Question about Cyberhome CH-DVD 300 DVD Player
Change set up on DVD from PAL to AUTO if my TV set has no PAL
How to change set up of DVD player from PAL to AUTO if my TV set (KDL-46XBR9) has no PAL compatibility?
  • dstramski Nov 22, 2009
    My DVD is CyberHome CH DVD 300. Because the DVD has been set to PAL and my Sony TV is NTSC, I am unable to display the DVD set up menu on my TV and change the DVD setting to AUTO or NTSC. So this question is how to do it?
  • dstramski Nov 23, 2009
    Your solution does not work.
    After pressing MENU with remote, the symbol "NO" does NOT appear.
    After pressing 1, and then 9, the symbol "NO" does NOT appear and the menu does NOT appear.
    My TV set constantly displays "No signal....".
    I know that the cables are correctly connected between DVD and TV, and that I look at the correct INPUT on TV. This is because I used before this DVD player with this TV set and it worked. I simply changed the DVD setting to PAL by mistake and now I am unable to reset it back to AUTO or NTSC. \
    Please provide a solution that will work.
    Again my DVD is CyberHome CG DVD 300 and my TV is LCD Sony Bravia KDL-46XBR9.
  • 2,335 Answers
There is a reset to auto function for this dvd player's video mode setting. Turn the player off, then turn the player on, open the disc tray, and then press and hold the STOP button for at least 5 seconds to reset the video mode to auto.
I hope that helps.
Posted on Nov 23, 2009
  • 5,807 Answers
if your DVD media is PAL system encoded and not /nor have NTSC
then no need to change the settings of your DVD player, however
if the media can both play on PAL and NTSC then you need to provide
us the make and model of your DVD player.
In the case of having the DVD player and the DVD media ( disk)
both in PAL system . it would need an additional converter to
convert PAL system to NTSC. Although some VHS player/recorder
have built in converter from PAL system to NTSC , you can use
it, just in case you have one available, and PAL is not an option
on your Sony KDL 46XBR9.
your Sony KDL 46XBR9 have NTSC , an American TV standard
here is a link to a manual , just in case you need one,
http://www.docs.sony.com/release/KDL40XBR9.pdf
it is stated on page 46 of the manual.
hope this helps, thanks for using Fixya!
Posted on Nov 20, 2009
  • 7 more comments
  • Rommel Cana
    Rommel Cana Nov 20, 2009
    here is a portion of it
  • Rommel Cana
    here is a sample of PAL to NTSC converter
    and here is a link to these converter,
    guide
    http://www.goldenshop.com.hk/AI-trad/Mis...
  • Rommel Cana
    Rommel Cana Nov 22, 2009
    you can try these:
    You will need the remote control.
    1. First make sure there is no disc in the player, and there is no
    obstruction in front of tray. (Glass door, etc...) Close the tray.
    2. Press MENU on the remote (Ignore the 'NO' symbol that appears)
    3. With the remote, press 1, then press 9 (Ignore the 'NO' symbol that appears)
    4. A menu should appear.
    5. REGION CODE should already be highlighted. If you want to change
    this, press ENTER on the remote. Then type a region code you want the
    player to have. (0 is all region) Then press ENTER on the remote after
    changing the setting.
    6. To exit the menu and save your settings, make sure nothing is
    in front of your player (Glass door, etc...) and push OPEN/CLOSE with
    the remote.
  • Rommel Cana
    Rommel Cana Nov 23, 2009
    i don't know what cable you are using to connect to your precious TV,
    if you are using the 3 RCA progressive cable, try to use the S -video connector, you need to have one if you don't have and connect it to your TV video 2 input.
    one reason you cant see the image from the DVD player is , might have been set to use
    S -video not the 3 RCA cable. in which case it is the reverse if you are using the S-video
    connector , it might have been set to 3 RCA cable.
    if there is still no signal from your DVD, try other TV or try using an RF modulator just to verify which output is being used by your DVD player. the solution will not work till there is no signal coming from your DVD.
    i am just wondering how you have change from PAL to NTSC and having no signal.
    how did you know it is PAL and it is NTSC?
  • Rommel Cana
    here is additional info
  • Rommel Cana
    and here is another one
  • Rommel Cana
  • Rommel Cana
    here is additional guide from the manual
  • Rommel Cana
    you can connect the DVD out here , just to find what output is DVD using
How do I get color display? It's displaying black & white only.
it soudns like a cabling issue. What connections are you using?
Oct 02, 2015 | Televison & Video
Change ntsc to pal
The manual seems to indicate that the TV will automatically detect what signal type is present, so PAL should be recognized. There is, however the possibility that the "Color System" setting under the system menu may not be set to "AUTO", but NTSC. This would cause a conflict when detecting PAL input and affect picture. Check the "Color System" and either select PAL or AUTO and see if that helps.
Sep 18, 2014 | Televison & Video
How to change ntsc and pal settings in a sony bravia ex400? It shows black and white color with a dvd player.
how to change ntsc and pal settings in a sony bravia ex400? It shows black and white color with a dvd player.
Jan 22, 2011 | Sony BRAVIA KDL-V40XBR1 Television
DVD MOVIES NOW PLAY IN BLACK AND WHITE
the problem is from setting on the remote control, you can change the colour setting form the remote that is NTSC to PAL or AUTO....
Go to the menu on the remote control of your TV and the DVD Player....
May 29, 2010 | Sony SLV-D271P DVD Player/VCR
My dvd player is outputing a black and white picture both on its own screen and when connected to a tv.
this has to do with picture compatibility between the TV and the DVD player.
To resolve this, check picture settings from your TV and change it to PAL or AUTO.
From DVD, change to NTSC or PAL. This could be gotten directly from the DVD remote.
All the best.
Jan 06, 2010 | Televison & Video
Denon Dvd-2910 only displays black and white on the tv screen
this is not a serious problem. It just has to do with visual compatibility.
Change the DVD display to Pal or NTSC and set that of the TV to Auto or pal.
You might find the PAL/NTSC on the DVD remote, or on the button of the DVD. If it is not there, then Check display settings of the DVD.
As for the TV, Change to Auto or Pal from display settings.
Take care.
Jan 01, 2010 | Denon DVD-2910 DVD Player
TV with PAL Only DVD
No,tv is PAL or NTSC not possible to change region setting in tv.
Dec 12, 2009 | Televison & Video
Won't play ntsf dvds in colour
if your dvd is ntsc compatable then in your dvd settings menu change from Pal to either auto or ntsc also it might be that your tv needs to be changed in the same way
May 28, 2009 | Televison & Video
I can only record and play back in black and white.
siri,
for the black and white screen output of your DVD and VCR.
1) for DVD player: using remote control locate "setup" button and click.a dialogue box should appear indicating " audio setup" video setup" etc.....
2) select and scroll to "video setup". in video setup there should be an option to choose "AUTO" "PAL" or "NTSC"
3) choose "auto" then check if any change in screen color.
for VCR, locate a switch or button indicating "PAL" "Auto""PAL SECAM" "NTSC". same with the dvd choose and select "auto"
note: if you still have the manual for both VCR and DVD check the instruction with regards to video color setting.
cheers,
mark
Jan 15, 2009 | Philips Magnavox DVD/VCR Dual Player
Pal/Ntsc playing problem
is your tv is the same tv that u playing before? coz according to you if u play ntsc there is no problem. if ur tv is multisystem, u can change the tv system menu to auto, but if not u cannot watch coz ntsc tv only accepts ntsc signal.
Jan 08, 2007 | Pioneer DV-373 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
91 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Henry  Thomas
Henry Thomas
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
