Question about HP G60-120US Laptop
How do you take apart a laptop AC adaptor/ battery charger?
    President:
  • 2,653 Answers
Usually with sharp knife or screwdriver (safer) you have to break the middle into halves...they're glued together.
Unless you're super desperate and not worried that you'll damage your computer permanently or worse start an electric fire you should just re-purchase an ORIGINAL charger for your machine.
ebay's the cheapest place...don't get a knock off!
Posted on Nov 20, 2009
5 Suggested Answers
ronaldo_ross
  • 1056 Answers
SOURCE: will not work with ac power adaptor but does with
Did you wiggle it a bit when plugged in? You can't tell from looking on the outside if the plug is fine because it goes bad inside where it is soldered. This is a very common problem, and have fixed many laptops with the same problem. All of them had a bad solder connection inside. Did you dtermine the plug was fine by plugging another ac adapter to your laptop or you just checked it visually? Hit me up I will solve this one for you.
Posted on Aug 12, 2009
Pyrhyc
  • 2028 Answers
SOURCE: laptop won't turn on
The blinking orange battery light generally indicates that the battery isn't working properly, usually going out and not charging properly. In this case, since the adapter will not power the machine without the battery, and it should, I'm going to say that the adapter is going out and not getting the proper amount of power to the system. Try replacing the adapter. Be sure to replace it with a Dell replacement, the Targus brand universal adapters do not work well with Dell machines, and in most cases won't work at all.
Posted on Jul 15, 2008
  • 69 Answers
SOURCE: Laptop does not work with AC adaptor, does not charge. Mother board issue
You may be able to get a battery charger but its rare.
If you do wish to use the AC adapter, take care with positive and negative. Also the voltage of the battery is actually lower than the AC adapter in order to get charged. I don't know what is going to happen if you do choose to use AC adapter as battery. 75% chance that it will work.
Posted on Oct 08, 2008
cornmint
  • 23 Answers
SOURCE: My dell xps M2010 laptop is not working with the
You say "My dell xps M2010 laptop is not working with the battery", do you mean only with battery you laptop can't work, if so, I think you should check your battery. You can check the adapter first, follow the steps as eng_omran_77
If the battery is bad, change a new one, In fact it's a very common problem for laptop, my laptop battery is out of work for a long time, but I don't use battery often, so I don't care about the battery.
My friend have bought a battery from an online shop, it's a replacement battery, cheap, but the performance is OK,
So you can have a look:
http://www.sales-battery.com/laptop-batteries/dell-xps-m2010.htm
Posted on Jan 16, 2010
I have an acer aspire 5100 and here recently the
Could be a bad battery and/or charger/AC Adaptor/DC Connector. Try to isolate the problem by removing the battery and then plugging the laptop charger in and starting the pc up. It should boot on the AC adapter alone. If it won't boot on the AC adaptor or it flickers and flashes while on the AC adaptor, I would first suspect the AC adaptor or the DC connector on the laptop (try wiggling the power plug at the PC to try and check the connector). If it behaves while on the AC adaptor without the battery present, I would suspect the battery. Either way, you may have to replace something.
Sep 04, 2014 | Computers & Internet
Flashing AC Adaptor
Is the battery any good? A bad battery will cause erratic operation of adapter/charger.
Jun 10, 2017 | Samsung Kitchen Ranges
2 ac adaptors have stopped working on acer laptop
Take the battery out. Unplug the charger from the computer. Press the On button for 30 seconds. Then plug the charger in. If it works, then put the battery back in and you're in business again.
If it still can't work, perhaps the charger you bought is a dead one, just contact the seller to get a replacement one after all you have used it for about a few minutes. If you don't believe in that seller, just contact them for the refund and go to other vendor for a new adapter. I recommend the following one for you:
http://www.chargerbuy.com/replacement-acer-aspire-5739g-ac-adapter-19v-4-74a.html
http://www.chargerbuy.com/replacement-acer-aspire-5738-ac-adapter-19v-3-42a.html
Oct 26, 2012 | Lifetime Acer Aspire 5738PG Replacement...
I have a HP dv7 laptop it does not work with the ac adapter but worked with the battery, whenever it is working with the battery and the ac adapter is connected it shuts down.
Remove the battery and plug the ac adaptor in check wethere the light on the port where you connect the ac adaptor glows or not, if no then check the wethere the ac adaptor is getting warm or not after you plug it in for few minutes if not then ac adaptor has to be replaced.
If the light on the port is glowing then it is likely that the power supply of the notebook has gone bad as it is not able to switch to ac adaptor or the port where you connect the ac adaptor to the notebook has a short circut when the acadaptor pin is connected , better try with a different ac adaptor to be sure wethere the issue is with ac adaptor or the notebook.
My best wishes
Mar 19, 2010 | HP Pavilion dv7-1130us laptop
Laptop doesn't turn on ...
remove ur battery change ur adapter
if not work there is short inside ur laptop
it is recomended to consult ur technician
Jan 27, 2010 | Acer Aspire 5610-4648 Notebook
I have a dell 1545 and when it is plugged in the battery icon says "plugged in battery not charging" when i unplug the ac adaptor and plug it back in it says "the ac power adaptor type cannot be...
try to remove the battery first and plug in the ac power adaptor and see if it works. if yes, then your battery is faulty.
if it doesn't work i suspected that there's a problem with the power socket from your machine. you can check it with the nearest service center near you.
Jul 02, 2009 | ASUS F3Jc-AP141C Notebook
Ac Adaptor not working??
as u said that when u plugged in the ac adaptor into the laptop it recognises that the ac adaptor is connected but it does not charge the laptop in this case what u can do is that if have the same charger extra then u can try with the another charger and if the other charger also does the same thing then in this case u need to replace the mmotherboard and if the other charger is working fine in this laptop then definately chage ur aac adaptor.....good luck...
thanks
Jan 25, 2009 | HP Pavilion dv6000z Notebook
Oct 08, 2008 | Dell Inspiron E1705 Notebook
Battery is not charging
Charger board seems to have gone bad.
Aug 05, 2008 | HP NC4010 Notebook
HP G60-120US Laptop Logo
2,290 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
