Question about LG Heating & Cooling
LO error code LG ducted - LG Heating & Cooling
    New Friend:
In my lg ac it automatically shut downs and restarts and lo is written in stead of temp what is the problem and what should i do?
Posted on May 20, 2010
I have an LG Dryer and keep getting a error message D90 after running for about 10 minutes
D90 means the dryer thinks the vent duct is 90% blocked. Be sure the vent hose is not kinked behind the dryer. I've even disconnected the hose from the dryer and hooked up my leaf blower to blow out the vent as it develops more air pressure than the dryer does.
Here's a great video describing the error code: https://youtu.be/yL7Oq4lCadw
Good luck. Hope this helps.
John
Mar 22, 2015 | LG Dryers
Lg dryer error codes
Duct is plugged it is heating up. the vent needs to be cleaned.
Oct 12, 2013 | Dryers
I have a new LG ducted AC unit B62UWYUY81 and geeting error code CH 54 on the remote controller . Can you help to reset the system.
Reverse or open phase. Check all 3 phases are present and correct. If correct voltage appears at all three phases, swap any two to cure the fault. Thanks. Helpful?
Feb 11, 2011 | LG Heating & Cooling
Error code 62 on Brivis Me20 ducted heater
Hi
Error 62 is related to hot surface ignitor (HSI)or/nglo module
you can check the resistance of the ignitor should be less than 10 oms @ 20 degrees
failing that, if you incomming suppy exceeds 270 volt will also result in error 62
May 04, 2010 | Heating & Cooling
Lg Ducted inverter airconditoning with error code COMPRESSOR SAFETY LP what does this mean?
The LP code is low pressure check to see if the air filter is clean if the filter is dirty this will restrict the air flow other wise you will need a service tech to check the refrigerant charge on your unit.
Jan 27, 2010 | LG Heating & Cooling
ERROR CODE
Hi,Pls to shut - down the unit and try to power on ,may be its malfunction the control LCD.
THANX
Edgz
Mar 30, 2008 | Heating & Cooling
Problems with LG MP3 Player (due to a mistake in the operation of the device)
I too have had the "Device Manager code 9001 see manual" message come up on my LG unit, after having upgraded the firmware. All my music and photos disappeared and the unit would lock up if I tried to record anything.
I decided to format the device (from the General Settings) and the error message doesn't come up anymore. All my stuff was gone so there was nothing left to lose. It seems to be working now. I hope this helps you guys too.
Jul 03, 2007 | LG Digital Media Player (MFJM53)
Heating & Cooling Logo
655 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
