Question about Protron PLTV-32 Television
My set won't turn on. I did all trouble shooting from the manual,an then some.There is no click when trying to turn it on.
    Problem Solver:
  • 6 Answers
You probably have blown capacitors in the power supply. This is a common problem with LCD TV's. If you want to check for blown capacitors, unplug the TV and take the back off then look for little 3/4" can looking components. If they are domed on top they are blown. You can replace them yourself if you are handy with a soldering iron for about 30 cents each.
Posted on Nov 20, 2009
My tv keeps saying stand bye and it won't cut on all its doing is making the click noise and the red light keep blinking
Try unplugging it for 30 seconds and see if it resets. If not, take the model # and get on the internet for the manual and go to trouble shooting page. It should answer your questions
Feb 13, 2013 | Televison & Video
1998 Honda Accord Won't Start
Park neutral safety switch maybe be the reason for the no crank ! Try putting the vehicle in park ,then try to crank the engine . Testing the electrical circuit is the best way to trouble shoot this problem , along with do a voltage drop test on the starter circuit ! This will test the battery cables an connections .
Starter Voltage Drop
How to voltage drop test starter motor circuit
Does it have a manual or automatic transmission ? Manual ? clutch switch . Looking at a wiring diagram I also see a starter cut relay !
http://www.bbbind.com/free_tsb.html Free wiring diagrams . Enter vehicle info. year , make , model and engine size . Under system click engine , under subsystem click starting . Then click the search button , then click the blue link ! Check the starter cut relay also . Videos on youtube showing how to test a relay controlled circuit !
May 29, 2017 | 1998 Honda Accord
Camera of genoa is preview error
try, basic trouble shooting steps on the phone.
-turn it off and then on
if it won't work,restoring the factory settings of the phone. :D
May 02, 2012 | Samsung C3510 GENOA QUAD BAND TOUCH SCREEN...
My model # is LNC6764A71 and won't drain. There is just a clicking sound. What is the problem? What can I trouble shoot?
This is a single belt washer. Tip it back and remove the belt. Turn the pump and see if that is what is locked up (very common) If that is fine then your main drive pulley needs to be swapped out using a thrust washer kit
service manual
Sep 11, 2011 | Admiral AW22 Top Load Washer
Everything lights up, but won't start when start is button is pushed. Lights turn on when door is opened.
There are 5 possible causes for this. Click here for the Service Manuals=> Trouble Shooting Guide and click here=> NGD7200TW Parts List and click here for your user manual=>NGD7200TW User Manual
For any Whirlpool Related manuals please contact me=> HERE Need Adobe Reader? Click Here sea_breeze_3.png
I will be here should you have other questions, Thanks, Sea Breeze
Aug 31, 2011 | Amana NGD7200TW Gas Dryer
My shutter won't fire using 18-55 lens, either on Manual, P or Auto mode. It is set to AF. But when lens is set to MF, shutter fires. I tried switching to another lens and shutter is perfectly fine.
I could be that your lens isn't focusing. If the Auto focus can't find something to focus on the shutter won't fire. If you are shooting in low light sometimes it has trouble try shooting something that is well lit. also your auto focus point may be somewhere other than the center. there is a button on the top of your camera that looks like this [ ][ ] [ ] [ ]
More or less that will switch where your focus point is. If you look in the view finder and see a red dot when you push on the shutter button that is your focus point. push the above button until the red dot is in the centre. that may fix your problem.
Jul 26, 2011 | Canon EOS 450D Digital Camera with 18-55...
Kenmore 80 series electric dryer Model - 110-60882990 The dryer won't turn on. Once the start button is pushed it makes a single clicking noise. If I open/shut the door and push the start button...
check the actual door switch,, you can jumper it to see if this is the problem, Just connect the 2 wires together , if this cures the problem replace the switch
May 25, 2011 | Dryers
My on button stays on will not turn off and the cancel button flashes orange
try this below....
turn on/off, unplug, plug in, should reset configs.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above. HP has an awesome website for trouble shooting
hope this helps and good luck
Apr 28, 2010 | HP Photosmart C5180 All-In-One InkJet...
Canon Digital Rebel XT auto focus
Auto Focus does not determine exposure. Only sharpness. "Wrong" exposure could be due to the metering mode being set in Spot Metering. Set it back to Evaluative Metering which may improve the overall even exposure of your shots. Test your shots in full auto or P mode. M (Manual) mode will require you to check the exposure setting manually (you can see the indicator in the viewfinder when you half-press the trigger)
Nov 05, 2009 | Canon Rebel XT / EOS 350D Digital Camera
No scan options say refer to device documention to trouble shoot
Try ths:
This happens mainly when you try to scan from the printer ;
Always try to scan from HP solution center but still here is the resolution:
Open Hp Solution center
Click on Settings
Click on scn settings
click on Scan to Setup
Select all the option available to updrade the Front panel menu list and click on ADD
Click on Update;
Restart the computer and the printer and try to scan.
It should resolve the issue.
Regards Soumajit
Mar 02, 2009 | HP Officejet 4315 All-in-One Printer
Protron PLTV-32 Television Logo
116 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
