Question about Panasonic PT-47WX49 47" Rear Projection Television
Tv makes a click sound and the picture becomes snowy
What would cause a GE 60GW948 have a very snowy, and now No picture screen
when you say gone out---no light on screen or brightness or what? The snowy picture can be got around in most cases.
Jun 14, 2012 | GE 31GT660 TV
Picture is really snowy in the bedroom and we have another lg tv in the family room and it has a great picture on it they are both hooked up to the same dish network receiver but it just started like 4 or...
Hello, I hope this was resolved, but if not, here are some steps to run through. It sounds like the tv that is showing only snow is on an incorrect channel and/or input. The correct channel is different depending on what tv it is that is snowy. If TV2 is snowy where there is no receiver box, that tv needs to be on channel 60 or 73. If TV1 is snowy, where the receiver is, then you will want to make sure that the tv is on either channel 3 or 4, and it usually needs to be on an input as well. Anything ranging from video1 to HDMI3. Also, make sure that you have a blue, green, and yellow light on the front of the receiver box. If none of these steps help, unplug the receiver from the power source for about 10 seconds. If this still does not help, or you have any other questions, please e-mail me at becki.barned@dishnetwork.com.
Becki Barned
DISH Network Customer Service
Nov 21, 2010 | LG 32LD550 32 in. LCD HDTV
Power supplies
tv comes on. screen is black. then makes that snowy noise like when you lose your picture, but the picture never came on. then it will shut itself off after making several clicking sounds. sometimes it will come on after a while. is it time to get a tv?
Jun 29, 2010 | Daewoo DSJ-5510CRA 55" Rear Projection...
Snowy picture playning dvd
Sound like a heat issue. Clean it out with compressed air make sure it is in an area that jests lots of air (not in a cabinet or entertainment center shelf), Make sure it can breath. If that dont help i would have it cheked out or return for warranty. Good Luck
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
No sound or tv signal
Probably need the TUNER either fixed or replaced.
Apr 27, 2008 | Toshiba CZ27V51 27" TV
Picture clear then fades to snow when it does, makes annoying sound
sounds like poor solder on the ground conections of the tuner, depending on the age of the TV frostman
Feb 11, 2008 | Sony KV-27FS13 27" TV
Rear projection snow
Bad primary tuner==can be replaced,or==by-pass by using video inputs.
Aug 26, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Panasonic PT-47WX49 47" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
