Question about Panasonic Televison & Video
SA-PT650 Panasonic DVD player. Display reads 'LOCKED' when I try to open the disc thing.
4 Suggested Answers
  • 286 Answers
SOURCE: dvd player doesn't recognize dvd's of any kind
jusguessin should call Toshiba quickly. The units have a 1 year warranty. Do not open the unit or it will void your warranty (I know, I do Toshiba warranty repairs on their recorders. If anything will make be void a warranty, it's a consumer who opens the unit and pokes around inside).
mooch, clean the laser head. I wish I could refer you to a FAQ because this is about the 10th time today I have written this.
Open the unit. Remove the DVD drive. Take the top off of the DVD drive. Clean the lense with a q-tip with a little windex on it. Work the head up and down gently. Reassemble and test. If problem presists, go buy a new one.
Posted on Feb 14, 2008
VOTIT
  • 2071 Answers
SOURCE: My dvd player Samsung DVD-R135 will not read any disc
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Posted on Sep 06, 2008
nitrospawn
  • 290 Answers
SOURCE: panasonic dvd player problem
Unscrew your dvd player, plug it to power source, press the open button, when it opens, without pressing the close button unplug it from the power source . then use a dry piece of cloth to clean the lens if after doing it, if it does not work then you will need to change the lens
Posted on Apr 11, 2010
Panasonic SA-BTT282 not reading blu ray, please help!
If the play function is erratic, the drive may have failed.
Jan 26, 2015 | Panasonic Televison & Video
Panasonic DVD player problems - switches to
get the dvd player len cleaned using a len cleaner.
are you operating the unit with the remote when find the mentioned issue try manually.
Jul 31, 2008 | Audio Players & Recorders
I have a Panasonic SA-PT250 surround dvd player. It plays most formats, but often displays "Error" and "Can not play Disc" although the same disc plays on a friend's dvd player. My...
some branchs are locked for some regions, and dvd movies are open forr all regions.
try to unlock your dvd and the problem will be solved.
look in the internet how to unlock your panasonic dvd, its easy.
Feb 14, 2011 | Panasonic Televison & Video
My panasonic DVD-CV51 disc player won't eject or play a disc. There is only one disc in. The player just continuously opens and closes the drawer and cycles thru the each disc location. Have left off for...
Before to apply BFH method as it is final and ultimate fix for these things, unplug unit from wall socket, take off top cover of DVD-CV51and clean optical lens with good quality cotton swab gently and check DVD-CV51 as dirty/ clogged optical lens does not read one disc and player go for next disc to read it and gives up after trying all discs.
Hope this info will solve your dvd player problem.
Thanks.
Aug 22, 2010 | Panasonic Televison & Video
Crack DVD Player
there is a disc that panasonic has to load to open region codes
Jan 16, 2009 | Panasonic SA-HE70K
Panasonic SA-HT520 error message
The system has a locked / unlocked toggle sequence on the main unit by holding down stop (or Play) and then tapping the power button. Use this sequence lock or unlock the DVD / CD drawer.
Sep 20, 2008 | Panasonic SC-HT520 System
Display says "LOCKED", won't eject disk, all other functions work. Need unlock procedure.
How I got my DVD from ”lock” condition
My DVD (Panasonic m: DMR-ES10) had gone to ”locked” condition without any warning.
Perhaps the reason was that I transfered the machine when it was on and recording was going…
Guidebook didn´t help to resolve the problem, neither Internet. Finally I managed to solve the promlem . This is how i did step by step:
1) Power on
2) Hello
3) read
4) no disc
5) functions
6) to others
7) setup
8) select down arrow
9) disc
10) select right arrow
11) setings for playback
12) enter
13) ratings (level8)
14) enter
15) No limit
16) enter
17) ”The Recorder is now unlocked” (picture of open lock)
18) enter
19) return
20) return
After this DVD works normally.
Jalmari
Aug 11, 2007 | Sony DVP-S330 DVD Player
Wont read disc-error message HO7
check out this link I think this information will help you. http://www.ledcar.com/pdvdh07/
Sep 17, 2006 | Panasonic DVD-CV47 Multi-disc DVD Player
Televison & Video Logo
273 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
