Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Replaced projection lamp but lamp does not turn on and instead of blinking green power indicator I am receiving a blinking amber lamp
  • Panasonic Master
  • 1,527 Answers
Hello make sure the lamp fitted securely and the lamp cover as well after this should be ok
shaun
Posted on Nov 20, 2009
3 Suggested Answers
  • 59 Answers
SOURCE: PT-60LC13
there are fans inside tv need to make sure they are clean and free of dust
Posted on Feb 05, 2008
mistersony
  • 320 Answers
SOURCE: Sony Grand Wega 60" indicator lamp blinks 5X green then 6 red
It is unusually to see BOTH of these flash codes together. I have never seen them at the same time. A 5 flash is a lamp driver error, which is possibly related to your lamp failure. You may have to replace the lamp driver or "ballast" to correct this problem. The 6 flash is a power supply problem and more serious, as it will likely take a technician to narrow down exactly where the fault lies. It may be a thermal fuse open OR a failure in the power supply itself. What was the original symptom that caused you to replace the lamp? Did you use an original Sony lamp as a replacement?
Posted on Nov 27, 2008
WD-57731 Will turn on, I get sound but no picture.
You should be able to see if lamp itself is lit or not, if lamp does come on or has been replaced recently let me know, I have a idea or two but need more information if possible.
Oct 14, 2012 | Mitsubishi WD-57731 57" Projection HDTV
What does hdmi is blocked mean
Hello!
HDMI blocked could mean, that one or more HDMI inputs are turned off. In WD- series DLP TVs it's possible to disable one or more inputs, which are not to be in use, to speed up signal source switching. Most of modern sets are constantly monitoring inputs and automatically recognizing "plug"n"play" signals. blocking any input would not cause TV to shut down.
Yellow(amber) light means: lamp door interlock switch is off or malfunction. green blinking: set is initializing, about to begin normal operation. So: quite possible that lamp has been replaced incorrectly or door is not tight intermittently. Last possible issue: door's interlock switch is bad. Take lamp door off and you will find the switch with blue lever on the left side of the door inside plastic compartment. Push it with your "pinky" or pencil carefully, then ask someone to turn set on. Make sure, yellow light is off, before do so. If set starts normally, observe lamp's activity: it should stay on and getting brighter, while you holding switch. If lamp stops working, while there is no "amber" light, then TV shuts off, red blinks, lamp is bad. I just had to replace lamp twice, due to defective batch of lamps with housing. 3rd time I replaced bare bulb and it solved the problem. But there was no "amber" issue!
good luck,
Alex.
Mar 06, 2012 | Mitsubishi WD Televison & Video
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
I replaced the lamp and it still doesn't work
You can try to reset the lamp timer. Check your manual to see how. If that doesn't help, your power supply may be bad. Then you should seek a repair service.
Feb 27, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
WD-62525, continous amber lamp light. No picture. Lamp is good.
Hello:
Make sure u replace the lamp cover as the safety switch need to be closed to make the set work. If new lamp did not repair your problem , then it may well be the Ballast Board, Sometimes call the Lamp Driver.
Nov 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I have owned the PT-43LC since Nov. 2005. Up until now, it has been a great HDTV. Today, I had my first "issue" and have yet to discover a fix. I turn the TV on and it blinks green, indicating that the...
That sounds like a bulb. You should pull it out and check it.
Pretty easy to do, but if mine did the same type thing, replaced the lamp and powered right up.
Sep 12, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Had a solid amber light indicating a new lamp was needed.
Press the menu amd device/input buttons both in together on the front of the set and hold them both in for 6 seconds to see if the timer light will blink a two digit blink code such as 3 blinks, slight pause then 4 blinks. If it blinks that code you will need the V26 Power pwb repair kit which is available at the following link under repair kits and has step by step instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Apr 22, 2009 | Mitsubishi WD-62725 62" Rear Projection...
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
Panasonic PT-50LC13 Power Light Blinking Yellow
My Panasonic PT-50LC13 when turned on has a green light for a few seconds you can hear the fans turn on and then you have a yellow/amber light that starts to blink 8 times i have replaced the bulb and the door is closed any ideas?
Apr 01, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Projection lamp indicators
maybe you have lost contact at the lamp circuit! check the CRT circuit and the lamp circuit!
Oct 03, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
81 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
