Is it just a matter of replacing the valve or is
Armstrong furnance has a bad ''smart valve''. Is it just a matter of replacing the valve or is there adjustment involved? I can install it, but does it require more than that?
  • 43,501 Answers
Your smart valve will come already preadjusted. All you have to do is remove the valve and install the new one. Make sure that you remove all power to the unit so that you do not short out any wires that could burn out your transformer while changing the valve. Also make sure that you mark all wires so that you get them back in exactly the same place that you removed them from on your old valve. One other thing to do is to mix water and dish soap together in a spray bottole and check all joints for gas leaks after the installation. You will get bubbles from the joint if you have a leak. You can do it and have fun at it!!
Posted on Nov 20, 2009
My ducane furnance blower wont ignite the thermost t keep going off
The blower requires proper voltage, I will include a diagram however if not familiar with power I advise against trying any repairs.
Mar 04, 2014 | Emerson Lennox Ducane Armstrong Furnace...
Need the year of my furnance, have the model and serial number
manufacture can tell you year. what brand is it? goodman? my guess is 97 dec.
Feb 26, 2014 | Emerson Lennox Ducane Armstrong Furnace...
My furnance keeps turning off and I could go to furnance flip switch on and it only last 5 minutes then shuts off again
You may want to check the limit switch or you could have a issue with the gas valve or transformer. I would check the low voltage transformer first, Sometimes I have found that under load the transformer will open ( quit working) and will close after power is removed and it cools down, It indicates a bad internal connection.
Jan 26, 2013 | American Standard Trane Ge Gas Furnace...
Armstrong GUK125D20-2B won't ignite
Did he check the Pressure switch was it filled whit water can you make the switch open on the pressure switch when blowing on it? Is the hose from the inducer motor opened and not blocked ? also if there is a block after the inducer motor it will not Ignite. If the Tech does not know how to check a pressure switch get a new tech.
Oct 06, 2012 | Honeywell Furnace Air Pressure Switch...
Goodman A18-8 electronic furnance and AC troubleshooting.
Check the unit for a high temperature limit switch, usually a round bimetal disc or a square plate that
would insert into the unit. If the switch is bad, it opens up and the fan will run no matter what. Complete the circuit with jumper wire, if fan shuts off
replace switch
Jun 12, 2010 | Goodman GMS90703BXA Heater
Rheem gas valve for furnance
It is intentional. It's a slow close valve. There is no adjustment. You can usually replace it with an instant open/close valve.
Jan 18, 2009 | Heating & Cooling
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
