Question about Kenmore Refrigerators
I have a kenmore side by side refrigerator. the
I have a kenmore side by side refrigerator. the freezer section gets frosted up and ice blocks the vents. i wanted to know how to test the defrost cycle. the controls are all electronic so i can't manually turn the defrost timer into defrost mode to check to see if the heater turns on and to check if the defrost bi-metal thermostat is faulty or the timer itself is faulty. can i have some assistance with that matter? thank you. also could you tell me where i could get a repair manual for electronic control model refrigerators and freezers? thanks.
    President:
  • 744 Answers
Hi, Is there ice/frost build up at the rear inside of the freezer?. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself.
This is going to be one of three problems with your refrigerator, 1st thing to do is remove shelf’s and panel in the back of the Freezer. You may see ice build up on the evaporator, don't worry get a hair dryer and melt the ice.
Next locate the wires for the defrost heater and using a multi-meter/ohms meter test the heater for continuity (it should read infinite) if the defrost heater is bad replace it.
This is what a typical defrost heater looks like:
If the heater is good test the defrost thermostat. This should normally be done when the evaporator is still covered with ice since it will only activate at 40f - 50f depending on the thermostat. When tested with the ohms meter at below 40f it will read infinite. It is normally clipped to the upper right of the evaporator and look something like this:
4462625.jpg The next possible problem could be the defrost timer. If you have tested the heater and thermostat and they have tested good next find the defrost timer, If your refrigerator has a mechanical one it will either be located inside the control panel in the fridge or behind the panel below the doors. Once you have located it advance the dial until you hear a click. This will initiate the defrost cycle. If your heater begins to get hot this will tell you that your timer has stalled and needs to be replaced. A typicali have a kenmore side by side refrigerator. the - f218caf.jpg timer looks like this:
f218caf.jpg If your refrigerator has a digital defrost timer you should locate the tech sheet. Normally you can find this behind the panel under the doors. It will tell you how to initiate a manual defrost cycle. As before if the heater gets hot you will have to replace the mother board normally located behind a panel at the rear of your refrigerator.
If your fridge is warm and there is no build up of frost/ice on the back panel inside the freezer then you problem is most likely going to be the evaporator fan, have you heard the fan running in the past few hours? if you are not sure pull the panel out to where you can see fan and watch it over the space of an hour to see if it turns. If you don’i have a kenmore side by side refrigerator. the - a4183d8.pngrning replace the motor. This is what a typical evaporator fan looks like:
a4183d8.png Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck & thanks for using Fixya! Mike
Posted on Nov 20, 2009
Why does The freezer side stays cold but the refrigerator side gets warm
Your problem is more than likely a defrost issue. There is ice building up in the freezer coils and when it gets blocked with ice the cold air cant blow into the fresh food section. When you shut it off the ice melts and it gets cold again for a few days. remove the freezer back panel and check the defrost heater and defrost thermostat. if they check OK then check the defrost timer. It is best to replace all three components at the same time. This way you will be starting out with new components rather than one failing then the other.
Jul 16, 2014 | Kenmore Side by Side Refrigerator
Freezer gets cold, but nor refrigerator section.
A lot of times when a freezer works but the refrig. section is warm its a problem of it not automatically defrosting so its builds up frost in the freezer so much so it restricts air flow into the fresh food section because the freezer coil is one big block of frost and no air can flow through it. THis tip i wrote covers the components of the defrost system and how to check them.
http://www.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
GENE
Sep 09, 2011 | Kenmore Side by Side Refrigerator
The freezer works, but the ice cube maker gets frosted up, and the refrigerator barely gets cool
Make sure the fan is running in the fzr the fridge side steals air from the fzr via a small duct to the fridge. If there is a lot of frost you may have an ice block on the cooling coils in the fzr usually behind a back panel. If you have an ice block your defrost timer,heating element, defrost limit one of these could be bad. Let me know if you find an ice block or a lot of frost. good luck
Aug 16, 2010 | Kenmore 50522 / 50524 Side by Side...
Kenmore refrigerator,bottom stoped cooling.freezer works just a little bit.8 years old.bought new.
More than likely your freezer has a ice block in it it will have a lot of frost on the inside of the freezer. This ice block is usually caused by a bad timer or a bad heating element in the freezer. The timer kicks in a timed cycle to turn on the heating element and a hi heat limit keeps it from getting to hot just hot enough to melt any frost and ice. (thats how we have frost free fridges now)
Aug 12, 2010 | Kenmore Refrigerators
The upper portion of the freezer turns off, causing the ice to melt. And the cooler side bottom drawer turns into a freezer. I can't figure out what's going on.
You have a frost blocked evaporator. Translation: The cooling coils, located behind the back wall inside the freezer section, have plugged up with frost (usually caused by a burnt out defrost heater, located at the bottom of these coils) which prevents the cold air from circulating inside the freezer, and into the top of the fresh foods section. At the same time, this blocked air flow allows very cold air at the bottom of the freezer section to migrate back into the bottom of the fresh foods section, and thus freeze item in the bottom bins of the refrigerator. Unload the freezer, take the shelves out and remove the back panel. Melt the frost with a hair blower, and change out the heater at the bottom.
Jul 08, 2010 | GE GSS25SGMBS Side by Side Refrigerator
22 cf kenmore side by side not very cold. Large ice block formed behind backplate on upper coils. thick frost on lower coils and on inside back of freezer section. Still making ice and fan blowing,...
also perhaps the defrost timer is bad, not allowing the defrost heater to come on and melt the ice as it should? Or the defrost heater itself could be bad -
Oct 07, 2017 | Kenmore 22.0 cu. ft. Side-By-Side...
Kenmore 106.536323000 S/S: Not Cooling Enough
YOU HAVE A DEFROST PROBLEM. FROST HAS BUILT UP SOMEWHERE AND THE FAN CAN'T BLOW PAST THE BLOCKAGE. OR ONLY A SMALL SECTION OF YOUR COILS IN THE FREEZER ARE COOLING DUE TO A CLOGGED FILTER OR BAD COMPRESSOR. PULL THE BACK COVER FROM INSIDE THE FREEZER AND LOOK AT THE COILS. THEY SHOULD HAVE A LIGHT FROST AVER THE ENTIRE COIL.IF IT IS A BIG BLOCK OF ICE YOU HAVE A DEFROST PROBLEM.
Oct 28, 2009 | Kenmore 53642 / 53644 Side by Side...
Freezer warm, can hear fan, water coming out
no frost in the back panel of freezer? did this happen all of a sudden? compressor hot? condensor coils dirty?
Jun 26, 2009 | Kenmore 26.0 cu. ft. Side-By-Side...
Freezer works frige dont
check for frost in freezer section. If frosted up your air flow is being blocked. Must thaw and determine why it is not defrosting
Jan 05, 2008 | Kenmore 56539 / 56532 / 5653 / 656534 Side...
Refrigerators Logo
164 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
