Question about GE Hotpoint Top-Freezer Refrigerator
Hi there. My GE GSL25JFPD side by side has major issues. The evaporator has completely frozen over. We called a technician twice. The first time he replaced the main electrical board. This fix lasted about 2 months before we had the same problem again. The tech came out again and tested various parts..All came back with normal readings so he replaced the main board again. Now, only 1 week later, we have the same frozen evaporator coils. I removed the panel, used a hair dryer to defrost to at least buy us a couple of days while I wait for your expert opinion. :) Thanks for your help!
  • GE Master
  • 1,606 Answers
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board .. Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also .
Posted on Nov 20, 2009
  • James Macomber Dec 03, 2012
    Did test and heater came on. But evaporator thermistor (#4) seems okay - reads 15.5k ohms after being in ice. ??
  • Mike Smith
    Mike Smith Dec 03, 2012
    Replace the #4 and #5 thermistors . They have been known to have variance in the ohms at different temps .
Can you tell me why my ice ain't freezing but everything else is
Its possible to freeze item below the evaporator, but with out a fan moving air the ice must be located above the evaporator. I hope this helps and answers your question. I would look for a fan issue, or get me a model number and its possible I can assist you further if needed. Thanks
Apr 16, 2016 | Refrigerators
GE Monogram ZISW36DYA ... frozen ice-cycle rivulets run down both sides of freezer (water off for days to verify it is not ice maker) ... defrost control clicks when rotated and advances with time ... do...
Seems to me that might be a clogged defrost drain or maybe a dripping water valve. Doing that. I have the service manual with nice pictures in it that show clearly how to access the components.
GE MONOGRAM SERVICE MANUAL
Nov 10, 2010 | GE Monogram Side by Side Refrigerator
Have a 10 year old GE profile side by side refrigerator that has a puddle (2-3oz) of water about once or twice per week comming from back bottom. I have checked the drain in the freezer section about 1.5'...
hi that the only drain going to the pan douse it have an ice maker if so check the water line going up the back to ice maker check around water valve may have a small hole or a hole in pan jim
Oct 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Why is our fridge frozen all the time?
Hi!!
The evaporator fan (little fan in freezer), is the one that blows cool air to the fridge. If your evaporator is freezing up, it could be due to the thermostat set too high, and the fridge control set too low. Set freezer temp. one number lower, wait 24 hrs and check, if evaporator still freezes, lower it one more setting. If temp in fridge is OK. leave it alone, or adjust accordingly.
Let me know how it worked out.
Good Luck!!
Mar 28, 2010 | GE GSS25JFM Side by Side Refrigerator
I need to know what bulbs I need fo rthe GE
main bulb is ge part # AP2006861 and is a 60 watt common light bulb/the dispenser bulb is a g.e. part # of AP3884244 and you should be able to get these at a grocery store or ace hardware
Oct 04, 2009 | GE GSL25JFPBS Side by Side Refrigerator
GE Side By Side refrigerator evaporator freezing up
is there good airflow around unit (should be away from wall about 2 or 3 inches on all sides) you say you cleaned under so about only thing left that can cause ice is low freon or defrost timer going out slowly
Jun 02, 2009 | Frigidaire FRS-26DR7D Side by Side...
Not making ice, no water dispensed, ref not cooling anymore
I see this one year ago. I will try to help if you still have the refer.
Apr 16, 2009 | GE GSH25JFR Side by Side Refrigerator
Water dispenser not working
This water line does not run through the freezer. You have a switch in the door where you get water that activates the water valve in the back of the Ref.
One or both of these are bad and needs to be replaced.
Dec 21, 2008 | Refrigerators
GE Side by Side refrigerator/freezer Evaporator keeps freezing up
Sounds like the auto-defrost timer has gone bad. In many cases, that is the cause. Check with GE service.
Sep 04, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Red glow (from defrost heater?) at bottom of rear panel in freezer
This is from the GE Appliance "Knowledge Database" Web site:
Refrigerator - Explanation Of Red Glow
In a no frost refrigerator, the defrost timer activates defrost heaters in the evaporator section (rear of freezer) which heat up and melt the frost off the evaporator coils. This process lasts for approximately 25-45 minutes and usually happens up to twice a day.
During this time, there will be no running sounds, no fan noise, and you may hear water dripping or sizzling as it hits the heaters. On side by side models, you may even be able to see an orange glow at the bottom of the freezer.
This is normal.
Aug 06, 2008 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
205 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
