Question about Sewing Machines
I have a defective Water Ace sewage pump. Water Ace agrees that it needs to be exchanged for a replacement. My plumber has vanished. The pump is in a cistern whose top is level w/ the basement floor. There are two PVC pipes entering the cistern from above. How do I get the pump out of the cistern?
  • 6,826 Answers
It should just lift out,pull up on the pipes,it just sets in there.
Posted on Nov 20, 2009
I have a brother super ace ii and the bobbin winder does not turn what can be the problem
THE BOBBIN WINDER HAS A "TIRE" UNDER THE TOP OF THE SEWING MACHINE. IT IS LIKELY IT HAS WORN AND NEEDS TO BE REPLACED. TAKE THE TOP OFF AND LOOK TO SEE IF IT IS MAKING CONTACT WITH THE HAND WHEEL WHEN IT IS IN THE WIND POSITION.
Jan 17, 2015 | Brother Sewing Machines
Brother super ace 2
yes just replace the computer bottons and clean the machine or go the second hand shop (surplus, junkshop) try to find a same model and take off the part you need replace it your machine you save a lot of money even your machine
Sep 09, 2014 | Sewing Machines
Must US Customs check packages from New york to China?
US Customs can inspect anything they desire, China can do the same. I shipped to El Salvador and a automotive part was in Customs for over 2 months before it cleared... Contact WHO you shipped it through with the tracking number, you should have insured it as part of the shipping and file a claim.
Mar 01, 2014 | Sewing Machines
SENSOR KEYPAD SHEWING MASHINE BROTHER SUPER ACE II (M-955) DON'T WORKS.
Had the same problem here. Took it apart and found that several tracks in the ribbon cable from the keypad to the circuit board on which the LCD display is mounted were broken hence keypad needs to be replaced. Its part number is XA4331002 and available online from Sewing World. Have just finished fitting the replacement and keypad and sewing machine are working A1 OK.
Jan 14, 2011 | White Sewing 955 Mechanical Sewing Machine
Stitch selection
Can't remember the Ace but you need to take the top off if you can and check the nylon camstack, very prone to splitting and the selecter finger getting stuck in the slot
Mar 09, 2010 | Sewing Machines
How do clean a water heater tank
That process can be very difficult if you have not done it in a long time or have never done it.
Hopefully your plumber installed a shut off valve on the cold water pipe you will need this.
Also make sure you have a new relief valve handy, you will probably need that also.
First turn off the cold water to the haot water heater and also shutoff the gas ore electric to the heater.
Then hookup a hose tot he drain at the bottom of the tank. Open the valve and relieve the pressure. The you will have to lift the handle on the relief valve to allow air to go in to the tank so the water will go out.
When the tank is empty, you then need to alternately run cold waterinto the tank and then drain it out until you get only clear water out of the tank each time you do this. You do not have to run a lot of water in at a time, A half minute shot each time will do the trick.
When the water runs clear when draining the tank is clean.
Close all valves and change the reief valve, because it probably will not seal again.
If **** plugs up the drain valve, you may have to take off the hose and use a wire to clear it or even repalce the drain valve.
This is a slow and long process to do it right.
Heatman101
Feb 03, 2010 | Sewing Machines
Pool cleaner will not move in water power switch is on
This is dependant on the pump which should be running when you switch it on. Alot of times these stop working due to air in the system which greatly reduces the suction of the pump. There is a bleeder screw on top of the filter which will help purge the air out of the system. Many times the air leak is simply a poor seal on the pumps filter basket. There is a large o-ring on that clear cover which seems to stretch and become ill fitting to the ride area of that pump to o-ring and cover. It is highly advisable to use lube on that o-ring as well but not petroleum based lubes (like vasoline or spray lube).Use a plumbers grease or lube provided by pool equp. store designed for o-rings. If your suction is up to par and cleaner still will not function,there is a special diaphram in the unit where debris can get caught inside causing the unit to malfunction. Look inside the suction area of the cleaner and you should be able to see and inspect the white rubber diaphram from there.If you are lucky, you can lube the o-ring and remove debris from the cleaner and resume operation...good luck
Jul 26, 2009 | Sewing Machines
BROTHER SUPER ACE II 955
I found an instruction manual for my brother ace on an australian brother site..hope this helps Pat
Feb 18, 2009 | White Sewing 955 Mechanical Sewing Machine
Need to replace the light bulb--how do I do that
You will need to obtain a new lamp from a Janome dealer.......they will probably offer to install it for you for no additional charge.......just ring to agree a time.
It is a small low voltage, simple push in type lamp & I believe the part number to be: 000 009 906
Just make sure the machine is NOT plugged in when you change it !!
Apr 28, 2008 | Janome Memory Craft 4000 Sewing Machine
Sewing Machines Logo
52 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
