Question about GPS
Memory card i have a Disney mix micro mp3. It said I needed to buy a memory card, so I did and then it says you have to download music onto that before inserting it. How do I do that?
    Sniper:
  • 62 Answers
Does your computer have a memory card slot? You will need to write\download your music to this card using hardware that can write to the card. Many computers sold today have small slits in the front of the computer for just this purpose. Sliding the card in to the appropriate slot allows the user to write data, songs, onto the card for use elsewhere.
If your computer does not have a card reader\writer, be sure that the Disney device itself can't act as a writer by using a usb cable. If the device does not have a usb port to attach to your computer, you might also consider an external card writer like this one:
http://www.circuitcity.com/ccd/productDetail.do?oid=98958&WT.mc_n=93&WT.mc_t=U&cm_ven=COMPARISON%20SHOPPING&cm_cat=BIZRATE&cm_pla=DATAFEED-%3EPRODUCTS&cm_ite=1%20PRODUCT&cm_keycode=93
Otherwise, you will need to find someone with a card writer to place your music on the card for use in the Disney device.
Posted on Jan 18, 2008
6ya staff
SOURCE:
How do i download music on my mp3 player?
How to Put Songs on Disney Mix Max
The Disney Mix Max portable media player is capable of playing audio files in the MP3 format. It can also play videos formatted as WMV and display photos formatted as JPEG. You can convert audio files into MP3 using the Disney Mix Max software -- Mix It Plug-in. The plug-in works with Windows Media Player 10. This software CD came with the player and is not available online. To download music to the device, you can use Windows Media Player 10 or Windows.
Things You'll Need:
* USB cable
* Mix It Plug-In installation CD
Instructions
Convert Non-MP3 Files
Install Mix It Plug-In. Insert the Mix It Plug-in installation CD into the computer's optical drive. Click "Install Mix It Plug-In" when prompted. If no screen opens, double-click on the "My Computer" icon. Double-click on the installation CD icon. Then double-click on the setup or installation file; this file is often formatted as EXE. Select to have the program saved to your desktop. Then double-click on the desktop icon -- "disneymixitplugin" to open the setup wizard. Click "Next" in the setup screen. Follow any additional setup prompts.
Open Windows Media Player 10 and create a playlist. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Open Mix It Plug-In. Select "Yes" when asked to save analysis information for your music files. The software will analyze each track's compatibility with the Disney Mix Max player.
Press "Go!" to start the conversion process. Once the process is complete, an inactive "Go!" will be displayed. All music that has been converted is still listed in your Windows Media Player 10 playlist. You are now ready to download music to the player using Windows Media Player.
Open Windows Media Player 10 on your computer.
Remove the USB jack cover located on the bottom of the Disney Mix Max. Insert the compatible end of the USB cable into the USB port on the Disney Mix Max. Insert the other end of the cable into the computer's USB port.
Click "Library" and click a playlist name. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Select the "Sync List" tab and choose "Sync List" from the menu.
Verify the items to be synced to the Mix Max, or right-click on a song title and select "Delete" to remove it. Click "Start Sync" to download music to the Mix Max.
Windows
Insert the USB cable to the Disney Mix Max USB jack. Connect the player to the computer with the USB cable.
Click on the desktop "Start" menu and choose "My Computer."
Double-click on the "Removable Disk" that corresponds with your connected device.
Drag songs saved on your computer with your mouse into the Removable Disk folder.
Tips & Warnings
If you converted files using the Mix It Plug-In, you will need to use Windows Media Player 10 to sync them to the player.
Mar 11, 2011 | Disney Mix Max Digital Media Player
How do i download music fRom my computer onto a SanDisk with a micro in my cell phone
hi what you will need to do is either use a USB cable from your pc to your cell phone, the memory stick (micro sd) will show as a removable device then just copy and past the mp3 files that you want to copy, the other way is to buy a sandisc micro card adapter, this looks just like a normal SD card, but at the top of it there is a slot that you put the micro SD card in then put it in a card reader as normal, then transfer the music over to that disc, when done just pull your micro sd card from the adapter and insert it into your cell phone as normal and away you go...hope this helps
Aug 18, 2010 | SanDisk Computers & Internet
Dvd to memory card for mix max
Go get the windows media encoder its free. Set the profile that comes with it up . I get 8 to 10 full length movies on a sd card.
Dec 28, 2008 | Disney Mix Max Digital Media Player
I need to download music and pictures from my computer onto a Samsing SGH-t219 mobile phone, but I can't figure out how to.
Does it use a Micro SD card? Buy one, with the adaptor to hook up to your computer. When you do that your computer will recognize that you inserted a memory card. Click on music and drag all your mp3's on there. If your phone does not utilize a memory card, then it is not made for music or at least it will not hold but a song or two.
Nov 11, 2008 | Cell Phones
Mix Max movie becomes pixellated.
If other video cards do not have the same issue then it's probably because the HSM card was damaged by inserting it or removing it when the player was turned on. Or you may simply need to reformat the memory of the player or it could be that flashing the firmware of the player could correct the issue.
To format the player follow the instructions listed here;
http://digiblue.com/customer-service/faqs/disney/mixmax/06.html
If that doesn't work try the firmware listed here;
http://digiblue.com/customer-service/faqs/disney/mixmax/17.html
Aug 15, 2008 | Disney Mix Max Digital Media Player
Adding new mp3's
Have you loaded your software onto your pc?
Jul 23, 2008 | Disney Cars Digital Mix Sticks (128 MB)...
Disney Mix Max problems
The memory could be corrpt in the player. It some times happens so try reformatting the memory to clear it up. This will erase everything and then you can put your songs and stuff back on it. Here's a link to the manufacturers instructions on how to format the player.
Mar 21, 2008 | Disney Mix Max Digital Media Player
Downloading Music onto Mix Max
If the music is already on your computer, it must be in mp3 format, do the following;
1) Open Windows media Player,
2) Connect your Disney Mix Max
3)Click "sync"
4) "Drag" song to where it says "Drag items here",
5) Click "Start Sync"
Jan 10, 2008 | Disney Mix Max Digital Media Player
Sansa c250 sd card installation
yes i have the same problem how do i get the music onto card itself
Jan 10, 2008 | Audio Players & Recorders
GPS Logo
111 people viewed this question
Top GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a GPS Expert? Answer questions, earn points and help others
