Question about Gateway MT6821 Notebook
My gateway laptop doesn't boot up correctly. When I turn it on everything seems fine but then it goes to a page that says configuring updates 3 of 3 then restarts and does the same thing over and over. I tried starting it in safe mode and that does the same thing. It doesn,t get far enough in the bootup to do a system restore.
    Guru:
  • 830 Answers
Hello and thank you for using Fixya's services.
Are you running Windows XP or Vista?
It sounds like the Windows updating has caused a problem in your operating system.
If it is windows Vista, press F4 right when the comuter comes on. Instead of choosing safe mode, choose advanced options. This will give you a screen to do the windows restore.
Please let me know if you have any questions.
Posted on Nov 20, 2009
  • Caitlin Jan 28, 2012
    i had a similar issue, i am running Windows Xp and i can not get enough in the bootup to do a system restore. i also do not have any of the discs to reset or restore anything. i know, for instance, if you hold down the '0' button on a toshiba it will automatically give you an option to reset windows. Is the something like this for gateway or what can be done.
The volume keys on my Gateway NE56R13u have stopped working suddenly how can I fix this?
check the keyboard connections inside, or replace the keyboard. sometimes a driver update or re-installation can help.
Aug 05, 2014 | Gateway NE56R13u Laptop
My Gateway laptop won't boot up it keeps saying "failure configuring Windows updates reverting changes" Do not turn off your computer
Make sure the Date & Time are set correctly on your machine. That can interfere with Windows Update. If your computer has the wrong date/time, you need a new cmos battery (available anywhere). Then, If you are running Windows 7, try the "Windows Update - Reset" options here... http://www.sevenforums.com/tutorials/91738-windows-update-reset.html?filter
Jul 16, 2014 | Computers & Internet
System configuration data updated ERROR,--Need a solution I have a fairly new Gateway M-1625 laptop running windows vista 32 bit, sp1. I turned it on and beeped twice (beep, beep) and gave me an...
Got a backup?
If not, download a Linux Live CD. Boot your machine with it, save all your data to an external drive and then do a complete disk format and re-install. That will be quicker in the long run.
Not sure about that PC, but on Dell, for example, you hit CTRL-F10 (I think) at power-on and it gives you the option of reinstalling the OS from the recovery partition (wiping any unbacked-up data in the process).,,Gateway is probably similar.
The Boot/BCD issue means your 'Boot Configuration Data' is hosed.
Jun 07, 2011 | Computers & Internet
When i boot up the laptop it shows configurating updates and never loads up beyond that
Go into bios F2 whilst booting,get to know how to configure these pages/enable correct boot sequence.use"tab" to navigate and arrow keys.save and exit or restore to factory default settings,"enter" to select option etc
Oct 23, 2010 | Acer Aspire 5720-4230 Notebook
Hi, Please help, I bought an Acer Aspire Revo 3600, 3 months ago, used it about a dozen times then un-plugged it to put my son's PS3 on, I have just plugged my Acer back in - son took PS3 into other room -...
what you can do is-hold down the power button until all the lights go off.once it is done turn on the pc and start tapping the f8 key repeatedly.it will take you to a screen which says advanced boot options.here using the up and down arrow key select the option last known good configuration and hit enter.if everything goes fine your system should boot without a problem.
Jan 23, 2010 | Acer Aspire 3000 Notebook
Turn on and nothing happed just freezs
Turns on boots on acer page to 75% then goes to windows XP then a blue page with some writing that's so fast I cant' read it then back to Acer page again and so the cycle continues. Tried F2 got nowhere, tried F8 last known good configuration and safe mode but neither helped. Safe mode didn't boot. Any suggestions, if I need to update BIOS how do I do that - was suggested on another site.
Jan 16, 2010 | Acer Aspire 3690-2196 Notebook
How do i restore my gateway laptop ML3108B to factory settings
Put your original restoration disc in the computer and boot it, it will probably ask if you wish to completely restore your computer back to the original configuration, click yes and follow the prompts as given to you by the program. There may be several discs and they are probably nukbered. As the program goes through the process it will ask you to remove one disc and insert another until it tells you to remove all media and reboot. When that happens, it will be just like the day it came to you. Beware though that windows at that time will want to update. My advice is to turn the automatic updates off until the computer stabilizes, then run windows update,but choose custom install and look at the updates and run maybe 10 at a time. That way there won't be any hangups or file corruptions. Reboot after each update untill you are done. As far as your drivers for the components installed in the pc, when you are on windows update, choose custom install instead of express, click on optional updates and you will see under hardware all the updates for your systems components. Get everything there and you will be all set. Good luck, ParrotHead PC Repair
Sep 11, 2009 | Gateway MT3705 Notebook
Gateway solo 9550 invalid configuration error when booting
Please look to see what error you're getting. You are getting one and it will tell you the problem.
May 29, 2009 | Gateway Solo 9550 Notebook
Acer5920 stuck in configuring updates.
This is generally caused by bad blocks in the Master Boot Record(Table). The drive itself is probably not salvagable. You'll need a reputable reapir person to slave your drive to another system to get the data off.
Good Luck
Mar 21, 2009 | Acer Aspire 5920-6727 Notebook
Random DNS Error
You may need to manually configure your PS3 connection on the console. Let's see.. I can suggest to first go to your Settings Menu -> Network Settings -> Choose:"Settings and Connection Status List" this will display a pretty detailed information about your connection to your local gateway (router).. Check specifically for Primary and Secondary DNS. In my experience, using the PS3's auto setup for the connection seems to enter the default gateway's ip (labeled "Default Router" on PS3 Status Screen) in place of the real DNS entries..
Question
: Sooo how do you check your primary/secondary DNS for your network? Answer: On your PC, open a web browser and enter your default gateway ip into the browser.. log into your router (assistance can be found in your router manual or by calling your router manufacture). You should see a status page of sorts that displays your ISP's primary/secondary DNS entries.. Simply transfer those two IPs to your PS3 manually to correct the DNS issue.
Hopefully that should resolve your issue!
Jul 10, 2008 | Sony Playstation 3 (PS3) Console
Gateway MT6821 Notebook Logo
259 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
