Motorola Mobility V555 Cellular Phone Logo
Posted on Jan 11, 2008
Key pad do not work
The key pad on my motorla v555 do not work, power button works.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 28, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
41
Points
Open your phone up and clen out the dust with some alcohol fixed m phone has been working since
1helpful
My motorla gps tn30 is froze the key pad is froze
HOLD THE ON/OFF BUTTON DOWN FOR APROX. 8 SECONDS,THEN TURN THE UNIT BACK ON AND IT WILL RESET. TAKES A MINUTE OR SO TO DO THIS
KENWOOD RXD-V555 PROTECT MODE WAS APPEARED . i CANNOT OPEN MY COMPONENT
MY MODEL IS RXD-V555 , LAST 1 YEAR NOT USE AND NOW START BUT PROBLEM IS WHEN POWER IS ON GO ON PROTACT MODE AND NO SCREN. PLEASE HELP
When I press any button on the DVD player the word Flash Sum keep blinking and nothing works.
this shows that the microprocessor in the motherboard seems to be defective hence its advisable to reprogramme or change the entire motherboard then programme again. this will completely provide the solution
Touch Pad and mouse buttons
try it with toggle keys it may be work
I have a Verizon Moto Q. The buttons are not working properly. When I hit the start button, back, the arrows, or center select button, mail button and certain letters it just enters numbers or letters and...
Hi, from the question you posted, there are three likely problems to the phone. One it's either the key button pad is bad which needs to be replace, the interface of the key button pad is dirty which needs to be cleaned, or the glass I.C which controls the key button is bad which also needs to be replaced.
But i think what the problem is the cleaning of the key pad button interface because the buttons are working but they only misrepresent whatever function you try to perform on the phone.
You just need to get a mobile phone technician or an electronic repairer around you to help service and clean the board and key pad button interface, and the phone will start working fine..
Take care
Mar 26, 2010 • Cell Phones
1helpful
2answers
Keys not working
dont worry.its only the key pard problem.you need to replace the key pad and dont forget to ask the repirer to clean the circut board.avoid hard use of key pad.take care
22helpful
8answers
Code error 021 not in book inforation codes
1. Push the function button
2. Push 7 on the key pad
3. Push Monitor button 4 times (it will only beep at you - nothing will appear on the screen) - so count the beeps)
4. Push * on key pad
You should now see the service menu option
5. Push 7 on the key pad
6. Push "Set" button
7. Push down arrow button once
You should now see the fuser reset option
8. Push "Set" button
You will be prompted for 1 for Yes 2 for no
9. Push 1 on key pad.
You should receive confirmation that the reset is *COMPLETE*
10. Push Stop button until back to the main screen
11. Power down the fax
12. Wait 5-10 seconds.
13. Power on the fax (and cross fingers)
Key pad not working
it could be that your key pad got burned out it happens a lot with hardware your best bet is to get it replaced cuz there is no fixing it only if you get a new chip but that can cost you more than the actual product its self
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
