Question about Garmin StreetPilot 2720 GPS Receiver
The small lip that hold the power cord to the unit snapped off. Need to know do I have to send it back to Garmin for repairs.
Lightly scuff the plastic a little ways out around the broken piece. Put some vaseline on the back connector and slide into place. Mix up some JB weld [or similar] and pack a little ball against the area that needs reinforcement. Keep smoothing and packing until it firms up. Let dry, and pull the connector back out. There ya go.
Posted on Dec 03, 2009
My garmin won't come on. I leave it in my truck pluged in the the cigarete lighter all the time. The green light on the cord is on but my garmin won't come on. Do you have any suggestions.
Hi dave,
Many times these units left hooked up for a long time, especially in a hot vehicle, will cycle out completely and need a total reset. Assuming your unit is still good and battery is ok, with power on the unit, the green light shows it's still charging the battery. Try the reset button in the recessed hole, usually on the bottom of the unit. Press it in with a blunt object for about 10-15 seconds. Some manuals say 6 seconds, but I always like to "overdo it", just to be sure.
If you still can't get it to power up, try holding the Power button on for about the same time as the reset procedure. Hopefully this will wake it up. If not, you may need to get with a repair facility or see about sending it back to the factory for service.
Let me know if I can help you later. Thanks.
Regards, Bill
Sep 17, 2010 | Garmin GPS
How do I get the back off the Garmin nuvi 250
Be A MAN Fix It" Take Decale off Says Garmin Model Number ect...exposes 2 screws, Remove Screws, The Frame around screen has plastic anchors that sit in Slotted groves completely around frame so work on the end that doesnt have on/off power switch and take small straight edge gently pry out and up once begains to open up take and put 2nd screw driver in as wege now goto the other side right or left and do the same, now work around the garmin and stop when you get to end with the power switch do the other side once you start on the end with the power switch watch the power button which is held inplace by the Garmin frame and has slot that the power button sits in Note: the Curve side will go in first when reassembly, once opened you will see 2 connectors 1 a 2-wire speaker and on the back side of the board a 3 -wire battery now the monitor has tape accross the conector and i just remove the tape like opening a Christmas Present and the locking door will rotate up toward your face...That is About it Have Fun Have Fun the frame will snap together if circuit board is dusty use a 2" paint brush and blow dust off while brushing ....
Dec 30, 2009 | Garmin nuvi 250W GPS Receiver
Two year old #200 unit. Plug seems to come loose
yikes! unfortunatly it sounds like you will have to send that back into garmin for repairs. for loose parts inside they are the only people who are authorized to repair it. Unless you know someone who is good repairing electronics
garmins website will give you a flat rate repair on what it costs to fix it.
Aug 14, 2009 | Garmin nuvi 200W GPS Receiver
Repair usb power male connector snapped off
You can buy a mini usb cord from any computer shop. You can also use one from a digital camera if it has a mini USB slot.
Oct 14, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin repair for screen
I'm afraid that will have to go back to GARMIN for repair... they use fully custom LCD displays, as to all other GPS manufacturers.
1-800-800-1020
Regarding the "guest" who's tagging along with a different problem...
Have you tried a hardware RESET? The button is hidden behind the front panel, which snaps off by a fingernail slot located directly under the GARMIN logo on the front panel.
* Use caution removing and reinstalling the front panel... it's somewhat fragile... wiggle it a little to get it off.
Press where it says "Press to Reset", hold for a second or two. Charge the unit with the car cord or USB cable, then try to turn it on again.
Once you can get the unit to (hopefully) turn ON, you should run all updates (there may be several!) using Garmin's Webupdater. (Connect to computer with USB cable first.)
Hope this helps!!
Jun 29, 2008 | Garmin StreetPilot c340 GPS Receiver
I have a Garmin Nuvi 760. The end cap which screws in and holds the fuse in for the traffic receiver power cord is broken. Anyone knows where I can get a replacement part without buying another power...
This is a known problem with the 760 traffic receiver power cords. Call Garmin Customer Service (you may stay on hold for 20 minutes or so). When someone answers, explain the problem and they will most likely send you a replacement screw cap and fuse assembly for free.
Jun 12, 2008 | Garmin GPS
I dropped my garmin nuvi and the power button is jammed in...am i hopeless?
Try to use a dental tool (small hook-pick) to pull it back out, otherwise send it back for repair.
Jan 27, 2008 | Garmin Nuvi 350 Car GPS Receiver
Garmin C330 resets itself
The first problem with it powering itself off is a battery problem. Your battery is not hold a charge.
The second problem with it powering itself on with the power cord attached is a power cord issue. The unit is suppose to automatically power itself on if a power cord is attached to it. This is Garmin way of turning the unit on when you start your car. Most auto cigarette lighter will cut power if the ignition is off, and restore power when the ignition is on.
Garmin uses this to turn the unit on and off. If the unit was being powered by the the cigarette lighter then it say unit is shutting down in 20 seconds after the power is cut.
Jan 21, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot 2720 GPS Receiver Logo
75 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
