Question about K-Line Toys
Looking for insrtuction sheet for K-Line KCC SD-70 CSX. Do you know where I can get one?
Found on O Gauge forum web site
Posted on Nov 21, 2009
MICHELE CSX HAND ALIGNMENT
You don't say if your "CSX" is a battery powered watch or a mechanical or windup type watch. The solution for a mechanical watch is take it to a watchmaker. If it is a battery powered watch you may be able to do it yourself. Not all work the same way so without knowing what a "CSX" is I will give you one way to try. Pull the crown out two clicksHold the lower button in until a hand moves.You have now selected that hand to adjustUsing the upper button now, press and adjust the hand until it lines up with 12Now hold the lower button againAnother hand should moveUse the upper button to adjust this hand to the 12 positioncontinue this until all the hands line up with 12Press the crown in and press the upper button,the chronograph hands should startPress the upper button again and they should startPress the lower button and they should all go to the 12 o'clock position
Oct 21, 2011 | Michele CSX Diamond watch
Looking for the wiring diagram for a syvania LU 70 ballast
http://www.lightbulbsurplus.com/index.php?main_page=product_info&cPath=4_16&products_id=285
Under the heading in the middle of the page > 70 Watt HPS Replacement Magnetic Lamp Quad Tap (In blue), click on>
Download Specification Sheet.
This is a PDF file give it a few seconds.
Just in case, here is the direct PDF file link,
http://www.lightbulbsurplus.com/media/data/LU70-MULTI-KIT.pdf
Wiring Diagram H, on the bottom right corner.
Nov 23, 2010 | Hammering
Check engine code po446,also can only put gas in very slowly or gas will gush out of filler pipe.don't know if both are related.
yes, 446 is fuel EVAP system vent valve circuit malfunction. Check the connection to the vent valve. If connection is good, valve/solenoid may have failed. The vent valve is between the EVAP charcoal cannister and the engine along the vacuum line. If you can tell me your model and year, I may be able to give you more specific insrtuctions.
Nov 12, 2010 | Chevrolet Avalanche Cars & Trucks
Looking for plug in?
one output from pc to boopher and all output to speaker goes to speaker and plug boopher's volt line to ac line 220
Apr 26, 2009 | Computers & Internet
Pioneer SX990
I just scored an SX990 in the original styrofoam packing case with a full manual, spec sheets & all at a thrift store yesterday. It looks mint, especially for something ca 1969-70. I'd be happy to make a copy of the manual for you if you haven't been able to find one yet.
Jonathan
Aug 29, 2008 | Audio Players & Recorders
Gps repair service
You find details to get a service in your area on last pages of your user manual.
Jul 12, 2008 | Garmin GPSMAP 76CSx Handheld GPS GPS...
Favourite setting lost when switched off
I think it is actually Channel 7 causing the problem. I have the same TV and have noticed that Ch7 only drops off the Favourites list when 7 telecasts a program in Standard Definition (SD) on the High Definition (HD) channel 70. They usually seem to do this when broadcasting sporting events. You can check if they're broadcasting in SD on the HD channel 70 by pressing the "INFO" key (also labelled "<<", just above the "TEXT" key). The channel description will read "70 7 SD Digital" instead of "70 7 HD Digital". (You will also see this when you change to channel 70 during these times.) Every time they've done this, I've lost the 7 HD channel from my favourites list. If you re-program channel 70 into your favourites list while it's broadcasting in SD, it will disappear from the favourites list when 7 starts broadcasting a HD signal again. I think I read somewhere that this happens because channel 7 isn't really transmitting a SD-resolution (576i) program on the HD channel, but instead just redirecting your TV to the SD channel's signal (Ch 7 on the tuner) - or something like that! I haven't yet found a way to stop this from happening other than to not change to HD channel 70 when they're telecasting a SD program! I have to admit, it's annoying, but it's a minor glitch in what I believe is an otherwise outstanding TV. I intend to email Network 7 about this problem. Maybe if the problem is their fault and enough people hassle them about it, they might do something to fix it! - Mav (Australia)
Jun 28, 2007 | LG 42PX5D 42 in. Plasma HDTV
Toys Logo
239 people viewed this question
Top K-Line Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a K-Line Toy Expert? Answer questions, earn points and help others
