Question about Kenmore Washing Machines
Kenmore direct drive washer will not spin. motor drive coupler was broken-replaced - still no spin.how can i tell if transmission or clutch is the problem or is there another possibility? THANKS
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem initially points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode. Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside,
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Nov 20, 2009
Washer fills with water as usual then it will try to agitate and spin at same time.
WASHER SPINS AND AGITATES AT SAME TIME:
( Belt drive) I SUSPECT YOU HAVE A BAD TRANSMISSION SPRING ITS NOT THAT EXPENSIVE OR DIFFICULT TO FIX. YOU CAN INSPECT IT BY TURNING MACHINE ON ITS SIDE AND LOOKING AT THE TRANSMISSION SPINDLE, SHOULD BE LOCATED UNDER THE PULLEY WHEELS AND MOTOR ( ON BELT DRIVE MODELS). U WILL NOTICE A SPRING ABOUT 2-3 INCHES LONG GOING AROUND THE SPINDLE IT SHOULD ALL BE ONE PIECE IF IYTS BROKEN OR CRACKED ETC IT NEEDS REPLACING. -
Another thing to Check is the wig/wag solenoid also in some models. The cam shaft may have slid and broken away from wig wag solenoid
( Direct drive) a simple way of determining with spin or agitate problem is with your washer's transmission (also called a gearcase) or some other part like a clutch or a drive motor coupler. And usually the problem is in the transmission itself in direct drive models. When it comes to spin and agitate at same time.
your next step is toremove the cabinetand jumper the lid switch harness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem isnot in the gearcase- look for trouble in theclutch(see the "Clutch" section below),basket driveor thetub drive block(see the "Drive Block" section below).
If, on the other hand, the disc is NOT spinning, check for a problem withthe motor drive coupleror one of its retainers. This washer doesn't have a belt. Instead, the motor is directly coupled to the gearcase by a drive coupler; that's why it's called a direct drive washer. BTW, replacing the motor coupler is probably the single most common repair on this washer.
Read more:Diagnosing and Repairing Spin and Agitate Problems in a Whirlpool / Kenmore Direct Drive Washerhttp://fixitnow.com/wp/2010/07/07/diagnosing-and-repairing-spin-and-agitate-problems-in-a-whirlpool-kenmore-direct-drive-washer/#ixzz3XW7eZwiNBy the way my advice is free cuz God is good!
Apr 13, 2017 | Washing Machines
How to remove and replace clutch on kenmore washer 110. series direct drive
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Before assuming that the problem is the clutch, I'd check the Motor Coupler first.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
If the motor coupler is OK, the problem could be the clutch:
Sears has a replacement clutch band kit.
See the following for how to pull the pump, motor and transmission.
You DON'T HAVE TO PULL THE AGITATORS OR TUB.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=65fc1c013d6130868b14c8bb4baf7bfd
Also see the Whirlpool / kenmore service manual for these washers.
Both the Motor coupler (available from most appliance parts stores) and the clutch band kit are relatively inexpensive.
See the Following Whirlpool parts list for alternatives to the Sears part numbers.
Nov 18, 2010 | Kenmore 16812 Washer
My kenmore washer will wash okay, drain okay, but when it's supposed to spin, only the agitator spins; the tub stays stationary. Kenmore topload washer, model # 110.26742503
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11026742503/0582/0153200?pathTaken=
Three possibilities: since you can hear the motor (Ranging from easiest to messiest) None of the suggestions are very expensive.
Actually, the agitator isn't supposed to spin. See the section of the Whirlpool manual on the Agitate Cams also.
spinning.
If the Motor Coupler is fine, and the clutch bands and springs are OK the problem could well be the transmission. "Neutral Drain Assembly".
See the Whirlpool / Kenmore Service manual for transmission operations on top load direct drive washers.
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
When ours had a similar problem, we looked at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) and noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 15Oz of 80-90 weight gear oil, remove the clip holding the main spin gear on and check the plastic cams and spin gear.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit or spin gear, put everything back together carefully and the problem may be solved.
COUPLER OR CLUTCH:
Two possibilities: since it will spin. None of the suggestions are very expensive.
spinning.
Nov 05, 2010 | Kenmore Washing Machines
Kenmore 80 series mod110.23832100 washer will not spin with a full load. does spin with small load.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11023832100/0582/0153200?pathTaken=
Oct 16, 2010 | Kenmore 24032\24036 Top Load Washer
My washer makes sreaming noises when in the spin cycle what could be wrong.
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
THREE POSSIBILITIES. TWO EASY, ONE A BIT MESSY BUT DOABLE.
Look in the section for the motor, pump gearcase and you'll see the Motor Coupler.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
2. It may be the clutch bands have worn.
See the following for how to remove the pump, motor and transmission. The clutch is on top of the transmission. Sears has replacement clutch bands.
You don't have to remove the drive tube and brake to change clutch bands.
3. If it isn't the motor coupler or clutch, it could be the "agitate cams" in the transmission.
These are plastic pieces that move the agitator drive shaft up about 1/4" when the washer goes into the spin cycle. If they are worn, you may hear a grinding noise.
Also see the Whirlpool / Kenmore service manual for top load direct drive washers.
See also a more detailed description from Whirlpool of how their transmissions work.
Remove the cabinet, pump, motor and transmission. YOU DON'T HAVE TO REMOVE THE AGITATORS OR TUB.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=1051095663c7f2d5997fa53b976529d6
I had the same problem with major gear grinding during the spin cycle and this solved it.
The agitator cam and follower use the same whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft (About $15.00).
Pull the transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight gear oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
Be sure to align the holes on the Motor Coupler correctly or the motor and transmission won't fit together correctly.
Following is also the Whirlpool parts list for their commercial top load direct drive washers that has a better description of the cams and the Whirlpool part numbers.
It is a bit of a messy job but much ($15 vs $170 for a transmission) less than having a service person replace the transmission.
Be sure to study the Service manual so that you can see exactly how the cams work.Also see the Whirlpool / Kenmore service manual for top load direct drive washers.
Apr 27, 2010 | Kenmore 24032\24036 Top Load Washer
Washer will not spin dry
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.24852300+&pathTaken=partSearch
Two possibilities:
Mar 19, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 20882 Top Load Washer Not Spinning
If the Motor coupler is intact, the next place to check is the Clutch on top of the transmission.
See the following for how to remove the transmission.
If the clutch is worn, or the springs are broken, it cannot transmit power to the spin tube.
If the Motor coupler and Clutch are OK, the problem points to the Neutral Drain Assembly in the transmission.
See the following Whirlpool Service manual on top load, direct drive washers to get an understanding of how the assembly works.
Replacing the neutral assembly is a somewhat messy job (14 oz. of 80-90 weight oil) but at $15, a lot less expensive than a $170 transmission.
Also see the Whirlpool Parts list for top load direct drive washers with clutch and neutral drain assembly's listed.
Nov 24, 2009 | Kenmore Washing Machines
Series 80 washer quit spinning;makes a whir sound instead .model#11028802890
You have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.28802890
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission. It's used as a fail safe device and consists of three parts.
Between them is a rubber piece with six holes. The power from the motor is transmitted through the rubber piece to the transmission.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning. You would also hear a sound from the two plastic pieces rubbing togetner.
With the transmission out of the washer, I'd also check the clutch for wear or broken springs.
Sears has a "rebuild kit" for the clutch if it is damaged.
Oct 19, 2009 | Kenmore Washing Machines
Doesn't always spin, will spin if i give it a push. Load size doesn't matter. Will spin some times and not a other times till I give it some help.
There are three areas to consider:
1. Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission. It's used as a fail safe device and consists of three parts. Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes. The power from the motor is transmitted through the rubber piece to the transmission.
2. Top load, direct drive washers use a clutch mounted on top of the transmission to direct power to the tub. If the clutch pads or springs are worn or broken, the tub won't spin or in your case, giving an assist to the tub may start it spinning.
3. The transmission on top load, direct drive washers uses a Neutral Drain assembly.
Giving the tub an assist may help the cams line up with their corresponding tabs in the Main Spin Gear.
See the following Whirlpool / Kenmore installation and service manual and look at the section on the transmission.
If the Motor Coupler and Clutch are fine, replacing the Neutral Drain assembly is a bit of a messy job but worth the $15 it cost vs. a $170 transmission.
If necessary, following is a method of replacing the assembly.
First, remove the cabinet and transmission.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode by itself.
Kenmore Washer won't spin
If the clutch spins and the transmission does not it is a bad clutch.
While you have it down replace the direct drive coupling also.
And yes, if the machine is in good condition otherwise it is worth doing the repair.
Jul 11, 2009 | Kenmore 27032
Washing Machines Logo
162 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
