Question about Bosch Drills
Releasing bit from tool bosch gsh11e hammer drill
  • 154 Answers
Grab the black plastic sleeve where the bit goes in and pull it back, and while you are pulling back the sleeve pull the bit out.
Posted on Jan 18, 2010
How to disassemble a Bosch 11241 hammer drill.
This is a pretty complex tool to tear down, make sure you're up for it.
1) you need to remove the bit holder assembly (#21-30) by prying the rubber seal off on the end, sliding the sleeve off, removing the hog ring, and then the 2 pawls along with the remainder of the bit holder parts.
2) In the nose of the tool behind the bit holder is a large snap ring (#154) that must be removed.
3) Remove the screws on the gearcase cover on the top (#873) and remove the cover.
4) The entire barrel assembly will slide out of the nose (This is generally not easy)
5) Using an o-ring pick or small screwdriver through the holes on the side of the barrel you can reach another hog ring on the inside - once released you can push the striker and hammer out from the nose out toward the piston end.
I would install a service kit and fresh oil if you decide to open this up Bosch 11241EVS 0611241739 Rotary Hammer Parts
Nov 11, 2016 | Bosch Drills
The bit wont lock in the drill, how do i fix this problem
This is a very easy fix - you have a quick change chuck on this tool. Turn the chuck counter-clockwise and pull it straight off - the new one goes on the same way. Quick Change Bit Chuck
May 23, 2014 | Bosch 11236VS Rotary Hammer
I have a hitiachi DH38ye drill and it won't accept the Bosch spline bits. they go in ok but the chuck won't lock. The drill accepts the hammer bits fine but won't accept the drill bits
you have me stumped on this one. The tool you have is a spline shank hammer and it should accept all standard spline bits and also hammer iron that is made for these. Is it possible that the Bosch bit has a burr on the splines not allowing it to lock? I have checked the Hitachi site and found no reason it would not work. I will continue checking though.
Apr 23, 2011 | Hitachi Drills
A bit is stuck in the chuck of my Bosch drill
Hello. Wrap a towel around the chuck and use a pipe wrench or a pair of channel locks to put a little force on the chuck. J.
Jul 19, 2010 | Bosch Drills
Stuck chisel
if you have access to a vise I would lock the chisel in it and pull on the release collar and then take a dead blow hammer and "tap" on the drill to try and pull it away from the chisel.
Jun 28, 2010 | Bosch 11265EVS 158 Spline Combination...
New bosch psb 550 re with hammer action. Hammer action does not seem to engage. even with 5mm bit progress is non existent. The bits were bosch masonary bits and I was drilling into concrete blocks
your pin under the selector switch my have broken off. also the hammer rod could have broken too. if its drilling and not hammering that more likely. you may be under warranty call bosch or log on and go to dealer locator's for the closes dealer to you. hope this helped
Oct 09, 2009 | Bosch Power Tools Hammer Drills
Bosch - Rotary Hammer Model 11232EVS
This site does not have the manual for the exact model number you are seeking but several that are similar and may be helpful:
http://powertool.manualsonline.com/ex/thread/view/idThread/76898
Sep 03, 2009 | Tools & Hardware - Others
Bosch 11222EVSG hammer drill not turning
Couple things to look at, First is the selector in the hammer/rotation mode? Without a bit in it does the collar turn when in the rotation mode. Are you using the right bits for this tool. If yes to all of these I would look down the spindle and make sure that the pawl are in place (they lock to the bit for rotation) Let me know and we will dig deeper.
Mar 06, 2009 | Bosch 11222EVSG 1 1/8 Inch Grounded Sds...
Chuck came off of drill on a Bosch 11236VS hammer drill
Have you pulled the collar to release the pressure on the steel balls. Just pull the collar usually forward and slide on the shaft and then release and twist till it locks. Let me know if I can help further
Jan 07, 2009 | Bosch 11236VS Rotary Hammer
BOSCH 11236VS HELP ME WITH A PROBLEM
I order parts for my Bosch tools at WWW.toolpartsdirect.com. They have the parts lists also so it is easy to find what you need. Don't forget to order some bosch grease for your tool because you will need to carefully wash-out all the old grease with metal bits. Good luck with you repair. Enjoy
Nov 25, 2008 | Bosch 11236VS Rotary Hammer
Drills Logo
123 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
