Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi dlp projection tv timer flashing green unable to reset TV
Call Mitsubishi, 18003322119. They seem to know this is a ubiquitous problem with these sets, and seem willing to cover parts (all new electrical chasis), but not labor. Have to have an authorized repair tech look, verify problem, fax info to Mitsubishi, then will send in chassis for rebuilt one. Cost from what I've seen runs $300-400 in labor. Stinks you have to pay any, since Mitsubishi used bad capacitors in making the T.V. in the first place.
Posted on Nov 23, 2009
Testimonial: "If you had not suggested calling Mitsubishi I would not be receiving a brand new TV from them. Thank you very much"
  • 273 Answers
The set has some parts that have failed in the dm module and will have to be repaired to get the set to function again
there will most likely be other areas that will need new caps also est 550.00 to 700.00
Posted on Nov 20, 2009
I have a Mitsubishi WD-52725 DLP TV and green light (timer) is rapidly blinking after a power outage and set will not turn on. The bulb was replaced a month ago and it has worked fine since. Now it will...
Hello
make a System Reset process. To do this;
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
OK.
Apr 23, 2011 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi DLP 60" - power
Unplug the television, let it sit for an hour an try to plug it back in. That should resolve the problem. if it still flashes green after you do this, use the "reset" button again. Let me know if that works.
Nov 23, 2010 | Televison & Video
Mitsubishi WD-62627 62" DLP TV
Try this:
1) turn on the TV
2) from the remote control press MENU 2,4,7,0 then ENTER
3) tv will state on screen that it is INITIALIZING
4) when done press the front reset button.
5) should be good to go!
Oct 26, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I have a mitsubishi tv model # WD 52525 DLP and the timer light just keeps flashing and the TV will not go on
i have a mitsubishi ws-55859 rear projection tv. the green timer light just keeps flashing and the tv will not turn on.
Aug 09, 2009 | Televison & Video
Flashing Green "Timer" light on my Mitsubishi WD-62525
My Sony had the same problem. Unplug from the wall for 36 hours and it should solve the problem
Mar 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
My tv won't turn on, the timer keeps flashing
http://www.jyerdon.com/tv/
If it`s a 65513 mitsu, this will fix the flashing green light, most of the time, e-mail me with any questions, good luck
buranc@bellsouth.net
Dec 28, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi tv
ok.
#1. replaced capacitors on power board. DM board FMT board .
# 2 on power board you need to chek caps. 3300mf x 35 v.QTY 2.
# 3 12 capacitor 1000mf x 16 v.
If caps 1000mf x 16 v . looked good. replaced anyway......
Sep 14, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Blinking Green Light on Mitsubishi DLP 52525
the dlp will most likely need a qualified mits repair center to take over for you. repairing that set is pretty involved. and the parts you would need are not available to the public.
on your 48" CRT projection check the DM module for 4 vented 1000mf 16v capacitors. replacement should get you tv working great
Feb 20, 2008 | Mitsubishi WS-48513 48" Rear Projection...
Constant green blinking timer light
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
Suspect the DM PCB part # 934C116002
Jan 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
227 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
