on the side for the little BLACK switch and shut it off there. Leave it off for about 1 min and then turn that little switch back on. This will reset the code. If the code continues, there will be a SC with numbers --- this is the fault code that tells us where the problem is. Now with that being said, do you mean that there is a JAM in AREA 'B' ? If so, open the front cover and there should be directions to locate area 'B'. Open the covers/ doors and remove the jam, close the doors/ covers and it should be cleared.
Dec 19, 2008 | Ricoh Aficio MP1600SPF Copier
What is error "Fault 37,016,43:30997
AC power supplied by power sources such as uninterruptible power supplies (UPS’s) or DC-to-AC inverter systems, may not supply enough current to properly power up the printer. In these cases, the printer may report printhead jet-stack or reservoir heater disconnect, drum heater, or preheater errors (37,002.47 thru 37,012.48). Verify the AC power source prior to troubleshooting a printer exhibiting any of these errors.
(Plug printer directly into a wall outlet)
If this doesn't solve the problem you will need the preheater replaced.
Aug 04, 2008 | Xerox Phaser 8400 Laser Printer
Xerox phaser 8400 fault 37,016,43:24800 ????
Sadly that is not good.That normally is one of the heaters in the print head has failed not warming up enough to allow the ink to remain liquid. It frequently is the result of a failure of the electronics module, none of the most likely problems is a cheap fix. I will give you the list of most probable causes.
Wish I had a more hopeful answer.
PARTS:Parts are listed in the order of highest probability for repair.
NUMBER QTY DESCRIPTION
119649580 1 *ELECTRONICS MODULE (STRIPPED)
671529180 1 I/O BOARD
650430300 1 *PRINTHEAD ASSEMBLY
The electronics module. Listed as stripped, means it comes without the ram and nvm boards. When that fails it is a portion of that module that supplies the heater voltage. I think its a 50 volt source off hand.
Apr 22, 2008 | Xerox Phaser 8500/DN Printer
Fisher & Paykel washer IW712: fault code 105
Fault codes sheet is located under the dryer control cover.
Fault Code 105 Communications Error Time Out - I&A
Communications failure between the sensor module and display module. (loose wire). 1).Visually check the contacts on the RAST (edge) connector at each end on the harness between the sensor and the display module. 2). Replace sensor module and/or display module and/or harness.
Nov 09, 2007 | Washing Machines
Xerox Phaser 8400 Laser Printer Logo
299 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
