Question about Lexmark X2600 InkJet Printer
Error code flashing on printer 1 ec
Wont print
Wont let me print
The error code "EC5" indicates a short in one of your cartridges. Please follow the steps below to identify and fix the problem:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
Jan 07, 2012 | Lexmark X2670 All-In-One Printer
Lexmark 2670 code EC continues to flash along with the in front of black ink
The error could be indicating that there's a communication failure between your cartridge and the printer. Please follow the steps below to fix the problem:
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center.
5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
I hope this helps.
Oct 25, 2011 | Lexmark X2670 All-In-One Printer
My Sub-Zero is flashing error code 36. What is this?
Diarmait --
Technical Service Manual for the SubZero 600 series can be downloaded at:
[https://docstore.fedex.com/subzero]
Username=subzero
Password=subzero
Write back if you still need help.
-- SWT
Aug 23, 2010 | Sub-Zero 650 / O Bottom Freezer...
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Canon i550 LED error sequence: 7 orange +1 green flash
    According to Canon 7 orange flashes indicates a print head fault. Solution they recommend is to take it to one of their service agents. Problem is that replacement print heads are not cheap and it is usually more economical to replace the printer. You could try taking the print head to a cartridge refiller and have it professionally cleaned (cost you nothing or next to nothing) and see if that solves the problem.
    Sep 19, 2009 | Canon BubbleJet i550 InkJet Printer
    Flashing E3 error code for a paper jam
    I had the same problem with my mp 160, Error message was blinking. I tried to print but the printer would take 1/10 of the whole page and stop, even though rollers were moving. My solution for this was to take a piece of thin cardbord(I used a magazine cover), cut it in a size of A4, put it in printer, printed it and when the rollers start moving I forcebly pushed the cardboard through. Now it seems to work fine. Hope it does for you.
    Mar 12, 2009 | Canon PIXMA MP160 All-In-One InkJet...
    Canon Pixma ip3000 flashing amber 6 times
    If the 6 flashes are accompanied by an on screen message #5400, this is a "Service Call Error" code.
    This code indicates the following;
    Internal temperature error [5400]
    The solution to this is the following part replacementl
    - Logic board ***'y (QM2-1548) *1
    *1: Before replacement of the logic board ***'y, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or
    more, also replace the bottom case unit (QM2-1205) or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864 / 4221 / 4257) when replacing the
    logic board ***'y.
    [See Section 3-3. Adjustment / Settings, (6) Service mode, for details.]
    Good luck!!!
    Jan 12, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
    Installed a lexmark z12 printer but not the power light but the light next to it keeps flashing and it wont print
    1. Turn the power OFF.
    2. Open the front cover.
    3. Turn the power back ON. The print cartridge carrier should move to the install position located in the middle of the printer.
    4. If it does not, close and reopen the cover:
    5. Remove the color print cartridge.
    6. Close the cover.
    7. If there is no error indicated by flashing lights, the color cartridge has short-circuited.
    8. However, if you continue to get an error, repeat steps 1-3, and then go to step 9.
    9. Remove the black print cartridge and reinsert the color cartridge.
    10. If there is no error indicated by flashing lights, the black cartridge has short-circuited.
    11. If you continue to receive an error in both cartridge scenarios, both print cartridges have short-circuited.
    Dec 01, 2008 | Lexmark Office Equipment & Supplies
    UNABLE TO PRINT
    press menu then start bk copy then fourtimes arrow-up button (tel.index) quick after another.
    machine will be in maintenance mode and lights will flash.
    press start bk copy in case machine wont directly display the error code.
    Error starting with 4 means defective print head.
    Error starting with 5 menas defective purge station or cycle problems.
    both error series means: you need a new printer...
    Feb 13, 2008 | Brother MFC-5840CN All-In-One InkJet...
    Lexmark X2600 InkJet Printer Logo
    390 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
