Question about Kicker ZR600 Car Audio Amplifier
I have a kicker ZR600 was shorted i dont have any idea how fixed my problem the 6 power ic's was toasted
  • 364 Answers
Mmmmm toast is correct, you may be lucky, examine the unit, it may have a fuse that actually took the short and simply replace it, if this was bypassed then the internal banks will be fried {toast}. The cost of repairs will exceed a replacement cost, I wish you Good luck
Posted on Nov 20, 2009
All three of my fuses blow everytime i install them in my amp
It has to be getting to much power. What system is hooked up to it? What are you sending through the amp? Power wise
Feb 12, 2011 | Kicker ZR600 Car Audio Amplifier
Speakers pop or rumble when stereo is turned on
AMP HAS PROBLEM.. SOUNDS AS THOUGH THE LINE INPUT AMPS HAVE PROBLEMS IN AMP ALSO ONE THING TO CHECK WOULD BE TO DISCONNECT SPEAKERS AND HOOK UP RCA'S.. CHECK THE SPEAKER OUT PUTS WITH A DC VOLT METER TO SEE IF YOU HAVE DC VOLTAGE ON THEM IF SO YOU HAVE SOME SHORTED OUTPUTS
Apr 24, 2010 | Kicker ZR600 Car Audio Amplifier
What type of "Gauge" wires should I be using for the Kicker ZR600 AMP (Power cable, ground, Speaker wire)?
The lower the gauge, the thicker the wire.
You want multi-strand, not solid. This has better conductivity and less resistance over distance.
10 to 8 gauge will be able to handle anything that particular amp needs.
Remember an in-line fuse on the power cable as close to the battery as possible.
The speaker wire doesn't really need to be anything special
Sound good? Pun intended
Best regards
Mike
Apr 05, 2010 | Kicker ZR600 Car Audio Amplifier
I HAVE A KICKER CAR AMP ZR600 AND ITS NOT PUTTING OUT ANY SOUND AND IVE TIRED EVERYTHING
TRY CHECKING UR CONNECTION AT THE BATT. AND AT UR FUSEABLE LINK AND EVEN UR GROUND WIRE
Feb 21, 2010 | Kicker ZR600 Car Audio Amplifier
How many watts are in the kicker comp zr600 amp? i was told that it was a 1000 watt amp. i just want to make sure that it is a 1000 watt amp and not a 600 watt amp. i am powering two 15'' kicker comp subs...
  • Amplifier Type: Dual Channel
  • Bridgable: Bridgable
  • RMS Power at 4 Ohms: 150 W x 2
  • RMS Power at 2 Ohms: 300 W x 2
heres a link to a stats page for the zr600>
http://www4.shopping.com/xPO-Kicker-ZR600#keyFeaturesArea
Feb 05, 2010 | Kicker ZR600 Car Audio Amplifier
WHATS THE WATTS ON THIS AMP
Feb 04, 2010 | Kicker ZR600 Car Audio Amplifier
Kicker zr600 smokin havent even bumped yet today
Well it seems to me that the pictures of this amp show green ATC fuses which would be 30 amp fuses. What is your inline fuse from the battery? 40 amp fuses for the amp is too much current for the amps powersupply. If there was a short in the powersupply the max ammount of current that it could draw would be larger than designed to handle therefore damaging the amp.
Jan 02, 2010 | Kicker ZR600 Car Audio Amplifier
Kicker car amp overheating
Disconnect the speaker wires and the RCA cables from the amp. If it still heats up, the amp has an internal fault. If it doesn't, you need to check the wiring for shorts and you need to make sure the impedance is what it should be (no less than 2 ohms per channel).
Feb 08, 2008 | Kicker ZR600 Car Audio Amplifier
Red light is lit on my Kicker KX400.1
the water shorted it out. It will need to be repaired.
Sep 10, 2007 | Kicker ZR600 Car Audio Amplifier
ZR600 problem
Does it blow the fuse before the remote voltage is applied or does it only blow after remote voltage is applied?
May 25, 2007 | Kicker ZR600 Car Audio Amplifier
Kicker ZR600 Car Audio Amplifier Logo
121 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
