Question about Vtech Uniden BCD396T Compact Digital Handheld Scanner 2-Way Radio
Looking for part number ''po 838AA'' Push to talk button, volume control circuit board. With price and where to get it. Thanks
  • 211 Answers
As far as I know, the BCD396T scanner does not have a push to talk button since it is only a receiver.
If this is the correct model for which you are trying to find a part, they can be ordered directly from Uniden.
Listed below are their phone numbers, as found on their website:
Uniden® America Product Support
Customer Service
1-800-297-1023
Mon-Fri
8:00A.M.
to
5:00P.M.
C.S.T
Parts & Accessories
1-800-554-3988
Mon-Fri
8:00A.M
to
5:00P.M.
C.S.T
Scanner Products
1-800-297-1023
Mon-Fri
8:00A.M.
to
5:00P.M.
C.S.T
Hearing Impaired
1-800-874-9314
Mon-Fri
8:00A.M
to
5:00P.M.
C.S.T
Online Store
1-800-554-3988
Mon-Fri
8:00A.M.
to
5:00P.M.
C.S.T
Repair Department
1-800-235-3874
Mon-Fri
8:00A.M
to
5:00P.M
C.S.T
Marine Products
1-800-586-0409
Mon-Fri
8:00A.M
to
5:00P.M
C.S.T
Closed Saturday, Sunday, and Holidays.
Posted on Feb 20, 2010
Two codes pop up?
Possible causes P406 include EGR Valve clogged, dirty or leaky
- EGR valve damaged/defective
- EGR volume control solenoid valve
- EGR temperature sensor and circuit
- EGR volume control solenoid valve harness is open or shorted
- EGR volume control solenoid valve circuit poor electrical connection
Possible causes P0108 - Faulty Manifold Absolute Pressure sensor
- Manifold Absolute Pressure harness is open or shorted
- Manifold Absolute Pressure sensor circuit poor electrical connection
- Faulty Engine Control Module (ECM)
May 23, 2014 | 2006 Lincoln LS V8
I have no idea what standby looks like; but I can't access the phonebook; I see the symbol, but nothing happens when i press it; I have successfully linked my cell and downloaded the phonebook from cell;...
A qualified person will have to remove the back (and circuit boards if necessary) to get to push buttons. Check for bits of plastic or something stuck between push button and circuit board. Check for corrosion on circuit board or missing /misaligned switch pieces.
Oct 29, 2013 | Uniden D3588-2 Corded / Cordless DECT 6.0...
What to do with po 406 code
P0406 DODGE - Exhaust Gas Recirculation Position Sensor Circuit Highxicon.jpghttp://engine-codes.com/p0406_dodge.htmlForum CodePossible causes- EGR volume control solenoid valve harness is open or shorted
- EGR temperature sensor and circuit When is the code detected?An improper voltage signal is sent to ECM through the valve
Jul 10, 2012 | Dodge Caravan Cars & Trucks
Hello, I have a small problem with my Pioneer CDJ-200 and i hope you will help me with an advice. It's about the ''play'' button which is working but something is wrong with its spring when you push,...
Hello
You are dicussing about the microswitch that fitted on your CD payers' control printed circuit board; I understands. If so, it can be replaced. Microswitches are of many types with different sizes and pin confugurations. You just desolder it out from the circuit board, and go for a same type, both in size and confuguration. Keep a keen look at its height, whcih cannot be exceeded of the present switch fitted in your CD player. Insist on exact size, and go with that sample you have resoldered it out.
Microswitches are available easly, on all electronic sparepart shops, and are cheap in price also. OK
Dec 01, 2010 | Pioneer CDJ-200 CD Player
Refrigerater stopped working just a clicking noise from the circut board is there a rset button anywhere
unfortunately there is no reset button. you can try disconnecting power for a few minutes and plugging it back in to reset the circuit board. most likely you have a bad relay on the control board. you didnt list a model number for your refrig so i could get you a part number for you. I use sears.com in their parts section to look up part numbers then google the part number to find the best price.
the control board is plug and play and any one that can use a screw driver should be able to replace the part with no problems. thx peyton
Oct 10, 2010 | GE Caf? 25.4 Cu. Ft. Side-by-Side...
I have a Samsung TV Model # LNT 4671FB. I need the circuit board part # that controls the ON/OFF switch.
Encompass Parts Distrbution has what you are looking for
1-800-638-3328 Go to their website and type in your model #LNT4671F They are listing free service manual and Parts/Prices.
Aug 28, 2010 | Samsung Televison & Video
Push numbers whilst talking on phone
1. FYI, when your call is dailed through successfully - please pay attention as there are two instructions on the screen. It tells you to press which button for dailing and which to press to unlock the screen.
2. To answer your question: On the left hand side of the phone, there are 3 buttons. Press the button at the bottom below the volume up & down buttons. The dailing screen should come up.
This button is also used as a shortcut for changing profiles quickly in the main screen.
Jan 22, 2010 | LG Prada KE850 Cellular Phone
Handset volume on Panasonic KX-TGA101S is too low
CLICK HERE for the user manual.
and HERE for the Base Unit
Pg 13 of the second manual designates how to adjust the handset volume.
The quick answer is to press TALK (or while talking to someone)...
Then, using the middle round button... press up or down to adjust the volume.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Jun 03, 2009 | Panasonic KX-TGA101S Cordless Handset
Part number: 316809100002-R02
I too have the same power board burnt out ... did anyone ever find the part you was looking for ... Thanks
Nov 20, 2008 | Computers & Internet
Need manual control board (power,volume, channel and menu push buttons)
Manual push buttons part number should be CM35776-B01-SA.
Give me a few hours--I'll get the remote part number....T
Oct 30, 2007 | JVC AV-32950 TV
Radio Communications Logo
147 people viewed this question
Top Vtech Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Vtech Radio Communication Expert? Answer questions, earn points and help others
