Question about JVC HD-56G787 Television
Turns on, 10 secs later fan stops, turns off, screen black
When I turn the tv on, i hear the "on" dull sound and fan starts but after 10 seconds the fan stops and the tv turns off. The screen remains black!! Any help would be appreciated. Thanks!
  • 448 Answers
The issue is with the main power board.
Based on the problem description given by you, it appears that the fan is not able to draw sufficient power to keep itself running.
You may open the case of the TV and check on the main power board, if any capacitors are burnt out.
Posted on Nov 20, 2009
The TV was turned off; and when it was turn on later, the green light blinked (while with only black screen w/no sound, or bulb illumination front/back of unit); and shortly afterwards the status ligh
Lamp is possible----
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jul 17, 2012 | Televison & Video
Tv turns on about 30 sec later screen goes black sound stays on for about 5-10 sec then just goes off then all 3 lights blink looks like a frowning face i have replaced my bulb about1 year ago is there any...
Bad lamp again. The lamp life is not dependent on install date but more the amount of use. Ebay for the lamps, a lot of the time you can get them 50% off for refurbs.
Jul 28, 2011 | Samsung HL-S4266W 42" HDTV
After 10 sec. After start up the tv starts to make a large growling sound for about 5 secs. Then repeats every 15 sec. Sounds like if might be a fan. How many fans in this t.v. . Took the back cover off...
there's 3 fans. 1 by the video board. 1 in the middle of the set infront of the heatsink and 1 behind the lamp. make sure all 3 fans are running and put your ears by them to check. if all of them are running the sound might be coming from your colorwheel. If it sounds like a loud whinning/humming or buzzing noise then more then likely its your colorwheel. Let me know what you find and please rate me. Thanks
May 15, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Hi I have a Sony Grand WEGA KDF-60XS955 TV
Ur right the cooling fan is defective,check it,clean it might work normal again.Not, than the cooling fan must be change.
May 04, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
65" projection tv will turn on and shut off before picture comes
the service light is blinking because you in fact need a new bulb also is why u have no picture
Oct 06, 2009 | Sony KP-53V75 53" Rear Projection...
52" RCA big screen tv turns on and few seconds turns off by itsel
if you heard a hissing or like static sound your board probably has a hole in it now. the board on the left side with the flyback fransformer. the hole is from where a prong has come loose an is arking over an it burns the board the ark is the sound you heard.
Apr 23, 2009 | RCA R52WM24 52" HDTV Projection Television
Lcd tv broken
I have a Wesington Plasma It is doing the same thing ??? It turns on sound picture and all then a second later black screen but all sound and stuff in tact?
Sep 10, 2008 | Televison & Video
Tv keeps turning off?
cutta, you will most often hear a click on boot then the fans start up and lamp will then fire. The picture will start to show up....at what point does it shut off? and do you hear a click when the tv is turning off? Is it the complete tv shutting down, fans and everything that turns off? Do you see any lights on the the front panel "POWER", "STATUS" or "LAMP", what are they doing? If you see a Power, Status or Lamp light after it shuts off the below are what they mean if there is an issue. POWER - STATUS - LAMP - CONDITION/ISSUE: Off - Yellow - Off - Temp. high/dirty filter/excess room temp Off - Off - Yellow - 4000 hrs. Lamp usage warning Off - Off - Blink Yellow - Lamp Cover open Off - Blink Yellow - Off - Air Filter Cover open Off - Off - Red - Lamp failure (failed to turn On or broken) Off - Blink Red - Off - Fan Has Stopped Off - Red - Off - Circuit failure (short) or DVI cable disconnected If you want to check for the last "Error Code", after you first turn the TV on, by pressing the front panel ?DEVICE? and ?MENU? buttons at the same time and holding them for 5 seconds, it activates the Error Code Mode. The ?Power LED Light? blinks/flashes (1/2 sec delay) and then flashes again denoting a two digit Error Code indicating no problem or an error has occured since the last Initalization. i.e. "Power light" blinks 3 times (1/2 second delay) and then blinks 4 times then 1 sec delay and repeats a few times. This would mean "Error 34 - Lamp abnormality". See below for error codes..... Error Code - Description or issue 12 - No Error detected, check Power Supply 32 - Lamp Cover is open 33 - Air Filter Cover is open 34 - Lamp abnormality 36 - Light Engine (DMD or LAMP Fan stopped) 37 - Exhaust or Lamp Ballast Fan stopped 38 - Lamp temperature high 39 - DMD temperature high 41 - Short is detected 44 - DVI cable between FMT & Engine disconnected. Sorry for the long answer but it was an open ended question.
Jul 11, 2007 | Mitsubishi WD-52525 52" Rear Projection...
JVC HD-56G787 Television Logo
51 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
