Question about Water Heaters
I have a defective Water Ace sewage pump. Water Ace agrees that it needs to be exchanged for a replacement. My plumber has vanished. The pump is in a cistern whose top is level w/ the basement floor. There are two PVC pipes entering the cistern from above. How do I get the pump out of the cistern?
  • psblack Nov 20, 2009
    the pipes are fixed with clamps. Do I disconnect the clamps? If I do, will there be a discharge from the pipes?
  • psblack Nov 22, 2009
    It won't just lift up, the pvc pipes are fixed. One comes through the wall of the bathroom and goes down through the cover of the cistern, about 6 feet long. Another comes out of the cistern and connects with a pipe heading outside. Each of the two pipes going in and out is clamped with 3 screw-on clamps banded around the pipe about 3 feet from the cistern. The pipes look they slide into the next pipe. I think I probably need to unscrew those 6 clamps and slide the pipes out but I don't know if they are cemented as well. I'm willing to try just about anything but I'm wondering if I'm out of my depth on this. I'm afraid that if I do manage to get the pump out and replaced the pipes will leak when I reconnect them.
  • 6,927 Answers
It should just lift out,pick it up and out,by lifting it out with the pipes.
Posted on Nov 20, 2009
  • Ronny Bennett Sr.
    Ronny Bennett Sr. Nov 20, 2009
    I am sure there will be,sorry
  • Ronny Bennett Sr.
    Let me know if I can help,I will be back on,and check in on here in the am.
I HAVE WORCESTER 24SI BOILER , THE HEATING IS WORKING BUT NO HOT WATER THANKS.
Hi Mustafa, you are going to need a Gas Engineer to fix this one. It could either be the Hot water sensor or the flow switch that activates the water to come on. Good Luck.
Jan 03, 2015 | Water Water Heaters
I have a Whirlpool water heater Serial Number 1110T464496 that is giving me a problem. I reacently had an un related pluming problem that I had to call a plumer to fix. While he was repairing the problem I...
to start with fixya site never responded about agreeing with the plumber
That would have been the manufacturer site
next ,what they have admitted would have meant that it would be replaceable under warranty (1 year old ) and they would have asked you to organize a warranty call for the fix
the rod they are referring to is an anode rod and is used to slow down the electrolysis process that eventually eats the heater tank
The noise could be from boil off from pressure that is released when you turn on a hot water tap ( sort of like what happens when you remove a radiator cap when the har is overheated )
It could be a "water hammer" problem and that can be fixed by an accumulator or mains pressure regulator being placed in the cold water inlet line ( sort of like a shock absorber for fluids or in the case of the regulator - sort of like a tap only half turned on )
you can try turning the thermostat setting down on the unit as any water temp over 75C is wasted energy as you cannot put hands into water over 75C and it is almost constantly using power to maintain the high temp setting
That may stop the problem
Mar 07, 2017 | Whirlpool 6th Sense 50-Gallon 12-Year Gas...
How to Fix Hot Water Pipes Hammering/Banging?
Had a similar problem and found that the plumber who had replaced the recirculating pump had removed the plastic pipe hollders. These are spacers used to hol the pipes firmly as they pass through the wood studs. Even with only two spacers missing the hammering sound passed through the whole system. Once new spacers were installed the hammering sound stopped.
Jul 14, 2012 | Water Heaters
Leaking from inside box for few days , plumber said condensation built up to use fan to dry out.
If the water is coming down over the fan motor, you probably have a heat exchanger leak. If the heat exchanger is leaking, it needs to be replaced. The heat exchanger is the large copper box on top of the heater.
Oct 15, 2010 | Noritz Water Heaters
I have a three year old home with a noritz tankless hot water heater. It's leaking and the plumber says the flue was plumbed incorrectly which invalidated my warranty. So, apparently I need a new tankless...
bull ****! . If the heat exchanger is leaking, it should be under warranty. If you have and improper installation that should be the responibilty of the builder or his plumber. You may have some labor cost, but not the entire cost. contact your builder
Feb 04, 2010 | Noritz 6.3 Gallon Residential Tankless...
GE gas water heater lights for only a few seconds. After the burner ignites it quickly goes out along with the pilot light. The pilot cannot be relit for at least 20 minutes. Have replaced the...
Called GE and there is a glass vile under the burner that is defective and cuts off the oxygen.
They are mailing out a replacement to my house & have contracted a plumber to install. waiting 4 days now. They say that the glass vile incinerates and there is not any thing left to it. The burner area is full of black soot. will post again one fixed.
Jan 08, 2010 | General Electric GE SmartWater Household...
Rinnai tankless water heater
LC is the error code that you get when you have limescale buildup in the heat exchanger. You need to flush your heat exchanger. If you have the manual for your water heater, use it. The manual to mine is attached. The procedure for flushing it is covered on page 12. I suggest that you have a certified Rinnai plumber perform this task as it requires a ciruclating pump and some hoses that you need to connect to your water heater. If you don't perform this task, it is possible that you will need to replace your heat exchanger and this is not something covered by Rinnai's warranty.
Sep 21, 2009 | Rinnai Webstone The isolator EXP tankless...
Hot water
there are two main faults with combi boilers not giving hot water. one is a faulty flow sensor, the other is the most common which is a blocked heat exchanger caused by debris and scale in the system. this needs to be flushed out or may require a new heat exchanger depending on the age and condition of the boiler some plumbers may suggest a new boiler.
Mar 02, 2009 | Water Heaters
Water Heaters Logo
23 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
